over the 04 civic ex was features. pro es has 4 wheel disks- better stereo 6-disk cd, better warranty, and much better handling plus service loaner cars for warranty repairs. dealer even throw in first free oil change at 3500 miles.and there is one` more major option that came standard with the pro es that does not come with the civic es and that is 100% MADE IN JAPAN!!!!
2. Turn the key to on position (not ACC, but ON)
3. Turn the key off and REMOVE it.
4. Repeat the last 2 steps two times removing the key each time. Keep the key out.
5. Press the light switch in the door (that turns the light off when the door closes) three times.
6. There should be a chime similar to when your seatbelt is not fastened. (Mine did not chime but the door locks went down)
7. Press the lock button on your remote two times.
Let us know if it works!
Dinu
Where can I buy accessories for the best price? Cargo net, cargo tray, etc..
So far the only surprise has been the maintenance requirements being more extensive than I expected. Maintenance is required more often and looks as if it may be more costly than the maintenance on my VW Golf TDI. The much lower purchase price should balance out the maint. cost.
http://www.mazdastuff.com/
http://www.finishlineperformance.com/
http://www.mazdadiscountparts.com/
http://www.trussvillemazda.com/
Maintenance is pretty cheap on Mazdas in general compared to the Jeeps and VWs I have owned in the past. I hope you enjoy your new Protege.
On the other hand, if you drive mostly freeway miles with little congestion, then you can probably go for longer (5000 or 7500 miles).
I drive mostly short trips. But I change my oil and filter every 5000 since I use synthetic oil and use the larger capacity filter.
Other than inspecting some things every 15000 miles, the only major items I recall are timing belt change (or inspection, depending on your state) every 60000 miles and replacing the coolant and transmission fluid every 2-3 years, battery at least every 4-5, plugs every 30k etc. Those hold true for pretty much any vehicle (I don't believe the 100k tune-up intervals some makes advertise...I think it'd be pretty tough to remove plugs that have been in an engine for 100k miles...and I've used platinum-tipped plugs in the past and found almost as much wear on them when changing them as the "regular" plugs...so I've switched back). I think they're betting on most folks trading in or selling or returning (leased) these vehicles before they reach 100k miles.
I'll start.
2000 ES 5-speed.
63,000.
Zero.
Meade
2003 Protege5 (Auto/SAB)
11,000
Mazda Auto-Dimming Mirror replaced 3 times before they found one that worked. This was the dealer's fault for not testing it before they returned the car to me.
Ted
Zoomster had to have been confused, feeling like he was zooming down the highway while his wheels weren't turning.
Both Zoomster and ZUMNMOM (Tammy's P5's vanity plate) weathered the storm with no ill effects, even though their undercarriages served as a popular gathering point for all manner of arboral debris! Thank God everyone put their big 'ol green Supercans in their sheds as the county suggested; I would've loved to see one of them come tooling down the street at 50 mph!
I've posted some pics of the hurricane's aftermath at my home south of Richmond on the Yahoo group, along with a much more lengthy description of what we went through two weeks ago tonight, if anyone's interested. Much of it is not related to Proteges, naturally, so I'll refrain from getting too verbose here. Thank you to everyone for thinking of us during IsaHELL!
Meade
67-68K kms
CD Player replaced - ate my Sandstorm CD (:
Spoiler LED had 3 lights out
2 rear right tail light brake lights replaced
all "chrome" Mazda, logo, Protege badges replaced due to a little chipping on them
That's it. Not real problems if you think about it. Mostly me being anal about having a perfect car (see the badges) The rest were fixed w/out fuss by my dealer.
Gotta love the PRO!
Dinu
Interestingly enough, in 3-1/2 years of ownership, I have had not one bulb go out on me. Not even the dome light.
Dinu, just wondering -- how did you chip those badges? Also, concerning the spoiler light -- I've wondered about what to do if/when any LEDs ever go out in mine. Did they just replace the whole light assembly, or are the LEDs replaceable separately, or what? Come to think of it though, I've never seen an LED-equipped spoiler light on any car with any LEDs out. Whatcha doin', shooting the high-pressure self-service car wash wand directly into it or something?
I have noticed one thing that unfortunately is not covered by the rust PERFORATION warranty -- something you guys with spoilers might want to check out. Under the trunk lid there are four torx screws -- two on each side -- holding the spoiler to the trunk lid. I've noticed that one of those screws (on the right side) has some bubbles forming around it under the paint on the inside of the trunk lid, indicating rust is starting there. I've done this kind of repair before and it isn't hard; I just have to remove the screw, put the wire brush on my drill, sand down the rust to the bare metal, reprime and paint the coin-sized area, and reinstall. Had to do the same thing on a much larger scale around the right rear light assembly on my '78 Corolla back in 1985. I was very impressed how my handiwork came out at age 20!
