4WD and AWD systems explained
2456729
    woodyr1woodyr1 Member Posts: 142
    Drew:
    I own a Nissan Pathfinder with a part-time 4 wheel drive system. A direct mechanical link exists to engage the transfer case and operate the front drive shaft.
    I am considering the purchase of a replacement vehicle and am looking at a Toyota 4Runner. The 2000 model (SR5) has a floor lever, like my Nissan, which locks in the front drive shaft almost instantly upon engagement, a part time system. The 2001 models have 'one touch 4 wd', which works through a centre differential and apparently allows one to drive in any road condition in 4 wd, without damage to tires or mechanical drive components.
    I live in central British Columbia amongst the mountains and valleys, and engage 4 wd, as conditions warrant (snow, ice, etc). I drove a 2001 4Runner, and noticed a delay from when the one-touch 4 wd button was pressed until the 4 wd icon illuminated on the dash. Do you know what mechanical processes exist to account for this delay? My present vehicle actuates 4 wd almost instantly as engaging the floor lever. I like the advanced features of the 2001 Runner, such as traction and skid control, but am concerned that the 'lag' in engaging 4 wd may present a delay in obtaining traction when needed. With a centre differential, leaving the 4 wd engaged would not cause any wear problems, but the increased fuel consumption and loss of power may be noticeable. I have an opportunity to buy a 2000 4Runner SR5, which may be more suitable to my environment.
    Why not take a look at the Highlander? It has more room and a lower price, plus permanent AWD. No worries, no buttons, 225hp, and better gas mileage.
    If you don't need the low range or ladder frame, it looked pretty nice at the auto show I went to.
    -juice
    drew_drew_ Member Posts: 3,382
    Nice to hear from another BC'er. AFAIK, the one touch 4WD engages the front prop shaft in exactly the same way as your Pathfinder, except that there are more electronics involved to actually engage the mechanics. Do you recall if the wheels were turned, or how quickly you were going at the time? I know that it does not necessarily engage until certain parameters are met (to prevent damage/excessive wear and tear to the system).
    Personally, I would recommend that you leave the system in 4WD mode at all times. If there is any fuel economy difference it will be negligable, and you will have twice the amount of usable traction than in 2WD mode at all times. As such, in any emergency situation, VSC may not have to intervene as early or as forcefully. FWIW, Consumer Reports ran their Jeep Grand Cherokee Laredo with SelecTrac 4WD (similar to the Toyota's system) in both 2WD and 4WD full-time modes and found no difference in fuel economy. They recommended leaving the system in the latter mode at all times since it helped to stabilise handling. As for loss of power, this shouldn't be the case at all since 4WD simply redistributes the power from the 2 rear drive wheels to all four wheels. As a result, you also get more even tire wear.
    To see a technical view of why full-time/permanent AWD/4WD is better than 2WD, read the following links:
    http://www.4x4abc.com/4WD101/tractionturn2.html
    http://www.4x4abc.com/4WD101/tractionturn4.html
    Hope this helps! Any questions are welcome, of course.
    Good suggestion, but I have a feeling Wes will want to take the vehicle off-road now and then :-) The 4Runner would definitely seem more at home in central BC than the Highlander (though it's also a good choice). In snow though, the 4Runner would definitely have the advantage.
    Drew
    Vans, SUVs, and Aftermarket and Accessories message boards
    You mean the Highlander just for snow, right?
    -juice
    Huh? No I mean the 4Runner for snow. With its greater ground clearance, and permanent 4WD system + stability control, it should be better than the H.L.
    Drew
    Hi Drew:
    Thanks for the information. To answer your question, I was going straight at about 30 kmh, when I pressed the one-touch 4 wd button. The icon on the dash flashed a few times, then became solidly illuminated. It was fully in 4 wd at this time.
    I appreciate your input, as in winter conditions, leaving it in 4wd will be of benefit. With all the electronics and speed sensors etc. do your forsee expenses with servicing, or reliability? I understand that the system is covered by the 5 year/80,000 km power train warranty.
    Wes
    What you describes actually seems normal to me. I recall the same behaviour when I test drove the '99 4Runner Limited about 3 years ago (back then only the Limited version had the full-time 4WD system).
