Nissan Pathfinder Maintenance and Repair
1424345474855
    The weather must be getting warmer in some parts and people are lowering their windows - this is the second helicopter thread in the last day or so. It's a common issue with many new cars:
    tidester, "Volvo XC90 SUV" #930, 3 Jan 2003 9:19 pm
    That's funny I just saw your other post!
    -mike
    bmwrider1bmwrider1 Member Posts: 1
    I have the same problem with a 2001 LE, and have removed 2 fuses under the left dash to stop fans, but of course have no AC or heat. Did you ever get an answer?? Possibly a relay? Mike (BMWRIDER1)
    You have a bad fan relay it would seem.
    -mike
    woodchuukwoodchuuk Member Posts: 1
    yes you read that right, when i hit the left directional it makes the transmission downshift. i've never heard of this happening to anyone on any car but here it is happening to me. whether moving out into the left lane or stopping at a light, as soon as the directional is triggered, the transmission downshifts. i have done several experiments and there is no doubt the issue is happening the way i say. any suggestions would be greatly appreciated...thanks.
    scottinkyscottinky Member Posts: 194
    just yesterday the forward/back controls on my drivers seat stopped working. the seat
    is now stuck in the far back position, which is fine for me, since that is where it usually
    is. However, my wife can't drive the vehicle in bad weather now. Does anyone have any
    idea how much it will cost to replace, or where to get the parts? This is the second
    electrical item to fail. I shoulda got the extended warranty.
    shark715shark715 Member Posts: 382
    Funny, the EXACT same thing just happened to me. What year is your truck, mine is a 2001.
    2003. Took it to the dealer to have it fixed. $537. Seat track and one of the motors
    had to be replaced. My service guy gave me a 10% discount, so I ticked in under
    $500. For comparison, the seat place in town would have been about $60 less, but
    would have taken longer. The parts were $270. What a rip.
    freddy7freddy7 Member Posts: 1
    Took my 98 Pathfinder w/95,000 mi in for an oil change, and the tech came out and said "cam seals leaking badly, recommend timing belt, seals, tensioner, and water pump." Bill would come to $2290 + tax and fees. Should it really cost this much? The car runs great, doesn't seem to be leaking anything, and have had all PM's done...
    ncdiver2ncdiver2 Member Posts: 1
    Ok heres what i know 1998 pathfinder overheated and died now will not start !.there is spark to #1 cyl.2 there is fuel leaving and returning to fuel pump 3 no obvious water in oil.4 water pours straight thru and out left bottom of block as you face motor ? freeze plug I hope.Anny help to trouble shoot starting problem need to get it up on ramps to see where water leak is.Very little help with manuals.They show parts but no real trouble shooting,Thanks Brian
    lifelover1965lifelover1965 Member Posts: 6
    I just bought an '05 Pathfinder LE Granite color in mint, and I mean mint condition, with only 5100 miles on it. I traded my '03 Jetta TDI with 87k on it. I loved the great gas mileage I got, but I always missed my pathy. (I had a 1995 Pathfinder SE)Anyway, with the trade, I paid 19k out the door. I felt good about the deal considering how new this Pathy is. Anyway, I haven't got a chance to look at the manual yet.(I like to do the basic maintenance things myself)My questions are:
    1.Are the newer models user friendly as far as basic maintenance like oil changing etc?
    2.Is there anything I should be aware of to look out for or problems that people are having with the newer models?
    3.The oil appears virgin, but I plan to use Mobil one Synthetic when I change it. Any body have any luck with accessories to help improve gas mileage a bit besides using synthetic oil?
    4.Can any one recommend a web site or store that sells a good Kayak carrier for the roof and a rear hitch cargo hauler?
    Thanks in advance for your help!
    alwaysbusyalwaysbusy Member Posts: 11
    I have an 06 (with 23k on it already!). I have had (1) major problem twice... and another problem once.
    The first major problem I had involves the "DTE system" not working. i.e., twice - when the tank showed I had 1/8 of a tank - I RAN OUT OF GAS. The "DTE" system did not engage, the yellow gas-low light did not work. Just.. all of a sudden the DTE went to a flashing "---" and the car died. Twice. That's apparently fixed now.
    The other problem was the right front brake - the caliper got stuck in a closed (or open?) position and wore the brake pad out and almost damaged the rotor. The brakes had been squeaking, I'm glad I brought it in when I did. Both were warranty issues but a pain in the you-know-what. I love driving my "pathy" but honestly if the Honda Pilot had fit into the garage, we would have gotten that instead!
