Jeep Owners Care and Maintenance
How do you baby your Wrangler? Any maintenance issues you would like to discuss?
KarenS
Owner's Clubs
KarenS
Owner's Clubs
Basically all it does is use a series of high pressure water streams, what about the detergents these washes use, are they too harsh for the soft-top or windows?
On a related note, I saw the results of a disaster in a touchless car wash: the arm mechanism that moves the jets from the front to the back jumped the track and got moved close to the side of the car. The pressure was forcing the jets up and down, up and down. SInce the arm was now too close to the car, the jets housing proceeded to grind away at the side of the car until the wash stopped. I saw this at a body shop and couldn't for the life of me figure out how the marks had been made. The shop manager was laughing the whole time while he was telling the story. He said the owner couldn't get out to stop the wash and had to sit there in the car for another 60 seconds while the machine chewed a big slot in their car. You have been warned.
My suggestion if it is too cold to wash by hand, but you want to knock the mud, salt off the car... Go to the do it yourself spray car wash. You can stand further away and you can avoid the soft top altogether.
-twylie
I will hand wash her, take her somewhere to have her hand washed when it's too cold for me to do it myself, or, possibly, use the do-it-yourself spray wash.
tsjay
have you hugged your Jeep today?
i couldnt resist eaither..
I have heard all kinds of philosophies about the best way to break in an engine. One extreme is to explicitly follow the owners manual, and the other is to put the petal to the metal on the way home from picking up the new vehicle.
I have always used a middle of the road approach.
I don't abuse the engine, but I don't baby it as much as the owners manual says either.
I drive up to 75 MPH in the first 500 miles, but I don't hold that speed for real long stretches. I think it is good to vary your speed, like it says in the owners manual.
I wind out the gears a little once in a while, but nowhere near red line RPM's.
All I can tell you is that I have had a lot of new cars and trucks (way TOO many), and I have had good luck with my technique. I have never had a bad engine as a result of my break in method.
It basically boils down to driving the vehicle during the break in period about the same way you plan on driving it in the long run, with the exception of varying your speeds for the first few hundred miles.
tsjay
Have you hugged your Jeep today?
Two questions: What size wrench do I use on the filler plug, and why does that filler plug have "do not remove" stamped on it?
KarenS
Owner's Clubs
Rahul
It's true that Jeeps have their own peculiar set of problems, but then, so does everything else out there on the road (or off-road).
Sometimes you need to take what you read out here for what it's worth. I'm a JGC owner and if you looked at and believed all the posts on this vehicle, you'd never own one. I've been very happy with the 4 I've owned since 93. No, they haven't been entirely problem-free but they've never broken down and left me stranded anywhere either.
To me, getting stranded by a breakdown speaks a heck of a lot more for reliability than reading complaints about the annoying little things, which all vehicles have. If you have your heart set on a Wrangler then go buy one! Sure, you run the risk of getting a "bad" one, but no more of a chance than anything else that's out there. Don't let that stop you from driving what you like and having fun with it. There isn't a more capable off-road vehicle out there than a Jeep!
I consider the TJs to be reliable. I think you should be more concerned about the truck-like ride, wind and road noise, and small storage area and other unique things to Jeep Wranglers. It doesn't bother some people for everything else they get out of it, but others can't put up with it.
After viewing this message board and many others, I am having second thoughts.
I see reviews of many people having problems.
What are the major problems to watch out for?
Are most repairs covered under warranty?
They don't even look the same as a conventional older spark plug wires, plus they are underneath a special square looking cover which has 10mm nuts securing it down on the plug...Not too bad a job, but you just have to remove a few things to get to them, without doing any damage to surrounding components, and electrical connectors...
Question now is, is it worth saving the $70.00 to do it myself?
Overall, I am very pleased with the reliability of my 97 Wrangler, wouldn't trade it for anything. If you know of a good mechanic to make sure the fluids are changed on schedule or better yet you can do it yourself, I don't think you could find a more reliable vehicle. Especially one that is so fun to drive.
By the way, the folks who questioned the wrangler's reliability, did they actually ever own a jeep?
I've got a quick question I was hoping to get some help with...I've got a 01 Sahara and I recently noticed the thread (seam) above the zipper on my side window is almost completely unraveled At this point the window is only being held up by the zelcro!! I'm so bummed!
What's my best option to get this fixed?? Should I look into getting a new soft top or can it be rethreaded?? Does anyone know how much that would cost...and last but not least how to I keep this from happening again????
Thanks so much!!!!!!!!!!
d
ChrisCOug
i have had it at the dealer all they did was replace the relay and charge 200 bucks
it worked for 2 days and then blew again
when i took it back they wanted to charge me 300 more to replace the blower mtor(which is not the problem) and i still do not have a/c
does any one know where to purchase the relays and what could make them go out?
I would check an auto parts store for the relay and if they don't have it, go through your dealer's parts department and install it yourself.
thanks so much
I have a 2005 SE with 537 miles on it, and I've noticed that the 6sp manual-shift transmission makes an intermittent ringing noise when my foot is NOT on the clutch. The slightest pressure on the clutch makes the noise go away. It sounds rather a bit like crickets chirping. Incidentally, I crawled part-way under the vehicle when it was making the noise and it is not engine noise. It's coming from the left front side of the transmission.
I know that a similar noise made by the transmission when the cluch pedal is depressed can indicate a failing throw-out bearing, but this noise eminates in the inverse circumstance. At any rate, I can't believe a throw-out bearing would make noise in a brand-new car.
The vehicle is returning to the dealer for a center console installation tomorrow, so I'll ask then. I'm just curious of any of you have had the same/similar problems.
I know quite a bit about performance automotive mechanics, but that knowledge is usually applied to 40+ year-old cars. These 'new-fangled' machines are a bit beyond my range of experience. Heck, I couldn't even find the shift fork on this monster.
Thanks for your input!
Will Seberger
2005 Wrangler SE
Beryl Green
Not a dumb question at all. Assuming you have the 5.9, you may have an electric cooling fan (the one up front by the radiator) instead of a mechanical clutch-type cooling fan. That is the one I was referring to.
This repair gets a little involved so you might want to think about a Jeep repair shop.
I've never had this problem on my Jeep (but then, I've only had it for 2 weeks). My old GMC had this problem frequently, however.
The first time it happened, it was a partially seperated tire tread. Remember in the mid 90's when tread seperation was causing Explorers to roll over? This is the same problem, just a different brand of tire. You should take your Jeep somewhere to have the tires inspected.
Another time, it was a worn control arm (suspension component that essentially holds your wheel on) in the front suspension.
Of course, it could be another mechanical problem. Whatever it is, you should have it serviced.
And remember, in defence of being overcharged or under-serviced, ask to see any parts that were replaced (the used parts they took out) as well as a breakdown of what's on your bill. Believe it or not, dealership service departments are not out to screw you as much as they used to be, because service has become a mainstay of Chrysler's (Jeep's) income. They literally can't afford for you to go somewhere else for service.\
Additionally, I'm not sure how long they've offered the X model, but it may still be under warranty.
I hope things work out well for you.
