Normal to stay on after u shut off the car. Not normal to play after you open the door.
Mark.
Anybody had a problem with this one? Both of the Keyless Entry knobs are broken (the hook which connects to the keychain is broken) and I blame Ford's stupid design team to design a piece like that. Anyway, what options do I have. I want my keychain AND keyless entry thing together. Any after market solution for this?
To be clear, there is nothing wrong with the actual function of the keyless entry thing.
Thank you,
Rahul.
That is about 3 times the labor rate/hr that I am familiar with.
When you brought the car in did they inform you of these possible charges? :mad:
thanks for any help
Mark.
Does your trunk leak too? Mine does and no matter what we do, we can't seem to keep it from leaking.
Having never used a CD changer or system like this before would anyone be able to give me some guidance on what to buy, where to fit and how to operate etc.
Mark.
(Evidently available for "fleet buyers" only.) Any way to add them to my vehicle? A lot of cars have the capability to add items because the wire looms are the same for each vehicle when built at the factory. You can add a relay or whatever to activate the particular option. Thanks! Jeff
2. Re insert the fuse and turn the radio on (nevermind the on off sequence). Insert a music CD, it will take one.
3. Pull the fuse again, count to five and re insert fuse.
4. When the CD starts to play, use the menus to get down to the factory default settings and ask it to reset to factory.
5. And you are now working again. Or you should be. It basically is a processor and it operates just like your home PC whn it needs a reload. It searchs to the default drive which is the CD player.
Good Luck everyone!
Please assist.
I have the same situation
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