    Yea, I was looking in to the Honda Pilot also, but then I came across this deal and couldn't pass it up. I test drove the 07 Pilot, but I like the "drive" feel of the Pathfinder and the look except for the back end which looks like a minivan. Well, I hope that any problems that occur happen under warranty like it did for you.Thanks for your reply!
    psychobillymanpsychobillyman Member Posts: 1
    I've just bought a 1998 Pathfinder and I just discovered a goofy problem the previous ower decided not to tell me about. Some times when I first start the truck in the morning, it will be running just fine then you put in gear and it just dies, and it will do it over like 5 or 6 time in a row then it will be just fine for the rest of the day. Has anyone else had a problem like this?
    Jake
    rbowenrbowen Member Posts: 1
    I have a 2002 Pathfinder that recently has started to overheat every once in a while (3 times) immediately after turning the engine off. While driving the temperature gauge reads normal. But when I stop I hear gurgling, the coolant in the over flow goes up and eventually overflows (if I turn the key back on, but not actually start the engine the temperature gauge reads at the top of the marked range, but not maxed). The first time I refilled the radiator and everything worked fine for a couple of weeks. The second time I replaced the radiator cap and refilled and it went fine for about a month.
    The last time it did this the check engine light came on during the trip.
    Any ideas?
    vette1946vette1946 Member Posts: 1
    I have a 1995 and when it hit a 105,000 i decided to changed my timing belt as recomended, i found an article on the internet explaining the whole procedure with pictures and it also said when doing the timing belt to replace seals cams & crank 3 total also suggested to replace tensioner and water pump total cost for parts from nissan less then $250 and about 16 hours,i would shop around and probably wouldn't pay more than $700-800 tops.I believe the interval for a 98 is 60K do you know if it was done if it was you can wait till 120K.Do you see alot of oil on the ground where you park the car at your home.but i believe $2290 is way to high,was it a nissan dealership that quoted you the price?Good Luck
    loachloach Member Posts: 246
    I have an '01 Pathfinder SE. There is some annoying squeak coming from the steering column in turns. Took it in to the dealer expecting they could just lubricate it, but instead they told me the bushing where the squeak is coming from is inaccessible and they would have to replace the whole steering column to fix it. Obviously I don't want to spend a lot of money to fix a mildly annoying squeak. I've searched the forums here and found other people with this problem - but no suggested solutions. Anyone have ideas?
    smokey75smokey75 Member Posts: 434
    This TSB may help. Unfortunately the repair would be out of warranty.
    Thanks for the reply. Yep, that looks like what it is and it is consistent with what the service writer told me at the dealership. Since it's out of warranty, I'll probably just tolerate it unless it gets worse. Disappointing.
    jomarchjomarch Member Posts: 6
    Hello! About your goofy problem you say well......it is not goofy at all. I had a 1990 pathfinder for 15 years and now I have a 2001 pathfinder. It is all about how the previous owner drove and maintained the pathfinder I think! Try letting the truck motor warm up a little longer before you put in gear and I think you will see the problem disappear and also add some gas treatment to your tank every time you fill your tank up.
    Hope It Helps - Jo In Texas
    smurfalicioussmurfalicious Member Posts: 2
    wow, a really old post, but my fingers are crossed you'll get this.
    i'm having an issue with wiring/relays... can you please provide to me the instructions for locating the relay box? specifically for the turn signals/flashers?
    thank you thakn you thank you thank you!!!
    kzc2 hasn't been around for a while but maybe someone else will chime in? :)
    SUVs and Smart Shopper
    sweet... thanks...
    jamie29jamie29 Member Posts: 6
    hello, i have this same problem, did you fix it? can you tell me where you bought the sensor? THANKS!!!! jamie29@comcast.net
    pfx2pfx2 Member Posts: 5
    It's the drivers side after the cat. I purchased a ODBII tool and bought the O2 Sensor online. Much less expensive than the dealer! Fixed in a few minutes!
    can you tell me where you bought yours so i can do the same procedure as you? how much was it? also, do i need the ODBII tool, and where can i buy that, or will the computer reset itself once the oxygen sensor is installed?
    my code says:
    P0158 Rear O2S, Bank 2
    i think it is:
    part # 226A1-4W011
    can i reset with this procedure?:
    reset procedure after replacement:
    http://www.nissanhelp.com/Ownership/Common/codes3.htm
    thanks in advance!!!
    pathstar1pathstar1 Member Posts: 1,015
    I purchased a "Scangauge II". It can read and reset codes, as well as display up to four parameters at a time (out of about 18 to choose from), such as fuel use, engine temp, batt. voltage etc. It also has a trip computer built in. Cost is $180 US or so. It sits on the dash plugged in all the time.
    do i need to spend this $180 to fix the error code? where did you get your oxygen sensor? did you get an OEM or a universal where you have to solder the leads? thanks
    I've replaced both rear oxygen sensors on my 01. You don't need the scan tool for the repair. I would recommend you buy the OEM sensors, which are Bosch. But check www.nissanhelp.com & look for the TSB for rear oxygen sensors. I'm not sure if it applies to 2002s but if so that's probably why yours went out. The rear sensors were activating as soon as you start the car & the moisture in the exhaust was shorting them out. The TSB calls for reprogramming the ECM which turns the rear sensors on later once the moisture burns off. The ECM is covered under the longer emissions warranty (but not the O2 sensors). I replaced the sensor, then took the receipt & TSB to the dealership & they did the reprogram no charge under the emissions warranty. As far as where to buy the sensor, just google "2002 nissan pathfinder O2 sensor" & you should find a lot of places to compare prices. Good luck...
