Nissan Pathfinder Owners Care & Maintenance
Dealer #2 actually had a 65F00 filter in stock, and there was Japanese writing all over the box. Oddly enough, the box stated that the filter was for a Sentra! This dealer's theory was that the 65F00 filter was put on by the factory "to save money." Anyway, he also believes that the correct one for the '01 PF is 9E000.
So that's all I have. Anybody else hear anything different?
might be more enviromentally friendly and using smaller filters so the land fields don't fill up with oil filters. Nissan engines are so clean,don't make metal ect. I'm not concerned about the size.Steve
I did some Google searches on "65F00," "65F01," "31U00," and "9E000." There were a lot of sites in Japanese, but there were a couple interesting ones in English.
One guy, Rick, put the service log for his 2000 Sentra online, and it's here:
http://www.zotz.com/nissan/service/sentra_se_service.htm
In it he talks about how he replaced the factory-supplied 65F01 filter with the 65F00.
Another website I found is an Infiniti site, here:
http://www.infinitihelp.com/Store/
If you click on the "Maintenance" section, you can then click on your car and part that you want. It then takes you to the page where your proper part is displayed. If you click on QX4 and then 2001-2001, then oil filter, it takes you to 9E000. If you click on G20 (Sentra), and same model year, then it takes you to 65F00. (For your amusement, note that they are charging over TWICE what you'd pay for the exact same filters at a Nissan dealership!)
I realize that neither of these are official Nissan sources, but I did find it interesting considering that the dealer I talked to also stated that the 65F00 part was for the Sentra (I saw it on the box myself).
Maybe Nissan intends for us to put the Sentra (4-cylyinder, 140 hp) oil filter on the 3.5 liter engine.
The important thing about the filter is that it has a relief valve. The manual says, "The oil filter is a small, full-flow cartridge type and is provided with a relief valve." It also has a diagram of the filter, which looks like the longer 9E000 and not the smaller 65F00. Unfortunately, the manual doesn't list filter dimensions, but it shows the relief valve, which both 65F00 and 9E000 have.
I just looked over this string of posts, and realize that other dealers have 65F00 listed in their computers for the '01 PF. The two that I went to had 9E000 listed. Maybe it's a regional thing based on supply/demand. Or maybe some dealer's computers aren't as up-to-date as they should be. At any rate, I'm sure that there are a lot of PF's out there with 65F01's and a lot with the 9E000. It probably doesn't matter.
Since the 9E000 that I have is what the service manual calls for, and it looks like the diagram in the service manual, and it has a relief valve, and 2 dealers here told me it was the correct one, and it looks like the 65F00 is for the Sentra, I'm going to stick with the 9E000.
--Howie
He seemed very friendly.
"When I went to change the oil in my '01 PF for the first time, I found that the filter on my car was different than what you guys gave me."
He knew exactly what I was talking about immediately. In fact, he knew the part numbers.
"The 65F01 filter," he said, "is for the Sentra SE-R. It's essentially the same filter."
"But it's smaller," I said.
"That's right," he replied, "It otherwise wouldn't fit on the engine of the Sentra. Still, it works fine on the Pathfinder. Eventually, though, Nissan is going to go with one part for both, probably the 31U00, or 9E000." Again, he said these numbers right off the top of his head, without looking them up.
"So why do other Nissan dealers around the country call for 65F01 to be used with the PF, but others around here call for 31U00?"
"They often do that due to a surplus of parts in different regions. They're trying to get rid of the 65F01's, so where there's a surplus they'll put them on the PF's."
So it turns out that everybody was right. Some dealers do show the 65F01 (or 00) as being the correct part, while others call for the 9E000 (31U00). Now I'm definitely keeping the 9E000 on my car, because it's bigger and has a larger filtering area. The Nissan mechanic agreed.
Hope this clears everything up.
--Howie
http://www.nationalfleetparts.com/luberfiner.asp
and has 'Excellent limited-slip performance'
Ok, here's the question of the month: Does this means that this is a LSD APPROVED gear oil that can safely be used on my PF and I don't need to add any LSD additive? Thanks in advance for your assistance. Daniel
They have excellent air filters also. Steve
I found it on the Nissan site at:
http://www.nissan-techinfo.com
I've heard about Amsoil products but this is something I want to get done before I go on a trip and I don't think I can get the Amsoil order bef the weekend (I can buy the Mobil 1 syn at AutoZone). BTW, how many quarts I need for both the front & rear diff? TIA for the feedback. Daniel
It has over 2500 pages. I went with the CD for a couple reasons.
1) I thought it would be easier to search the manual for the information I need.
2) My last manual had come into contact, many times, with my greasy fingers while working on my vehicle. Now I can print out the section I need and throw it out after the work has been completed.
I hope I made the right decision. ;^)
flowed from the filler hole. I'm sure they were full. Next time I change the lube my wife might make me do it outside. I change it this winter in the garage and the smell was really pugnant.! Steve
Is there any way to calibrate the odometer/speedometer?
