Chevrolet Impala Accessories & Modifications
Greetings all,
At the end of May I will be taking delivery of a 2001 Impala LS, Navy Blue, all options except sunroof, leather, and on-star. I can't wait!
My questions are regarding the stereo. I have a complete Alpine system in my '98 Lumina. I plan to leave it in when I turn that car in. Of course, I want to do upgrades to the factory system in the Impala. So here are my questions.
1)Am I correct in assuming that I'm pretty much stuck with the factory head unit due to the "vehicle customization" feature?
2)Has anyone upgraded the factory speakers or amp? If so, what works well?
3)Has anyone installed a sub? I don't want "boom boom" as I drive down the street, but rounding out the low end makes a big difference to my listening pleasure.
4)Is there a way to direct wire a CD changer into the factory head unit, or will I be limited to FM modulated?
Any other pointers or advice would be helpful.
Brad
Brad
I was planning to get the "dual playback" CD/Cassette (option UPO) with the upgraded performance speaker system with amplifier (option UQ3). But I still want a CD changer. I've had one for the last 10 years and I refuse to go back.
Here in Canada there's no option for the Remote CD Wiring Harness, so I'm in a bit of a quandry. It would be an easy decision if there was that option. I'll check with the dealer when I go to order the car next week. I'd rather not do the FM modulated route - I've done it before with only moderate success. I was much happier with a proper direct wired changer. Then again, if I go with the CD/Cassette and an FM modulated changer I would have the capabiltiy to play single CDs in-dash and a bunch more in the changer. Maybe that's not such a bad thing.
Before someone says it, yes I really am a freak about my music!
Brad
There is a whole board on the IMPALA RADIO here at edmunds.
Most of your questions can be answered there.
Suggestion:
Since you are a self-acknowledged "freak" about your music,
Take a CD and a cassette that you know well to a dealer.
Play them both in various IMPALA radio- tape -CD combinations and see what you like.
Some people have been very happy with their factory systems - untouched.
I was not.
I have the US version with radio-CD-tape. It came with a CD harness for a trunk
changer as well. It's still hanging in there just behind and above the right rear wheel well.
I'll bet that CD harness could be ordered on the net if nort already installed.
I bypassed my trunk amp in June 2000 and have been very happy with the results.
I didn't realize there was an Impala Radio board. I've read a bunch from there and I'll re-post my (revised) questions over there.
Brad
I also have the radio/tape/cd setup and wanted to add in a CD changer. I didn't want to go to the FM modulator route. I like my steering wheel controls too much.
I am away from home at the moment in Texas and have been calling around looking for a connector that will fit the amp harness. Hopefully I can find one so we can replace the factory amp with something better.
Tail and Brake lights for a trailer hitch - not likely.
Power antenna? Too many wires.
My plug appears to have 7 wires running into it. That would seem about right for a changer.
power(1) controls(2) and L & R audio out(4). NOTE: THIS IS A GUESS.
As I wrote in post # 10, my best GUESS is that it's for a CD changer.
What's your best guess?
(Far left) pin 10 Gray wire Audio Class 2 Serial Data. (moving right) pin 9 and 8 unused. Pin 7 black wire ground. Pin 6 not used. Pin 5 orange Battery positive. (break) Pin 4 bare drain wire. Pin 3 Lt Blue Remote playback device audio common signal. Pin 2 lt green remote playback device right audio signal. Pin 1 orange/black remote playback device left audio signal.
Hope that helps.
Duraflex are you a gasket guy?
Thanks for posting the wiring info.
FYI: You can revise (EDIT) anything you write here within 30 minutes of posting it.
Number 17 was in that window of opportunity.
What is a "helm manual"?
Still wonder what the other one is for. Mediumfry, can you look it up?
http://home.hawaii.rr.com/impala/Mystery_connector.html
The Helm Manual is the "GM Shop Manual" that the dealers use. I'm a firm believer in getting that book (the one for the Impala is actually three volumes and covers the Monte Carlo too, over 2000 pages). It's better than Haynes or Chilton, for instance, because it's for one model and one year only. It has specific info like pin-outs and placements of all plugs, wire colors, harness locations, component replacement instructions, component rebuild instructions, trouble code definitions and diagnostic flow charts, everything imagineable. It also costs a hair more ($120 for the latest one) but over the life of the car it pays itself off over and over again. Plus, I got the dealer to buy it for me when I bought the car...bonus! Anyway, Helm inc is (I believe) the publisher that prints manuals for all manufacturers. They definitely handled the book for my Plymouth mini-van and I haven't tried to buy a Ford book.
Night Owl, I'll look in my manual and see if I can figure out what the connector "B" does. Hopefully I can post that information this evening (I'm in the eastern time zone).
Sure enough, the connector "B" in your trunk near the front of the passenger side wheelhouse under the package shelf is your sunroof power connections, for which I would guess you don't have a sunroof. Specifically:
The four connectors on top of your diagram are labeled A thru D left to right. E thru H are across the bottom left to right.