    Hello, i just went under the car and looks like i have to buy a universal 4 wire, and cut the leads and solder them and use electrical tape or shrink fit tubing to insulate... i can't reach the darn plug! it's way up in there... how the heck did you reach it?
    also, to reset the error code, can i just unplug the battery for 10 minutes after i put in the universal sensor?
    thanks!!!
    It's been a while since I did it but I'm pretty sure you access the plug topside. Now what is a pain is the snap in wire guides to keep the cable tucked in. Some of those are impossible to reach. The 10 min. battery disconnect should clear the codes, but don't forget about the ECM reprogram or you'll end up in the same boat again.
    do you think it's easier to buy a universal 4 lead sensor and just cut the leads and solder the wires underneath the car, and therefore leave in the existing cable? that way i don't have to re-route the thing? i didn't even think to look topside, i'll check that tomorrow!
    also, about the reprogramming, i have 91k miles and the dealer told me it's $330 to reprogram the thing. so, i'm thinking the old sensor lated quite a while, how long til the new one blows out?
    also my BOTH of the catalytic converters rusted out! and it's only a 2002! i cna have universals welded in a meineke for $total but the friggin' warranty should be 8 years!!!! but i got too many miles.
    you think i'm ok not to reprogram? and also, is the universal easier and just cut and solder underneath the car, and seal with shrink tubing or electrical tape?
    thanks for all your thoughts!
    The 4 wire one would probably be ok. I don't have any experience w/ other brands so hard to say. I don't blame you for not reprogramming the ECM at that price. But that seems way high. It only involves them hooking up their scan tool & updating the ECM. 1/2 hour, 1 hour labor at most.
    well it's only $30 more ($76 total with shipping) for the direct connect, that's what i'll do. So let me ask, the connector is the red cable at the right front side area when looking at the engine? That's the left rear one... I think what I'll do is run the new one next to the old and wire-tie it to the old one rather than the locations it's lashed to now... sound like a plan?
    i'll hook it up and do the battery disconnect for 10 mins, and then if all is well i'll pass inspection ASAP!!!
    been driving for 4 months with "rejected!" for this one reason alone. luckily no tix yet!!! LOL
    the dealer won't ECM for free due to 91k miles... it's a scam!
    Yeah, actually that's not a bad idea. I mean, it's kinda goofy but honestly I kinda wish I had left the other cable in place & done that & avoided the scrapes on my arms. It's pretty easy to drop the sensor through from the top. If you have other Nissan dealers I would check their prices on the ECM reprogram.
    okoehlerokoehler Member Posts: 1
    Hello pwlong19,
    not sure if you even still own this Pathfinder, but did you ever figure out what the problem was? Just bought a used 98 Pathfinder and it's doing exactly the same thing you describe.
    OK
    My sister's '02 PF with 71K miles burns a quart of oil every 1000 miles. Her dealer recomended a valve job, but I told her it would not be harm anything and to simply add a quart of oil when needed. My '01 PF has 111K miles and uses a quart every 2-3K miles. What kind of oil usage are people here with higher mileage 3.5 engines (model years 2001-2004)experiencing? Has anyone here with a 3.5 engine had their truck repaired due to oil burning? What was repaired, what was the cost, and did it resolve the issue? Thanks.
    I noticed that one of the plastic clips that holds the bottom of the front bumper cover to the frame of my truck is missing. The other clip is still there and I'm guessing the missing part is identical. It is circular in shape, and it looks like it just presses into the pre-drilled holes in the bumper cover and frame. Anyone know what this is called so I know what to ask for at the dealer's parts department? Thanks.
    newmannewman Member Posts: 11
    have a 95 pathfinder 4x4 the reverse went out need to find some place that will fix it and not charge me a arm and a leg. i live in southeast kansas. or any ideas why the reverse went out. :confuse:
    burdesalotburdesalot Member Posts: 1
    I have an 02 SE and depending on my driving will go through at least a qt every 3K miles. If I just drive back and forth to work, I go through a qt. If I do extended highway driving at 70-75 mph. I can go through 2 qts. I have 120K on mine.
