I figured that was the case, but could not find it listed anywhere. No need to, just noticed.
Anyway, took a major trip today to pick up a boat. Spent $89 for gas for a 200 mile trip and ran out of gas. Carried a spare gas can and made it to a gas station. Got home and noticed a steady stream on the pavement when I was backing the boat into the driveway. Major gas leak but only when engine is running I think. Is it the fuel line? Something a shade tree mechanic can do or is this a "dealer special"? thanks for the help!
www.e85fuel.com
Hope this helps.
I have seen transmission "specialty" shops (no names, but you probably have seen their ad's) tell customers that their transmissions have "problems", and show them this grey / black powdery goopy stuff that was in their transmission bottom pan. Realize that unless there's something else going on, or if there's really a ot of this stuff in there, that some of this stuff is normal clutch wear material. I'm guessing (just guessing, based on years of ownership of multiple types of automatic transmissions) that if there's no more than, say, a level teaspoon of this stuff in the bottom pan of a "typical" transmission, it's probably normal wear for a few years. Maybe three. I think I would suggest changing the fluid and filter every other year if you drive it hard, or maybe every 3rd to 4th year if it's not driven too hard. Just a guesstimate. I know some people who have never changed AT fluid and filters in 100,000 miles and have no trouble at all. go figure. Then there's the rest of us... Hope this helps.
Just an idea you might wanna try.
You can e-mail me if you were able to find out what it was.
Ron
Want to see what I can do before I take it to the shop.
If so, it's coming from the mass air flow. I've got the same problem and a mechanic told me to change the TPS (throttle position sensor) and the idle air control. I haven't tried to yet. The parts will cost you about 80 bucks total. I work at a parts store so it's all good. Just to busy working on everyone elses stuff instead of my own. Hope that helps ya out a little.
Caddis295 :confuse:
It can probably be taken off and cleaned with carb cleaner.
It has electric solnoid on one end, and medal valve on the other. DO NO GET carb cleaner into the electrical end!!!!! It will eat up the windings!
Just clean the valve part. Be carful removing and do not tear up the gasket under it.
Good Luck and hope this helps.
David
you need to check and see if there is a crank sensor on your truck. This was happening to me quite frequently with the same result from the mechanics. Someone suggested this to us, we replaced it, and its fixed.
David
Different subject altogether, but thought I would mention it. In addition to my '98 Ranger, we also own a '98 Explorer. On both vehicles, the heater blend door broke, which means you either have full heat or max air conditioning, with nothing in between. The blend door is $45, the labor to replace it is about $800, as the dash has to come out. This is my only real complaint about either vehicle.
I went to Braves game and the truck stalled out at an intersection, and just became lethargic with no power whatsoever... It's an automatic, and I didn't think it was possible for one to stall out... It also stays constant at 4000 RPM when going above 50 MPH...
I was told by a friend to have the catalytic converter checked that it could need replaced... There ARE 84,000 miles on this baby!!! I took it to the dealership and they looked it over, ran diagnostic tests and the best answer they could create for me was "Oversized tires are killing my gas mileage" "I need to speak with someone in parts to order new tires, and a matching spare" I can't even change my own oil, but I'm pretty sure that entire story was a line of figmented imagination!!! needless to say, I am not very entertained... WHAT COULD ACTUALLY BE GOING ON WITH THIS TRUCK...
How difficult is it to obtain a new idler pulley assembly and install? What steps are required to replace? ls it necessary to remove the radiator?
Pulling codes at service center cost more than part at NAPA.- $20.00!
no problems w/ hot starting and weather has been in 90's all week. Part is readily available in aftermarket so that suggests it's failure is common.
hot start or cold start replace ETC sensor.
The engine turns over fine, just won't start. No check engine light. Doesn't matter if the radio or AC is on or off, transmission in Park or Neutral. Seems like there is no gas or spark. Until this morning, I was thinking fuel pump problem. After reading posts at several sites I can't narrow it down. OK, to add a little spice to the problem, when trying to start the engine, both door locks will intermittently open and closed. Like an electrical problem, chip or relay resetting itself or possession by an evil spirit!!! Freaky man!
Solution???
Gregg
1995 Ford Ranger XLT Super Cab, 4 X 4, 4.0L, 1 year old battery, wires and plugs about 9 months old