The only thing the Service Manual talks about is diagnosing whether there is a problem with the gauge. But the only solution, if there is a problem, is "replace the unified control meter." Anybody find anything else in the SM relating to odometer calibration? As a corollary, this means that if you were to change the size of your tires, you wouldn't be able to calibrate your odometer/speedometer to match.
--Howie
Thanks. Take care
-kj
P.S. I checked the FAQ and did not see "tire pressure" discussed. Maybe it could be added?
Just a thought.
Scott
That would be a good internal test. However, both the speedometer gauge and the odometer take data off the same electronic unit. If that central system which controls both of those is off, then the test as you described above would be normal, but the car could still be miscalibrated.
I will try it, though. Thanks.
--Howie
I have accumulated dust on the instrument panel face, and am interested in a method of cleaning the face without scratching it. Any ideas?
Meguiars, www.meguiars.com, has something for that. Its for clear plastic. I use their Gold Class Products for outside protection (Polish & Wax).
Clark
and the engine. The limited slip differential looks like any other from the outside
except there should be a red sticker on it to identify. The LSD is part of the rear
axle, the drive line (or propeller shaft) is connected to the front of the diff. If
you look infront of the spare tire is is in the middle of the rear axle it's about the
size of a basket ball. The service is due every 30k. I like some change to synthetic
oil in the front and rear differential. Might get better milage and longer service???
There is a drain plug on the bottom and a fill plug about halfway up the differential
and both can be seen from the rear looking foward. Hope this helps?
-johnskev
http://www.topnotchauto.com/
they have a special - $32.50 for lexol leather cleaner, lexol leather conditioner, vinylex, and 2 pads. click on "Specials" at the website.
Did anyone get the factory brand? Has anyone gotten a different one? How much did you pay and do you think it is worth it? Did you find it to be inconvenient when cleaning your PA?
I saw a nice set (front/rear bumper and tail lights) from WAG. I like the look and "protection" it can offer. I'll be moving from the burs to the city within the yr and I thought this would be a good way to counter the unavoidable digs.
what are your thoughts/advice on this? Thanks for your time and help.
first time poster/if owner
I figure I'll buy two connectors from Nissan and then fashion a 12 to 18-inch extension for the sensor. With a little extra wire I should be able to move it away from the radiator and into a place that gets more ambient air flow. Whole job shouldn't cost too much...
The present location not only gets radiant heat from the radiator, but it is behind a large piece of grill that prevents good air flow across the sensor. My old car mounted it on the bumper behind the license plate, so that's where I'll probably go with this one.
Any one else tried anything interesting?
Anyway, I placed the sensor in the grill attached to the top of the upper-most opening with the sensor actually exposed and not hidden by anything.
The grill is deep, everything behind the grill is mostly black, the sensor is black, and it's so far up in there that it's in the shadows. I don't even notice it and I know it's there.
As long as I'm moving, I get an accurate reading. Of course, as soon as I stop moving, the reading goes up. But, it doesn't take too long for it to go back down once I start moving again. With it that high up, it isn't as affected by road heat as much as it would be if it were under the license plate.
At the risk of sounding even more redneck, I'll tell you what I used to fasten the sensor to the grill: two ordinary paper clips. It was meant as a temporary solution for testing the accuracy of the location, but it's been there for over a year, now, and hasn't budged at all...and they're cheap to boot! Good luck!
thermometer does not react very fast and the vehicle must be driven at 6 mph or faster for 100 in. and then updates itself every 40 seconds. Cheers.
1. I used a floorjack and lifted the front using the cross beam (the one at the rear of the undertray). I placed one jackstand under each front jack point (see manual - the strangely shaped "sockets" just under the front doors on the frame rails.
2. I then used the floorjack under the diff. and placed the jackstands on the rear axle as per the manual jack points - just about where the shocks are bolted to the axle.
A few things I noticed at this second oil change -
a) Watch the tightening of the undertray bolts - I found two that were almost off (and yes, there are 11 of them plus the plastic doohicky!).
b) The oil plug gasket should last a lifetime - it's a copper one (unless it falls off and you loose it).
c) Indeed, as I have found on other vehicles, if you don't overtighten the oil filter you can remove by hand (tighten 2/3 of a turn after the gasket touches the engine - be sure to oil the filter gasket before installing).
d) Don't reinstall the undertray until you refill the engine and start it up so you can check for leaks (and don't forget to reinstall the new filter before refilling and starting ;-).
A touch of anti-seize will allow the bolts to break next time. This is will not cause the bolt to come free on its own. Hell, I do that with my race's wheel studs with great success. I have seen guys break studs because they didn't use anti-seize.
can get messy. Also try using dow corning #4 (DC4) grease on the oil filter
Purolator recomends it on their aircraft oil filters. They always spin off easy.
Cheers
I wonder about the tapered nuts on aluminum wheels, though. Most aluminum wheels use nuts with locating "barrels" and flat surfaces to hold the wheel on. Is this also a contributor to the "shimmy" problem? Also, the rear propellor shaft has no slip joint in it. Only the front has. Questions, questions!