    With the 4Runner's excellent track record in mind, I do not forsee any problems with leaving the vehicle in 4WD mode all year around. Actually, a friend of mine has a '99 4Runner Limited (bought it brand new in late 1998 ) that is in 4WD mode all year around, and I have yet to hear him mentioning anything regarding reliability problems, or the lack of power/loss of fuel economy with his truck.
    I hope this helps in your decision. Please keep us updated. Happy hunting!
    Drew
    Guess the word "just" threw me off. As in the 4Runner would be better if you did more than just that.
    My wife's aunt has a Limited model and is happy with it. The only catch is the step in height is very high.
    -juice
    Yes, the 4Runner's step-in height is a higher than say, the M-class or the Highlander. I suppose it's partly because of its fairly significant ground clearance.
    Drew
    tshadletshadle Member Posts: 38
    Hi Drew,
    I'm cross-shopping the Highlander and the Outback VDC. My primary uses for the vehicle will be:
    1. to drive on beach sand and occasionally through medium-deep snow
    2. enjoy a decent ride before I get to the beach so Part Time AWD is out.
    In the Outback I assume the VDC wouldn't be an issue after reading about Patti of SOA's test-drive in the sand with no problems.
    If I choose the Highlander my best choice would be the V6 with Limited Slip and WITHOUT VSC because of post #477 of 744 Snow and SC by cliffy1 Jan 24, 2001 (10:44 am)in the Highlander Forum, that describes the Highlander stuck in the snow, right?
    Tom
    heatwave3heatwave3 Member Posts: 462
    Drew: can you shed any light on the differences/benefits of the 4wd auto system in 2001 Yukons/Suburbans vs. the AWD in the 2001 Denalis? What are the power biases front and rear in the two systems? Can GM's 4wd auto mode be run all the time even in dry conditions? Do both systems have locking rear differentials or limited slip differentials (or are these different terms for the same thing?)
    Other than the lack of a 4wd low mode in the AWD is there any other reason why one system might be considered better than the other? In a towing application would one system be considered preferable to the other?
    rrmcdonaldrrmcdonald Member Posts: 29
    OK, now I'm confused. I'll admit I am pretty ignorant about these things (not a manly thing to admit, I know!). tshaldle provided a reference to a comment by cliffy1 in the HL section in which he believes VSC is not good in the HL 4WD. I have a chance at a HL with FWD with VSC or at a HL with AWD. Which would be better in wet rainy roads in FL?
    sidsamsonsidsamson Member Posts: 3
    There is a big difference between GM's AWD system and the auto4wd plus true 4WD(hi) and 4WD(lo). Specifically when trying to get unstuck. The Yukon Denali isn't meant to be an off-road vehicle in the true sense of the word, nor is it intended to handle the same towing capacity as its brother vehicles. In reality, the Denali's AWD system might help if you are driving on snowy pavement, but if you get stuck with anywheels either off the ground, or stuck in mud or snow you aren't going anywhere, you'll see the wonderful AWD system spin your wheels, where on a 4WD system when you put your vehicle in 4WD(high or low) all the wheels turn at the same time no matter what. So you'll be able to get unstuck, by rocking the vehicle or just powering out of it. As for better wear on your tires using auto-4WD, sorry this isn't true. Auto-4wd won't engage unless there is a considerable loss of traction while driving, so on turns and during acceleration it won't help. As for gas milage, again the previous statments are wrong. I lose at least 1 mpg when in Auto-4wd vs. 2hi. on my 2001 Yukon. I know because I have very carefully been tracking MPGs. And currently normal driving in 2hi I get 14.2 mpg and in auto-4WD in snowy conditions I get around 12.5-13.2mpg Hope this is helpful. As far a towing, if you notice the 2WD versions of the Tahoe, Yukon, Suburban, and YukonXL all have greater towing capacities than the 4WD counterparts.
    jcorbanjcorban Member Posts: 4
    Drew: This may be a stupid question, but could you explain what low range gearing is? In your excellent post of Feb. 5th you say this is the difference between AWD and 4WD systems. Does it mean that AWD vehicles become 2WD in low gear?
    Jim
    You are correct in your above post about the AWD on the Denali and Escalade. I wonder why GMC didn't use a beefed up version of the TOD system that is used in the Isuzu Trooper. With this we get the advantages of a true T-case, 4wd Lo, yet we get an initial split of torque of 15%f/85%r which varies up to 50/50 based on weight distribution, wheel spin etc. And we can throw it in 4wd Lo for a locked 50/50 split with a standard LSD in the rear. We also have the fuel saving 2wd mode as well.
