1989 Chevy Beretta GT problem...
Hello. I am having a problem with my 1989 Chevy Beretta. I have taken my car to a mechanic three times, and no one is able to find what is wrong with it.
My car stalls out when I come to a stop, whether it be a stop sign or a stop light. It happens randomly. I can start it back up again, and it will keep running, but as soon as I put it in gear and hit the gas it stalls out again. I have to wait at least 15 minutes with it running before I can even give it gas without it stalling out on me. It has also stalled out when I put it in reverse.
I have gotten the wires replaced as well as the oxygen sensor, and I still have the same problem. I have also been told that it's not the coils because if it was, my car would stall and I wouldn't be able to get it started again if the coils were shorting out.
I would greatly appreciate any advice. Thanks.
I just had the sensor inside the transmission replaced. I am waiting to see if that works.
Thank you very much for taking the time to respond. I really appreciate it. Thanks again.
Anyway, I hope your car is fixed.
Then the replaced alternator went bad pretty soon (three weeks), and I got a premium one.
I had an engnine tune-up at 93K and the shop didn't find anything wrong with the engine. Somehow a week later the engine stopped stalling and started hunting in idle.
Can these two problems be related to each other? Thanks a lot in advance for any advice on how to fix this!
A friend with a Corsica was describing the same problem. Had taken the car to the shop and they had tried several different fixes, but nothing worked. Finally told the mechanic to replace the Torque Convertor Clutch Solenoid and it worked.
I love my Beretta and really need to replace it, but it runs perfect. The only problem is the interior is starting to get worn (crack in dash, carpet and seat fabric worn, etc.). We're having a difficult time finding a replacement for this car.
Any body have any ideas?