    I trust my mechanic and when i asked him if I should have the work done to stop the oil loss he said not to bother since body rot is the number one cause of death where I live. He said just keep feeding it oil.
    dudenbosteldudenbostel Member Posts: 4
    Please be aware the wiring harness can burn. We had a brake sensing unit put in a year ago right after we bought the vehicle. Our sensor lights came on a month ago and we took it to our dealer, Hampton Motors in Fort Walton Beach Florida, after diagnosing the vehicle they downed our vehicle as being unsafe and then determined the whole electrical wiring harness in the vehicle had completely melted. Now a month later, Hampton's determined because of the brake unit our warranty was void and are charging us $3000.00. The mechanic informed us the brake system was properly installed but other than the unit (the braking unit still works) they cannot determine why the wiring harness burned. Check your wiring harness.
    Did you get a second opinion on why the wiring harness melted? If another mechanic says it wasn't related to the brake sensing unit, then warranty coverage may kick back in.
    mojobagginsmojobaggins Member Posts: 15
    When I flip on my headlights at night on my 2001, the interior night lights(clock, around transmission lever, etc) don't turn on. Nor does the dimmer switch on the lights that are always on(instrumentation panel, digital compass/thermometer) work.
    Any ideas if this is a simple switch or something that I can easily replace? Hate to have to bring it to the dealer and spend a lot of money to fix.
    Check the fuse chart in your owner's manual. If I recall correctly all of the items you mentioned are on the same circuit. If that is the case, the fix may be as simple as replacing the fuse. But if a new fuse blows, too, obviously you will need to determine what is causing the fuse to blow.
    hisnandezhisnandez Member Posts: 1
    Ok i'm hoping someone can help.
    Basically i'm down to this i've checked everything i can think of and when it came down to simple spark plugs its sparking but i noticed that i can pull the 4 and 6 plug and it has no effect on the engine it's still idling rough and not rougher. i can't even go up a hill with this thing without it dropping down to 1st to get up the hill. i smell light gas odor on the plugs when i pull them back out but i'm lost at this point (and yes the distributor order is correct i've checked that) on that note i have also switched the 4 and 6 plug and this doesn't do anything either help im lost. btw its a 93 pathfinder 3.o sev6
    :mad:
    khurramkhurram Member Posts: 15
    I just bought a used pathfinder 20001 se, with 60k miles on it. Nearly Everything works fine, as it is still under extended warranty.
    There is one thing which is driving me crazy. If I am driving at low speed at 40 mph and let go of accelerator, then if I slightly tap the accelerator instead of pressing it down hard as I just want to increase the speed slightly, it makes at lound whirring noise at 1500 rpm and 45-50 mph. If I keep the accelerator pressed hard, then it does not happen as it shifts from 2-3-4.
    When it is whirring, I think the response goes down also.
    I am thinking it is a timing belt or transmission issue.
    Before I got the car, the dealer had installed a new transfer case, harness wiring.
    Any help on this would be appreciated as do not trust the dealer to much to really take an effort to replicate the problem in the workshop.
    Khurram
    This is exactly the problem. Does anyone have access to the TSB to help me furhter. Thanks
    Khurram
    Service Bulletin Num : 00053
    Date of Bulletin: JUN 19, 2000 View Document
    Component: POWER TRAIN: AUTOMATIC TRANSMISSION
    Summary: SOME APPLIED VEHICLES MAY EXHIBIT A CHIRP NOISE AS THE AUTOMATIC TRANSMISSION SHIFTS FROM 2ND TO 3RD GEAR, PARTICULARLY WHEN ACCELERATING THE VEHICLE WITH ONLY 1/8 THROTTLE APPLIED, THE NOISE MAY BE COMING FROM THE HIGH CLUTCH ASSEMBLY DURING OPERATION.
    matt04matt04 Member Posts: 6
    I have a 2004 Pathfinder SE which has had an intermittent problem with squealing belts. The issue started approx 2 years and I have had the car serviced 4 different times for this particular problem. The problem was initially diagnosed as a CS belt/pulley problem. At first the belts were reset, then replaced, then the pulley was cleaned and reset. After each adjustment the noise would stop for a variable period of time and then recur. The NIssan service center performed these services for free as the problem was first diagnosed while the car was under warranty.
    Now the Nissan service center says the squealing is from a broken power steering pump and that it is not the same problem as all of the previous squealing. They further state that it will not be covered by the warranty since this was not the problem initially and the car is out of the warranty period.
    My question is: is it possible that this was the underlying problem initially? Is it reasonable to think that a similair squeal recurring over the course of 2 years is the same issue or is this two distinct problems? How would I differentiate? And how do I know that the fuel pump was even checked during any of these other visits.
    newport444newport444 Member Posts: 2
    Hey nospam4cj,
    Haven't seen you post anything more on Bose Clarion CD changer issue. How did it get resolved? I have the same problem. Did you make a deal with Nissan not to post any more comments about this issue if they took care of you? :)
    jaedleejaedlee Member Posts: 59
    mine died one disc slot at a time... mine's 2001 LE.