    -mike
    Jim: a simplified example may be best.
    Let's say you have a AWD vehicle with a 4 speed auto tranny. You have 4 forward gears, with both axles receiving power all the time. There is no low range gearing (not to be confused with 1st or 2nd gear, which every transmission has).
    Compare to a traditional 4WD vehicle with a 4 speed auto. It normally operates with 4 forward gears and only one axle getting power. Put it in 4-Hi, and both axles get power. Put it in 4-Lo, and both axles get power, but you use a different set of gears, all much shorter than normal. So there are actually 8 forward gears, if you will, even though you only use 4 at a time (either the Hi or Lo set of gears).
    Why, then? Because the much shorter gears give the engine more leverage, if you will.
    I took my AWD Forester on the sand last fall, and though it got through just fine (contrary to what many predicted), I could have used lower gearing. The soft sand really eats up whatever torque you have, so a low range would have helped me pull out of deep, soft sand.
    -juice
    sidsamson: The Denali AWD is rated to tow more (8500lbs) than any 2wd or 4wd version of a 1500 Yukon. The suspensions are the same. Is it merely due to the extra hp?
    gpm5gpm5 Member Posts: 785
    So are sidsamson and paisan saying that on the AWD Yukon, the wheel without traction will spin and this system will not transfer power to the wheels with more traction? If the system is designed to transfer when needed I would think it should work offroad, even if a wheel comes off the ground. However, not having 4WD Lo is a problem. Lo gears give more torque out of slippery spots and more control down steep inclines while offroad. On the trooper, 4WD Lo is very useful offroad.
    hung0820hung0820 Member Posts: 426
    Thank you Drew for answering my questions. My Santa Fe is a Full-Time AWD with a viscous coupling centre differential. It sounds good to me? But I still don't know all the benefit of of it?
    That's mean my car will only work 4WD at 3&4 Gear and 2WD on 1&2 Gears? How does the viscous coupling centre differential benefit? Why Did my Manufacture sign said 4WD? Also does my AWD is same as the RAV4? Does my AWD any better or worser compare to the Subaru Vehicles? Is there any after market manufacture build the VSC? Do you think I need the VSC on my car? Please reply Drew. Thank you very much for time and cosideration.
    actually heatwave you are wrong, the 5.3l V8 on the yukon 2wd is rated to pull 8800, and the 5.3L V8 on the 4WD version is also rated to pull 8800 pounds the same as the 1500 series xl. Thanks for playing though. If you looked up your info on this site I can see how you may have gotten this answer wrong seeing that edmunds only show the info for the 4.8L which shows only 6500lbs. towing capacity.
    For the most power the big 8+L in the 2500 series can pull up to 12,500lbs. just in case you were interested, so If towing is an issue the Denali even though it has a more powerful engine, it isn't rated to pull as much!
    sidsamson: You need to check out the facts with GMC versus Edmunds as I believe the manufacturer's specifications are the ones to best make purchasing decisions on.
    All of the figures below are for the 2001 model year. There is no Yukon with a tow rating of 8,800lbs except a Yukon XL with the 5.3L & 4.10 and the maximum tow capacity for any configuration of a Yukon XL is 12,000lbs, not 12,500. Not to get to anal about these details, but the facts may be important to those with specific towing needs.
    The highest 2wd Yukon tow rating is 7,900lbs with a 5.3L and 3.73 rear. The other 3 configurations for a 2wd Yukon provide the following tow ratings: 6900lbs with 5.3L & 3.42 rear, 6900lbs with 4.8L & 3.73 rear, 5,900lbs with 4.8L & 3.42 rear.
    The highest 4wd Yukon tow rating is 8,700 lbs with a 5.3L & 4.10 rear (4.10 rear not available in 2wd Yukon). The other 3 configurations for a 4wd Yukon provide the following ratings: 7,700lbs with 5.3L & 3.73 rear, 7,700 lbs with 4.8L & 4.10 rear, 6,700 lbs with 4.8L & 3.73 rear.
    The Denali has a tow rating of 8,500lbs with a 6.0L, 3.73 rear and AWD. (This is the only configuration.) Consequently, my original statement remains accurate that the Denali with AWD surpasses the tow capacity of any 2wd Yukon.
