4x4, is 10 years out of date.
Really annoying, I just tried to move the roof rack bars, you need a HEX key, what moron, invented that idea. I had 2 Jeeps, 2 Explorers, all had small turn wheel to adjust the roof bars.
Trunk area, without carpet, so everything, puts scratches scuffs on plastic.
Truck is basically a piece of junk.
I have 25 months left of a 36 month lease, wish I could give it back tomorrow.
Reg. Frank R.
I called today and there are no recalls or service bulletins issued right now. I am taking mine in on Thursday for the third time. I am also going to request that they let me drive a different 08 on the lot.
If they can't fix it, I may see what options I have to turn over my lease and get a manual transmission or a v8 (I'm assuming the v8 is different).
Probably those who haven't had a previous year of this car might not notice the transmission. I sure do!
When passing gear is needed (pressing deep on the pedal) - engine revs to 6k but car doesn't speed up accordingly - this is irritating - you have to feather the pedal too much. Clock doesn't keep the right time.
Brake pedal is vague and has a lot of travel before really slowing vehicle - requires heavy pressure for quick stops. Hood shimmies on the road - metal too thin.
Oil pan hangs too low - NO OFF ROAD USE for my SE V6!
I don't think this vehicle will last 70K without constant repair - SUV is designed to need constant dealer involvement and I'm a do-it-yourself guy.
BE SURE to get a thorough check before your car(s) hit the warranty limit!!
The problem is when i am going to park in reverse and when i shift to Drive i hear a loud sound like " CLUN" in the back of the SUV . When i took it to service they replaced the differential shaft twice and the sound keep getting LOUDER? The dealer is waiting for a service advisor to take a look of my pathfinder...
It is a 2005 SE model 4X2 automatic trans. 30K
Can anyone can help me?
When I scroll through AM / FM / Sat Rad / CD, it goes straight from FM to CD and no longer gives me the Sat Rad option.
Does anyone have any recommendations on how to start troubleshooting this?!?!?
I am about to purchase a PF LE 2WD in the next two weeks.
Before I purchase, I plan on taking the exact car for a nice long test drive.
I am taking the car in Monday and going to drive v8. Going to try and make a deal to trade up. There is 3,250 in incentives on v8.
I could have gotten the v8 for less monthly pmt, but since I felt my 05 was awesome, didn't even drive the v8 or the v6 before purchasing.
Any ideas / solutions!!???
I was afraid I tightened the belts too much or not enough but staff at Checker/Autozone say that isn't it. The manual says only 1/4 inch play halfway between pulleys and mine is a little more than that.
After reading some forum answers, i noticed one about smoke out the exhaust and a possible catalytic converter issue, i do seem to have a higher level of smoke out the exhaust (although i have always noticed this a little on this truck)
Thanks in advance!
There is another sensor right next to that i dont see documented in the manual. Any ideas what that might be? They are right next to each other.
This might explain my problem. it looks like a pain to replace. i will try electrical tape for a quick fix.
I am going to look for a cheap scan tool to get a reading from the PCM.
One guy tried to tell me it was CBT (I know this car is not CBT) another guy said it was a deacceloration retarder which I also think isn't the case.
Another guy said that it is drive by wire....as I understand it, the car controlled electronically and as you get into higher speeds you don't notice the downshifting etc.
I don't totally get it..anyone? He said that one of their service managers and other consumers have also noticed this weird drop at 30-40 and they have had many bring it back. I don't know sounds like it is what it is. BTW, service mgr has v8 and he says it also does it same as v6
WTF, I am so sick of being jacked around by these service techs. The one today goes into this condescending lecture about CBT. I smiled and said, cut the BS. I know what CBT is and the Pathfinder is NOT CBT. Another mgr came out and said that it is an accelorator retarder and I'll be happy that my brakes will last longer. I was like f the brakes, I'd rather replace them every 10,000 miles than drive like this.
Then another guy who actually seemed to know what he was talking about said it was the drive by wire thing. I accepted what he said, but looked it up and the 05 was also drive by wire.
We need to keep talking about this and sharing...I have a $42,000 car sitting in my garage that I would love to drop at the dump.
I think there is a production problem and we're just going to be miserable the entire time with this 08 model.
me again! My Sirius radio miraculously just started up again! I did have a prob with my battery (original one) which apparently was low on fluid (not sealed) and it went dead Monday morning (2/25). When a new battery was put in - voila - I had Sirius back after doing nothing!
Coincidence or related? I don't know but I am glad I have it back!
I hope yours is working now also!
I've had this code on the ESM for quite some time and just got around to having it fixed. I bit the bullet and had a repair shop (not Nissan dealer) 'try' to fix it. After 3 days of back and forth they have diagnosed that the problem resides in the cam on the right side. When the engine is revved up it has a whine very similar to that of a standard fan belt. They have assured that the sound is not from the belts but rather coming from the cylinder 1 cam sprocket. In spirit of 'trust but verify' I'm asking if anyone out in forum-land has seen or heard of this before and if so how much am I looking at for a repair cost.
Thanks in advance!
