I been shopping for a good used Ford Ranger, mostly in the paper & the craigslist. Anyways... I have seen alot of ads claiming low mileage for example '93 super cab w/48,000mi. Maybe....really 148,000 so just to save me some ground work.
Thank You, Sheri
Hey, are you one of my ex-wives?????
That was my nickname for her.
I don't know when they started, but my 1994 has 082357 miles on it.
I also would like to do it myself, if it is not going to be too hard.
The fuel filter is usually on/beside/etc the frame, just about under the driver's door, or slightly forward. There may be bracket or cover to be removed.
Gasoline will come out when the filter is removed. Do not do this inside a garage. Sometimes, due to a siphon effect, gas will continue to come out even after the pressure if relieved from the line. I sometimes take a pencil and push this lightly into the fuel line to stop the fuel. Or buy dowel rod the size of a pencil, cut some lengths, and sharpen these in a pencil sharpener.
my ranger is 2000 3.0 v6.the flex fuel engine was standard that year.is it still available?.
Tried jumping battery,. etc. Will not turn over. Tried replacing battery. Still will not turn over. Help.
It continues to do this. I have checked fuses and they seem OK, everything else works, just the radio has lost power, total loss, even the clock doesn't come on.
Its a 1994 ranger XLT 4x4, 6 cyl 4 liter, standard trans, very vanilla truck. Hope someone has a simple fix for this annoying problem.
Sounds like a Nice truck, only one problem...I live in Oregon. Darn !
Thanks, Sheri
JR in Dallas
Many times that can be a known ranger problem that either the MAF sensor needs cleaning or replacing.
My apologies if this has been addressed already and hope it helps.
When ever I accelerate on the freeway, particularly when going up a grade, the engine sputters and completely looses power, and acts like it is not getting gas.
I have replaced the Plugs, Wires, Fuel Filter, Fuel Pressure Regulator. and Fuel Pump.
I have replaced the O2 sensor recently.
I'm thinking, could it be EGR?
It does it on acceleration. When I hold the pedal at a certain place, at lets say 60 mph, or around 2500 rpm, it will come and go, but it always happens under a load.
Regards for all :confuse:
I noticed a strange thing that the "tree"where all of the Vacume lines go, (I don't know what to call that part)Well according to the sticker on the inside of the engine compartment, the vacume lines are shifted over one "branch."
But if I pull the rubber "boot" and shift it over, the boot doesn't fit right.
I'm thinking that really doesn't matter, as I have seen it positioned that way on another Rangers.
A plugged Egr would usually show vacume if you disconnected the hose, mine does not .
But, the Egr does turn, I think it is broken off it's base.
I have sprayed it to see if it is sucking air and it is not.
I just bought a conversion kit that changed the points to electronic.
The truck ran great for about an hour. Then went dead and won't start back up.
And I noticed the coil got hot. Can any one help me?
Oh and originally the truck had an electronic dis.
But the truck was from Calif.and couldn't be ajusted. Thanks for any help.
I worked on my truck for a couple of hours yesterday and had great results. I bought a can of SEAFOAM and a can of electronic component cleaner at a NAPA store. I also bought a gasket for the throttle body. I removed the air intake assembly and the throttle body. I sprayed the throttle body inside liberally with the SEAFOAM, getting the butterfly very well. I let this sit for a while so the SEAFOAM would set in. I used a lint free cloth to rub the throttle body clean of all the buildup. While the throttle body was off I sprayed SEAFOAM into the intake manifold.
I disconnected and cleaned all the connectors to the fuel injectors, TPS, ignition coils, and practically any connector associated with the ignition system (male and female) with the electronic cleaner. I also sprayed the MAF sensor with the electronic cleaner. I found an oxidized intermediate ground connector at the coil pack. I used a file to clean this one first and then cleaned it with the electronic cleaner.
I reassembled everything.
The SEAFOAM says to find an intake vacuum hose to spray in while the engine is running. I had a buddy with me, and he sprayed the SEAFOAM into a vacuum hose that went into the intake manifold while I revved the engine between 750 - 3000 RPMs. Alot of smoke was emitted from the exhaust. It is normal when there is alot of buildup.
I let the truck sit overnight and when I drove it the next day, I swear, it was like driving the truck when it was new. No more surging or idle problems. I don't know what exactly fixed the truck but those are the things I did. I am so pleased with the way my truck is running. What a difference!