    For those that may be interested, here are the tow ratings for the XLs:
    The highest 2wd 1/2 ton Yukon XL tow rating is 8,800 lbs with a 5.3L & 4.10 rear. The other configuration for a 2wd 1/2 ton Yukon XL is 7,800lbs with 5.3L & 3.73 rear.
    The Denali XL has a tow rating of 8,400lbs with a 6.0L, 3.73 rear and AWD. (This is the only configuration.)
    The highest 4wd 1/2 ton Yukon XL tow rating is 8,600 lbs with a 5.3L & a 4.10 rear. The other configuration for a 4wd 1/2 ton Yukon XL is 7,600lbs with 5.3L & 3.73 rear.
    The highest 2wd 3/4 ton Yukon XL tow rating is 12,000lbs with the 8.1L & 4.10 rear (sidsamson's figures on maximum tow capacity for 2500 series with 8.1L were also inaccurate). The other 3 configurations for a 2wd 3/4 ton Yukon XL are 10,900lbs with 8.1L & 3.73 rear, 10,300lbs with the 6.0L & 4.10 rear, 8,300lbs with the 6.0L & 3.73 rear.
    The highest 4wd 3/4 ton Yukon XL tow rating is 12,000lbs with the 8.1L & 4.10. The other 3 configurations for a 4wd 3/4 ton Yukon XL are 10,500lbs with 8.1L & 3.73 rear, 10,000lbs with the 6.0L & 4.10 rear, 8,000lbs with the 6.0L & 3.73 rear.
    I hope this info. sets the record straight and assists those shopping for vehicles of this type with tow capacity as an important criteria.
    thor8thor8 Member Posts: 303
    It is a case of two words meaning the same thing, just like a pig and hog, referr to the same animal. Now there are several ways to give four wheel traction or all wheel traction, but that is a technical description. I own an ML430 and a Unimog 406 Mercedes, the Ml has a central diferential that transmit power at a ratio of 48% to the front and 52% to the rear by a system that has some give or elastic, since the intended market is as a daily, luxury, uncomplicated transportation, with open differentials, because the differential pinions can orbit and/ or rotate on their own axis, if one wheel loses traction all the torque will flow to that wheel, it is necesary to stop that wheel, to make the torque flow back to the other wheel with the traction, using the ABS. Another method is limited slip differentials, they have disk or cones clucthes to send the torque more evenly on uneven traction. The reason we have differentials is because when turning a vehicle different radiuses will be created for the wheels on the same axis, the inside wheels turn less than the outside, there has to be some give or compensation, another reason is that tires, even if brand new have diferent diameters, if front and rear traction was 50/50 that small variation in tire diameter will cause shruder and tire wear as they try to mate themselves to the same diameter, affecting the quality of ride as in sligth vibration. The Unimog has on command positive mechanical locks in the differentials and 50/50 front to rear power ratio, but it is to be used on soft ground, where the traction loss or friction will compensate for the tire uneveness and turning radius. If I use this mode in asphalt the vehicle will vibrate, don't want to turn and will scrape the tires so badly that it will leave ugly tire marks all over the road, believe me, we don't want that system in our SUV's. The Unimog is a heavy, slow, strong vehicle to operate off road and an SUV is an onroad vehicle with limited offroad capabilities. Which one is the AWD or the 4WD, both, just different aproaches.
    tincup47tincup47 Member Posts: 1,508
    Land Rovers are very capable off-road, that is what they are built for. They are used by the English military and the U.S. Rangers because of their abilities. The Range Rover, Discovery, and Defender have their differences, but all are among the best production off-roaders on the market.
    resipsaresipsa Member Posts: 5
    What are the disadvantages, if any, of traction control with 4WD? I have also heard some complaints about Skid Control with 4WD- disadvantages of it? Thanks.
    I can think of a few - less fun since you can't wag the tail, the possibility of baking your brakes, or loss of momentum in a race situation.
    Still, in normal driving these just aren't much of a factor.
