Temperature gauge goes between 140 and 230 degree and back and forth
I have a 1994 Ford Explorer Limited 4 wheel drive V6, auto
transmission. The temperature gauge keeps going up and down from
140 to 230 degrees and back. The radiator was replaced because of
a leak, the radiator cap was replaced, the thermostat was
replaced 3 times, the anti freeze was replaced and flushed 3
times. A new mechanical gauge was put in same problem. The anti
freeze doesn't go down so no leaks. There is plenty of heat from
the heater. The truck doesn't boil over. Ford doesn't know, they
don't believe it a head gasket. Two mechanics looked at it and
can't figure it out. Help if you can. Thank you in advance.
How quickly does it fluctuate? If you're talking seconds, then its a senser. The coolants actual temperature isn't going to change quickly
Volvo 240 - Overheating Problems
3 messages,Last post on Jan 18, 2001 at 10:58 AM
the general consensus is that its a sensor and not a real overheating situation. very frustrating !!!!!!
