My jeep just started leaking coolant. At first my light cam on and said " Low Coolant". I thought it was most likely just low. I looked under the hood, and it was empty, or almost.
I bought a pre mixed solution and emptied it in. 4 days later, the light came back on.
I added more and see it dripping ( slow) from under the front passenger side up near the front.
Any thoughts on what may be wrong, how screwed am I ? Cost wise etc. to repar.
My Jeep has 168,000K. I just paid it off. LOL.
Any thoughts would be great.
Thanks in advance,
Matt
Sometimes, when you hit a bump at normal speeds (~40MPH), the whole front end wobbles and you just about lose control of the Jeep.
My mechanic (who, granted, is a smaller, 1-man operation and doesn't have access to advanced diagnostic info like Jeep dealer would) has checked the ball joints, tie rod, and the shocks/struts and found nothing wrong.
I thought my wife was exaggerating the problem until she told me to try it out for myself. I took the Jeep over a small bump (actually it was a partially sunken mahnole cover in a local road) at about 45 MPH and I nearly lost control of the thing as the whole front end was shaking so violently. I had to slow down to regain steering control of the Jeep. I believe I hit the manhole on the left (driver's) side, if it matters.
My wife is 6 months pregnant and I told her to stop driving the Jeep until we can figure out what's wrong.
I did some searching online in general and on this site in particular and couldn't find anything except some reports of tie rod failures on later model (2000-2001) Durangos.
Is there something else wrong here or did my mechanic miss something?
Seems that I can fix for around $175 or so with labor and parts.
The other is his AC doesn't seem to want to drain outside. I have pulled the entire interior and checked what I can of where I think the AC condensate should drain. The condensate drains into the passenger side rear and front. I see no draining outside. I found alot of dirt in the frame rail where I think it is supposed to drain and cleaned this & what seems to be the hose or drain hole. It worked for about a day or two then started flooding the interior again. I have tried pressure washing and air pressure. Any ideas's?
Any ideas or input would be "FOREVER IN MY DEBT" :confuse: :sick: :mad:
Help, Joe
Thanks again
- turn the key; engine turns over; runs for about 2-3 seconds; stalls
- happens randomly
- when it happens, it will continue this sequence for a random period of time then at some point later (hours or days), will then start and run just fine.
- has been happening since February '05
- I have had the jeep towed 3 times to the dealership
- I have brought it to the dealership 2 other times on top of that (cause it magically started and ran after stalling out many times)
- Also of note (and perhaps related?) is that my dash gauges randomly stop working:
- sometimes right at startup
- sometimes while driving
- sometimes just the speedometer and odometer stop and the others are fine
- the pattern of "start, run for 2-3 seconds and stall" is consistent
- the dealer has replaced the PCM (covered under warrantee)
- the dealer then replaced the BCM (not covered under warrantee)
- the dealer has kept the vehicle for 1 full week's "observation"
- the dealer really does not know what to do next cause it is random and I am tired of being stranded on the streets
It just happened again this morning so this is my 6th trip to the dealer and I/they are lost as to what the cause is. I have read online that it could be security system related and/or fuel pump related.
Does anyone have any good ideas as to what step-by-step process of elimination I could try as I have no confidence in the dealer anymore and this is costing a fortune in towing and service.
Grant (Ottawa, Canada)
I bought a 1989 JC Laredo 4 monthes ago that is having the same problem you describe. It seems it would get us anywhere we wanted to go it just would not get us home. It has cost me over 600.00 in repairs and it still will not start correctly. I can tell you from experience that it is not the fuel pump,the fuel filter, the ignition module, or the battery as we have replaced all of these items. I love the vehicle and it rides great. I have recently heard that the crank sensor is the problem and after reading this from you I am second guessing puttint anymore money into this car. I would love it if you could let me know what you do and if it works. Good luck from a fellow JC owner. Jaycee1/ jaycee8895@yahoo.com
Jaycee8895@yahoo.com
Joe
so i was off roading yesteday and my car got stuck in 1/2 meter of mud (was not able to open any doors.) as you all know a cherooke sport does not have any hooks in front or in back (what genius came up with the idea not to include hooks)
ANYWAY long story short i dug for 3 hours in cold mud to wrap a rope around my front diffrental (i hope i wasent an idiot doing so) but i think while pulling me out i might of bent a hydroloc beside the tie rode (whis was leaking from what i saw) andnow the car only turns left and when i go to turn it right it doesent want to give if i try a bit i see the car lowering a bit whil forcing.
can it be that hydraulic that is bent or broke? can it be more serious? and how much you figure it would cost?
Thanks in advance
When I looked up the part on Walker's website they list it at $119.00. Is it really that hard to put in a catalytic? Is this something I can put in myself?
I would highly recommend going to a local autoparts chain to have this work done.
I have a 1996 S-10 4x4 and my Catalytic converter went out about 6 months ago.
The dealer quoted me "about $600" to replace it. :sick:
I, like you, thought that was BS so I shopped around and found a Walker at VIP Automotive for $97.12. They installed it for another $141.44.
Grand Total: $238.56.
$ saved by not going to the dealership: "about" 60% :P
I believe someone said they fixed this problem by replacing the transmission temperature sensor
Have heard crank shaft sensor can cause lots of problems also.
It started after stopping at a gas station and filling up then starting again. At first it wouldn't start and then three cranks later it started but with all electrical problems listed above.
I have had and still have quite a few Jeeps, I changed the CPS on our '98 Cherokee a month ago, but it wouldn't start at all before I changed it. This is a stutter or bucking.
Thanks, Joe
I'd recommend checking other forums using the same engine. For you folks with suspect trannies, check this out:
lgret13, "Chrysler 300 Owners: Problems & Solutions" #559, 4 May 2005 5:32 pm
It's post #559 on the Chrysler 300 problems and solutions board. Apparently water enters the trannies at the base of the dipstick tube. The source of the water is from the air conditioning condensor per other posters. Good luck.
Danielle
Is this V8 the 5.7L Hemi or the 4.7L?
Either way, I don't have an answer for you, but am interested because I'm thinking about purchasing a 2005 Rocky Mountain Edition with the 4.7L V8
-Derrick
I know there was a recall on '98 GCs for this issue. It may have also affected the '96 models as well.
The Jeep will start up fine at first. I then drive it down the road about a mile or so and when I come to a stop sign, or I stop, the vehicle STALLS OUT. I then have to press the gas pedal to the floor to get it to start. When it is restarted, I have to hold my foot on the gas a little bit to keep it running, if i let off the gas it will stall out again. After it stalls, if I let it sit for a little bit, it will again start up and sit at an idle fine, until I drive it down the road a mile or two, and the same problem occurs.
Thank you for any help