    -juice
    ripshinripshin Member Posts: 10
    I have to say that you all have done an excellent job of defining and explaining the differences of the various systems. Especially Drew, who seems to be a veritable clearing house of power-transfer information. If any of you are interested, here is a link that gives a great description of the various types of 4WD/AWD systems (in fact, I'm a little surprised that it hasn't been posted yet):
    http://www.audiworld.com/tech/audi.html
    Be forewarned, it gets fairly technical and the author is not a big fan of SUV's. In fact, at the end of that article, he provides a link for another article which is actually a fairly well written analysis of SUV technology. I would reccomend both of these to anybody who has an interest in the topic.
    rip
    Split 90:10 and 50:50 on slippage. That's good. What do you mean by no help in understeer conditions? Surely, it must be better than front-WD alone in the snow. I would think it must be as good as the tribute or the subaru. Yes?
    Any other comments on the T&C AWD would be appreciated particularly in terms of reliability. Not many posts in the Chrysler T&C section.
    A friend of mine is a Chrysler mechanic, and he said the only thing to watch out for was the tranny. Just have it serviced every 30k miles - drain and refill the ATF.
    Automatic Foresters have a 90/10 split much like your T&C, except that in 1st, 2nd, and reverse gears it's actually 50/50. Still, in winding turns it still understeers.
    My manual-equipped Forester is more neutral handling. In the snow I can even wag the tail a bit, and that was true even before I added a fatter sway bar.
    So I'd say the 50/50 AWD definitely feels different - in hard turns, all four wheels tend to drift at about the same point (i.e. less understeer).
    -juice
    Apologies for the lengthy delay in getting back to you. I've been busy and have been putting it off for a while.
    In any case, I think I can appreciate why you are cross shopping the OB and the HL. WRT your question, what kind of sand will you be driving in (i.e. loose, packed?)? The reason I ask is because the Highlander doesn't have an off switch for its VSC (neither does the OB VDC for that matter, but it's activation threshold is much higher) and hence the kind of sand can make a difference.
    When you say medium deep snow, how deep is that? A few inches?
    If you choose the Highlander, I still think the version with VSC would be better because of the stability control system. The advantages far outweigh the disadvantages. BTW, with the way the Highlander's AWD system is set up, it is possible to get stuck even with the rear LSD (if you don't have VSC).
    FWIW, a Subaru rep friend of mine took a VDC onto sand and did all the could to get it stuck, but it kept going. IIRC it was a volleyball court area, which has plenty of deep, soft sand.
    So it seems the VDC's stability/tracion control is not so intrusive, as Drew mentioned.
    -juice
    Did they come to a complete stop and start again? I think that is where the traction control might cause problems since if you are moving and continually pushing it's ok, but from a dead stop you might tend to dig in a bit causing TC to take over. Just a thought.
    -mike
    We actually specifically asked her to try that, and she did. She also did sharp turns, turning while pulling away, backing up, etc.
    I think it's capable of more than any sane owners will ask from an Outback.
    Of course, we're not all sane! %*}
    -juice
    Does anyone here know anything about the 'Rotary Blade Coupling' AWD system on the Tribute / Escape, and how it compares to other systems (such as Subaru's or Audi's)? The website and brohures don't say talk much about it (which worries me a little), but it sounds like a new kind of locking differential.
    Jim
    Are you referring to understeers with respect to a 50:50 split on a different vehicle. I would assume it should not understeer with respect to the front-WD version of the same T&C van but give better overall handling. thanks for the info.
    I had also saw that posted on the T&C site in regards to the regular maintenance. I think that's probably true for all transaxle vans. I mean these things when loaded down are really under stress (I have a '98 Ford Windstar--tranny nightmares from day 1) and are not designed like their former van/truck counterparts that had a rear differential.
    Sorry, but I've never hot-lapped a T&C to be able to tell you how it handles at the limit! Sounds like fun though! ;-)
    I meant among Subarus. The automatics, with a FWD bias, seem to understeer more. The manuals, less so. Mine has a bigger rear sway bar so it's right about neutral.
    The AWD van must distribute weight a bit better, since the drivetrain extends to the rear. With some power also going there, reducing the burden on the front wheels, my guess is it would handle better than the FWD version, but I can't verify that.
    If and when Edmunds Live comes around this year, see if you can make it. We had a hoot last year. There were never any lines for the vans (though we didn't try them), and you were basically allowed to drive as fast as you wanted to.
    -juice
    tomshadletomshadle Member Posts: 11
    Thanks much for the info.
    I'd like to be able to take the Highlander on the beach. Worst case scenario would be loose, deep sand after a long dry spell.