I am late to this game with the Err1 messages. I just inherited my wife's 2001 Pathfinder LE and you guessed it the CD player is broken. Did Nissan every provide a final fix for this? Is it reasonably priced?
I also believe this is a production problem. It is so disappointing because the Nissan Pathfinder has been a solid, well built vehicle in the past. I have had 4 prior to this one.
What are they telling you from Nissan Direct?
I guess I should have provided more information with my initial post.
They diagnosed the problem correctly and changed out both banks the first day. I spent 20 minutes with the mechanic and he went over the diagnostic tests he did and told me the problem had been fixed. A day later and the SES light is back on so I take it in again and they look at it for an hour or so and they check & clean all of the connections in case of a bad contact. They reset the SES. Day 3 and the light is back on, I call and drop the truck off in the morning and don't get a call until late in the day (a good eight hours laters). I stop by and talk with the mechanic again (this time for 45 minutes). He explains that the problem isn't the sensor but rather the cam timing that the sensor is picking up is off. He then proceeds to start the car and rev the engine. There is anoise that sounds like a soft whine of the belt that he says is not coming from the belt but from the right side cam. The sounds is definitely coming from that general area. He also mentioned that he spent the day working on it an had a friend who works as a mechanic at the Nissan dealership helping him diagnose th problem. When I look up info on the cams on this forum it appears that there is a guide or tensioner that helps keep the cam chain tight I wonder if the guide is worn and the slack is causing the fault.
Another interesting thing that may or may not be related is that the warning light for the parking brake turned on after I washed the truck today. It wasn't as bright as if the brake was on and changed in intensity from time to time (the further I drove the dimmer it became). I've seen this before with my 4 wheel drive indicator lights after a car wash they would stop working then after they seemingly dried out they were back to normal.
Thanks again for the assistance.
When I discussed my problem with relative at nissan, he first thought maybe it was CVT. Then, he checked with the Nissan tech guys who said there is no CVT on Pathfinder.
I posted earlier about telling off the service guy and saying there isn't this feature on Pathfinders.
I looked on the specs at Nissanusa.com and sure enough, it shows CVT. I'm trying to find specs on the 05 to see if it also had it.
When Edmunds lists transmissions on the Styles pages, the choices are Auto, Manual and CVT and the Pathy has an Auto listed there.
The 2005 owner's manual doesn't anything about a CVT, but it doesn't say much about the transmission at all from what I can tell.
The 2008 Pathfinder does not have a CVT based on the Styles page info. link
I confused CVTCS with CVT. CVTCS is a function of the engine not transmission.
I am meeting with GM at the dealership tomorrow to request that he allow me to drive a 2008, and a used Pathfinder 05-07.
Whipsplace
how big a repair is the head gasket. is it a super time consuming job all to put in a $10 part or is it very tricky type of job?
He mentioned it also has to to with EPA approval. Because the issue also related to gas fuel adjustments.
I never had this issue with my 05 - I'm very dissappointed - Anyone know if this can fall under Lemon Law???
I know the shock absorbers in my front right wheel aren't all that great but I don't think that's where the problem lies.
When I speed up a little or hit the brakes a little it stabilises but I'd really like to get it fixed. Is this a common problem and does anyone have any suggestions how to fix this?
Danielle
He mentioned it also has to to with EPA approval. Because the issue also relates to gas fuel adjustments.
I never had this issue with my 05 - I'm very dissappointed in the 08 - Anyone know if this can fall under Lemon Law??? What can we do?
I took mine for a drive with GM and Service Tech. They acknowledge what I am complaining about, but say it is NORMAL. my 05 definitely did not shift this way. I started getting angry because they say it's normal...based on what? Have they driven Pathfinders Exclusively for the past 10-12 years?
I am trying to connect with my friend who has an 06 to see if hers drives the same. I did drive another 08 and it is the same as mine.
Keep us posted if you get any answers on your end!
Dealer changed cannister and vent valve - no good, SES came back on after a few days.
Eventually - they found that it was a crack in the gas tank filling pipe - there's a bend where the pipe gets to the actual tank - they replaced it and no more SES. BTW - there was also a smell of gas before they changed it.
Hope this helps.
Cheers.
I drove my friend's 06 the other day just to see and what do you know, tranny was just as I remembered in my 05. Do you think this was an intentional "difference" or do you think they have a production problem?
To add insult to injury, I've been attempting to deal with NMAC regarding the offer to upgrade and waive up to 3 pmts. I did the deal, submitted the required paperwork. they kept sending me bills and I spent hours on the phone trying to "prove" that I didn't owe the last two pmts.
A week ago saturday, some bully from a COLLECTION AGENCY called demanding I pay up.
This transaction, the car the whole thing is being chalked up to a REALLY BAD deal.
I think there might be some truth in the fact that the EPA is demanding different standards on vehicles now and it may have something to do with the change. Maybe they get the transmissions from a third party and that party has changed to someone cheaper. I am not sure. We called Nissan about the problems and they never called back. I have read other posts and they say Nissan is working on the problem. I doubt it. We will drive this one for a little while and then trade in for something of better quality.
And is there a way to determine if I have a LSD without jacking it up? Anything in the VIN or door panel plate?
