Thinking it was a vacuum leak or broken line I searched under the dash then then under the hood. I did find 2 burnt lines which were not connected to anything under the coil. However, I can't seem to figure out where they go. I searched everywhere. Could this be the reason I only get air from the defrosters and if so does anyone
have any idea where the 2 lines connect? Thanks...
I can't describe exactly the problem, with correct names, but here is my best try.
The post on one of the 'air control' flappers (or the post on the control rod that moves the flapper) in the heater box is broken. It is plastic, and it just breaks. To repair, the dash must be removed to get it out. And the part (I think) is part of the entire air control set of flappers ( usually 2 or 3 'flappers') - it must all be replaced. Big money. $1,000 or so.
If you are mechanically handy, if you look on other Ford Ranger sites, there is a documented 'work around'. It is pretty messy, involving drilling a hole through the broken shaft and inserting a pin, or something like this. Not really sure about this. But it fixes the old part and don't have to buy the entire air assembly.
Good luck. If this is your problem, you have quite a problem to get it working correctly again.
I had the exact same problem with my 99. They would usually break free but the last time resulted in a trip to the shop on a flatbed. The problem is a seal on the rear hub that is prone to leaking. The folks at Utton's Mufflers (802) 229-9005 in Montpelier Vt are familiar with the issue and can tell you exactly what the problem is.
MP
Good luck,
MP
Any ideas??
Louis
Use a steel brush or something like this, and then coat with the special brake grease.
Also, if these calipers have 'pins', be sure to grease the pins when you put them back in.
Why would you want a vehicle that has a name that means "steer clear of"? :P
That's meant solely as a warning to pedestrians..... :P
This is most likely a bad door switch. ford hid them WELL in the 98 models, so I can't suggest where it's located, but if you can find it, replace it. Also, let me know its location, my sister has a similar problem with a 98 Mercury (Ford) Sable, but i can't locate the switch
My '94 Ranger failed to startup recently. After some debugging work, I found out that the fuel pump is not turned on during startup. The fuse is fine. I can also make the fuel pump running by jumping a wire directly to inertia switch. So the problem must lies somewhere in the circuit between the fuse and the inertia switch. I have a Haynes Repair Manual but could not find any wiring diagram about the fuel pump. Does anyone know how the fuel pump is wired, or where I can possibly find the wiring diagram? Thanks in advance!
The switch is inside the doors. It is near the lock itself, not the hinges. Some people have luck spraying WD40 or Electrical Cleaner through the lock or through the outside handle.
Best way is to remove the door panel and actually get to the switch. Clean it or replace it.
This isn't normal on any car, I would look at something else. I own a 1994 V6 Ranger, 5 speed maual with no such issues
This will then likely apply to the situation I have with the Sable. Thanks
Check the fluid level
You may have to get a steering wheel off an newer model or an aftermarket replacement, since a horn switch isnt built into your steering wheel. Then you will have to re route the switch wire(s) to the steering wheel's horn button
Yeah, I guess if you're walking toward one, it would be a good turn toward a ford. :shades:
http://www.suspensionconnection.com/
Recently, I did notice a low-pitched whining noise on cold mornings before the truck has had time to warm up. I took it to a local mechanic who is a friend of mine. He suggested that with the number of miles the transmission oil probably needed to be changed. I had him change it and so far I haven't noticed the sound anymore.
http://www.therangerstation.com/tech_library/bleedclutch.htm
Thanks for the help!!