    As far as snow in the Baltimore area, it will vary tremendously. I guess 6 inches is typical.
    Tom
    I know you think the VSC is a great safety feature on asphalt but I'm thinking for what I'm planning to use the HL for, I should probably order it without any extra traction features at all.
    I have the limited slip rear on my Pathfinder but as to whether that's helped on the beach in addition to the locking diff. I can't say.
    Maybe in the future Toyota will include the off switch.
    Tom
    Didn't some reviews with the HL think the traction control interevened kind of early?
    For sand, it may be better without it.
    -juice
    is starting in 10 minutes time. See you there!
    /direct/view/.eea61db
    Drew
    timberwolf4timberwolf4 Member Posts: 3
    Drew - very much appreciate this topic. Given the number of different systems and the use of the same words to mean different things, there is a great lack of clarity leading to mis-understanding.....
    Am interested in your comparison of the xWD systems in the 2002 Bravada and the 2001 MDX. How would you describe them and what do you feel to be the advantages/disadvantages of each?
    Also, for some time Bravada claimed that their xWD system was unique to that model. Is it your understanding that this remains true for the new 2002 models or is the xWD offered on the Envoy the same as the Bravada?
    Unique is always "excludes other GM products"
    The bravada/envoy have a viscous center diffy, similar to the Astro van/safari and the MT versions of the subarus. Constantly tries to split power 50/50 to the front and rear drive-shafts.
    -mike
    hengheng Member Posts: 411
    6 inches of granular snow, grades and bumpy terrain. It was the bumpy terrain that did me in. Once 1 or 2 wheels drop into a dip you are stuck. I couldn't go any faster because it was a forest type trail (on my property). We got stuck multiple times. We did get out of there after a lot of work (I'll spare you the details).
    Question: (just for thought) Is it a workable solution to install locking diffs on each end (driver activated)? Does it even have to be both ends?
    I know the units run about $400 apiece so it is a pricey proposition.
    My understanding is that Olds' system is unique, and Chevy and GMC use more traditional 4WD systems.
    heng: what car/truck do you own?
    The differential itself actually sounds cheap - it's putting them in that is the trick. In this case, I'd guess that labor will cost you well more than the parts.
    Think about yanking out the diffy, probably the exhaust for access, disconnecting the drive shaft, the half shafts, etc. You'd need new seals, so even the parts price would skyrocket.
    IMO, trading it in makes more sense.
    -juice
    tonychrystonychrys Member Posts: 1,310
    heng Feb 25, 2001 3:43am
    If you want "diffs" between the front and rear axles, and between each wheel on both axels, you are basically talking about a JGCL with Quadra-drive.
    http://www.jeepunpaved.com/gr-cherokee/4wd/feature2.html
    bblahabblaha Member Posts: 329
    Were you driving in full time 4wd or part time? In PT, you would have had to lose 2 tires (1 in front and 1 in back to get stuck).
    Locking the differential aids whichever axle has lost traction on one tire.
    One of the more popular lockers is an ARB air locker. Uses compressed air (compressor needed) but a press of a button locks the differential.
    I was thinking of, but the cost and the amount of work Axteixeira points out doesn't make sense to invest. I'm not a rock crawler so maybe keeping cable chains for each wheel is all its worth.
    Don't laugh guys, its just a 2000 Jimmy with open diffs. I'm calibrated now to its limitations.
    At various times during this episode I was hanging 2 wheels. I was even spinning 2 wheels on the same side. Even got it to go sideways some.
    On non-bumpy ground it did great. The same forest track, without the snow is not a problem. So I'm not considering a more capable 4WD, maybe just cable chains.
    rmaddenrmadden Member Posts: 1
    Does anyone know why Chevy no longer offers traction control as an option on the 2001 Tahoe? I heard someone talk about Traction Assist on a 2000 Tahoe. Is Traction Assist the same as Traction Control or are they two different things? I would like to order a Two wheel drive Tahoe with a no slip differential. Does the new Tahoe come with a traditional free spinning differential or a newer version something similar to the limited no slip differential? The car salesman don't seem to know anything about the differential designs. I'm hoping that something is taking the place of the traditional differential since Chevy is no longer offering traction control as an option. Is traction control worth having when you tow a small trailer and for winter driving? Please inform me if you have any information to share.