Meade
As for the badges, they were all chipped. Either showing minuscule rust spots or faded like some acid or bleach was spilled on them in droplets. Very tiny, needle point-sized rust in the middle, then white discoloured "chrome" around it. Not too noticeable, but it NEEDS to be perfect The new ones are OK.
Dinu
35,000 mi
CD player replaced.
No other issues.
31k miles
cd player fritzy at times
door lock cover plate broke off, stuck in keyway
buzz in dash [someday i"ll find the damn thing!]
difficult to drive slowly
Currently 45250miles (or thereabouts).
When new, the steering wheel was off by about 15 degrees. Fixed under adjustment period warranty.
Driver-side plastic door lock flap cracked and fell in. Replaced driver and passenger door lock cylinders with new ones with metal flaps under warranty. I now use the keyless entry remote; batteries are cheaper than lock cylinders since my car's out of warranty.
CD player stopped playing CDs this past spring. Replaced it with a JVC SX-780, which makes even better use of the aftermarket Pioneer speakers I installed. And I can plug in my iPod for long trips too.
AT sometimes "stumbles" when accelerating after coming to a brief stop or a crawl. I can manage around this quirk by pausing a little longer before accelerating, but still annoying.
Other than the issues above, no problems. It's been a blast to drive too, especially after adding the strut tower bar.
I have noticed on the road that alot of Proteges have burned out taillamps, the top part of the taillamp only though. Anyone notice this?
These plugs had platinum on the center electrode and the ground electrode. They were $12/each to replace, so I went cheap and replaced with NGK coppers.
I had also heard the horror stories about plug removal at 100K, but I had no such problem. I changed them first thing in the morning, when the engine was cold and they popped right out.
I'll probably stick with the coppers for the next 100K.(@30K intervals)
Dinu
The regular plugs are cheap enough that you could replace them every 15,000 miles and still spend WAY less money than replacing platinums at 100,000. I have never burned up any spark plugs, they are always pretty close to stock gap when I replace them. Now, if the plugs were a pain in the [non-permissible content removed] to replace, I might be more willing to use platinums, but the Protege's plugs are easy.
As far as burned out light bulbs are concerned, I haven't seen a 99-03 Protege with a burnt out bulb. I haven't really noticed any newer cars that have a high percentage of burnt out bulbs except for VW/Audi cars. I've seen TONS of those cars with burnt out bulbs.
German cars in general seem to have a lot of burned out lights. Older Celicas, LS400's, and Camrys used to seem to have a lot of out tail lights.
My parent's 92 Camry didn't burn out any bulbs in 11 years. Unbelievable.
Getting to the plugs was no problem...Once I removed all the pretty covers and intake piping.
Originally I just didn't want to fuss with removing the lamp housing, but having done so I can say that it is very easy to do for those who might want to change any of their rear lamp bulbs. Simply remove the three brass-colored nuts. However, besides those nuts, there is a little hidden plastic "snap-into" socket that requires you to give the lamp housing a bit of a tug to free the housing (that socket is not mentioned in the owner's manual).
I truly believe that back-up alarms should be standard equipment on all vehicles. It can save lives.
Dinu
Well, I believe it is cheaper to maintain a vehicle than it is to repair the same. True?
Every 5,000 miles:
Oil & filter change
Rotate tires
Every 10,000 miles:
Replace air filter
Every 30,000 miles:
Change Transmission oil & service
Antifreeze/ coolant replacement
Replace spark plugs and wires
-Larry
I have seen a couple Jettas with burned out taillamps myself actually. And headlamps seem to go on Golfs and Passats alot too.
As far as plugs, they must be hard to change on the 1.8t motor. VW told me it would cost $170 to change them at 40K miles for me.
Tuesday nights - 6-7pm PT/9-10pm ET.
Meade
Mazda Maniac
"An even smaller Mazda2 may also turn up. This is said to be based on the redesigned replacement for Mazda's Japanese-market Demio, a tall-body mini-minivan with 4-cyl engines in the 1.3-1.5-liter range. No word yet on timing or even whether the idea has Ford's blessing, but we'll keep you posted."
Please do!
Meade
http://carpoint.ninemsn.com.au/reviews/reviewstory.asp?id=5382
Meade
Differences
1. Compression ratio 10ish:1 as opposed to our lower 9.5-ish:1
2. Different (high pressure) pistons
3. Tuned (timing etc, combustion advanced (retarded?)) for RON 95 or higher.
MAJOR difference: 10-15 more HP and 10-15 more lb-ft
They toned it down for the US 2.3 to keep it a regular-sipping car. I, for one, would have paid the premium (for premium!) to get the Euro/Aussie/Asian engine
The only issues people seem to dislike are that they shortened the trunk overhang to make it smaller than the 6 (makes sense, it is one size down!) and the bulges (fenders and hood - which I LOVE)
If I had waited, I would have had a super tough time deciding between the 3 Sport Hatch and the 6 Hatch (which will only come with the Sport Package - so we may as well call it a Sport Hatch as well!)
I now have Yoko Avid Touring - MUCH better.
Dinu