I wish I had done that first. If I were a pro I would have.
It gave me 3 codes.
#1 was the code for the maf sensor, so I replaced it.
#2 was for the TPS, so I replaced it.
#3 Was for the secondary fuel pump circuit.
In checking in the Haynes book, I found out that the problem could be the Fuel pump relay.
Looking in the book there is no relay pictured.
Looking on the internet I found out that the relay is located UNDER the "Breaker Box" under the hood.
I replaced the fuel pump relay....VICTORY!!!!!! http://a332.g.akamai.net/f/332/936/12h/www.edmunds.com/media/townhall/webxicons/emotorcons- /emo_smiley.gif
smile
Someone also mentioned a high piched noise coming from around the air filter. I get that too but it comes and goes. When it is there I only hear it when idle or low speeds, once I get going it usualy goes away till I stop again.
Any ideas or further comments on either issue is appreciated. :sick:
95 Ranger XLT supercab, 4.0L
I have a 93 ranger 2.3, 5 speed.
for the last couple of years, in warm weather usually will not start after warmed up.
will get me to and from work, if I have to stop somewhere leave it running.
3 times now it dies while driving, have to wait 10 to 15 min. then it will start.
Saturday I changed ETC sensor. and it has started everytime since, even after 50 miles of alot of turning it off always started. But this morning on way to work it died let the clutch back out it finally started, made it to work. ran fine all the way home, turned it off and restarted.
new sensor might have fixed that problem, and dying could be another
any help would be great
THANKS
Is this an engine problem or does it sound like the transmission? The last time I had this much power loss it was the transmission (that car was '79 Honda Civic), so I'm not sure if that incident is applicable here.
Lastly, do any of you have advice about mechanics who you can TRUST? The last city I lived in I really trusted my repair shop; they weren't the cheapest but I knew they weren't trying to rip me off either. I know the techs need to be at least ASE (I think that's the certification) certified but that's about all I know.
Any advice would be greatly apprecieated on these subjects and thanks in advance for the advice.
Sincerely,
Wayne
The check engine light was related to something totally different though. I dont remember the shifting being real jerky but it wasn't as smooth as it should've been. When they looked at the transmission they found metal shavings and had to replace the transmission.
Try this. Supplement the ground connection directly to (at first) the trailer ground by running a relatively heavy wire from it directly to the battery negative post. If the trailer frame is the trailer ground, you might be able to do this by using one or maybe two automotive jumper cables directly from the trailer frame to the truck battery negative. If the problem gets better (might even go away!) that's it.
You can supplement the radio return directly to the truck battery in the same manner. This requires taking the dash panel out and doing a bit more wire-running, but will also re-direct any return current right to zero. You can also try to make a measurement to possibly see the unwanted drop... measure the voltage on the radio housing (negative ground) with respect to the battery negative post. Should be very low; under 0.5 volt under all conditions. If it gets worse (goes UP) when you put on the brakes, that's it.
If any of these tests show improvement, or the measured voltage rises in a voltmenter test as described above, the ultimate repair is to (most likely) supplement one or both return ("ground") paths permanently. I have used about a 6 foot piece of #10 THHN (oil-resistant) wire with a lug on the battery-end and a lug on the radio-end. The radio-end I bolted to the 1/4" hole in the dash bracket immediately to the right side of the factory radio location; you'll see the hole if you remove the factory radio and radio dash panel. Good luck.
Jay
To answer you question, the slave can be changed without changing the clutch. The dealer claimed that since the cost of replacement was mostly labor, I should change the clutch too.
Bottom line is that I believe that the material is defective. The after market has the part for $30. Looks like to drop the trans, the floor cover must be removed, the cross member unbolted and dropped, head pipe unbolted to pull the trans. I am going to do it myself and then sell the truck. My daughter recently bought an F-150 with a manual trans and on inspection I found the same part number on her slave.
NO MORE FORDS FOR ME! The son-in-law who owns a 1 yr old Chevy full size short bed with I think a 5.4L V-8 gets the same mileage around town 17mpg.
Hope this helps.
changed the egr valve soon after because I had a code. new plugs and wires also.
so far has started everytime, since new etc sensor. and didn't die on me today goin to or from work, but I'm sure I'll see that again soon.
any other Ideas?