A is yellow and is accessory voltage. B is Black and is Ground. C is Black (may have appeared brown) and is Sunroof Switch open signal. D is Dark Blue and is Sunroof Switch Low Reference. E is Orange and is Sunroof Switch Open Signal. F-H are not used.
I think we nailed it.
Is this the manual you can order using the form in the Impala owner's manual?
If you order through the owner's manual or the web, you get gig'd for about $7.00 S&H. The dealers usually won't order it in for you, they just reference you to a 800 number to call to get it. I don't remember the number or I'd provide that too.
There is a TON of information in that book(s). The challenge is to understand how the heck they organized it so you can find what you're looking for. That was a particular challenge a few years ago when I got my first one. However, I've now had one for an '86 Grand Am, '90 Dodge Caravan, and '93 Plymouth Voyager. I'm starting to get the hang of it.
I'm glad I visited and got involved with these bulletin boards. I've helped others learn things and gotten some good from it myself too. Can't beat that.
can integrate the remote start& alarm with the factory installed alarm (included
with the driver info center add on)- not the passlock theft det.? wondering if I can't
get them to streamline these key fobs and manually lock my doors without car factory alarm
being set off if I use the unlock on the add-on fob (does any of that make sense?) Means
I have to use 2 sets of key fobs-( like to let spouse keep the spare.)
If I park in the street at home so my kid can pull in the driveway- I do not want to arm
the alarm but just manually lock the doors. Crawling underneath to put it into
valet mode is a bit impractical. Suggestions for a better plan?
I have had a CD-changer in my trunk since May of 2000---it works GREAT!!!!!
However, it took me about 3 months to finally get the correct changer
parts. Aftermarket changers would not work. Of course I by-passed the amp.
If I'm correct, the ULO radio is the cassette-only radio. Did you investigate if the UPO radio (CD/Cassette) can control the changer? Do you have steering wheel mounted radio controls? If so, do they control the changer as well?
Obviously I'm VERY interested in this since I'll only have a limited amount of time to change my factory order if the changer won't work with the UPO radio. Thanks for your help!
Brad
According to both MNR and Radios & More, the CD changer can be controlled by ALL the available Impala radios (including UPO). However, MNR says that the harness that comes with the system won't work because it doesn't go all the way to the radio. He says that you have to purchase the harness that's listed on the web site and run the new wire from the trunk all the way up to the radio and attach the plug into "the open plug at the radio". He also said that if you have On-Star some additional modificaitons are needed.
Aquaknot, I'm still very interested in hearing your story!
Brad
Aftermarket changers won't work because the CD-changer has to be equipped with a lead from the changer to the radio that supplies "Class 2 Data". Only GM furnishes the correct changers as far as I know. I did try a couple of changers that Mobil-ONE tried but none would work.
The CD-changer in my car is controlled from the radio itself---JUST AS THE OWNERS MANUAL SAYS.
The steering wheel buttons control functions as indicated.
Did I understand someone to say that the CD-wiring harness is equipped with the RDS radio that has a CD/cassette--if so, it may possibly work. But I am not aware of this combination.
Its worth a try. But--if I were you I would go to the GM parts department and have them tell you which CD-changer you need to order. You also need to order a mounting brachet for the changer. It cannot be mounted under the package tray. I can give you my CD Part no. but you better check to see if it will match your RDS radio. MY CD part. no. is -25708970 and the part no. for a extra cartridge is 25659168. This is a 12-Disc unit.
Interesting that you just had to plug the unit in and it worked. According to the guy at MNR the harness doesn't work. Maybe he means that the factory harness doesn't work with the UPO radio (CD/Cassette). Even though I have two independent opinions that the UPO radio WILL control the changer, I'm still a little concerned. I'll continue my research and keep everyone posted.
Brad
It appears that the harness is installed in ALL Impalas in Canada. It's not even an optional item, regardless of which radio you purchase. We have many different configuration options up here. Another example, in the U.S. you can't order the UPO radio without the "premium" speakers. In Canada we can (and I did).
By the time I've got this thing all figured out I'll probably have driven myself (and a few others) nuts! Waiting until May to get my car isn't going to help!
Brad
I have the radio/CD/tape option in my car and I was also told that the changer harness was not available with this package. But a few weeks ago I found a couple of connectors in the trunk and with a lot of help, discovered one of those was for the CD changer. So maybe the CD changer harness is not available as an option because it is included as standard equipment.
More info can be found at:
Both the MRN and Radios and More sites have said that without question the Impala UPO radio will control the Delco CD changer. However, I'm still very unsure/worried.
Brad
http://store3.yimg.com/I/electronman_1628_7100319
At this point it appears that my 2 options are an RF changer or put up with a stack of CD's in the console. (
Brad
I'm finally confident enough to have asked the dealer to get me a price for the changer. Once I get the car in May I'll let everyone know how the installation goes.
Brad
Brad
