Also do you know which of these parts are serviceable - can I buy a replacement viscous coupler (is this the same as a transfer case coupler and does it sit inside the transfer case?) and are there any replacable parts on the front driveshaft - the mechanic tells me it has a coupling on either end. I live in a really bad place to try to get the parts so when we order I want to get it right.
Thanks again.
Hope this helps
When turning at a light (A U-turn), suddenly, my Jeep didn't want to turn. I actually thought I had a flat (It felt like when you have a flat and try to turn). Pulled into a parking lot. Nope. No flat. I looked around, and couldn't see anything obvious.
Pulled forward into a parking space and got lunch. Pulled out, and it didn't want to go in reverse. It did, but stopped almost like I was in a small trench or something. Forward works ok, so I headed home (a few blocks). Had to make another U-turn... same problem. Got through the turn, and made it home. Pulled into my parking space, and it doesn't want to turn, but did (This time, turning to the right).
These problems only started right after shifting from 4WD to 2WD. BTW, mine is the Selec-Trac automatic transmission.
Any ideas? Coincidence?
tuggajb
http://www-odi.nhtsa.dot.gov/ivoq/
I am going to report my problem to and I am hoping enough people contact this website so that Chrysler will issue a recall.
did anybody find a solution to this problem?
Yesterday -for the first time- the "check gages" sign lit up in my 2001 Jeep Grand Cherokee, and I have no clue what this implicates...
Thanks so much to any help!!!
M
Thanks so much in advance to any help!!!
M
Thanks for your help.
it acts like it wants to start, like watsonjeep's problem, except his does not run no matter what. it cranks, starts to fire, then immediately returns to cranking. the odd thing aobut this though, is once its cranking, it wants to start exactly like normal, but cant. so the crank time is consistant, and within 1 sec it dies. if you hold the key down and let it crank, it repeats over ad over. i have tried it with my foot to the floor. it WILL NOT START AND RUN. ever since yesterday we have been trying and the same thing happens. we did check the alarm system, and turned the key in the door, no luck.
Any clue how expensive repair this is ?
THanks.
something somewhere has to be messed up. you dont suppose its the main computer?
Not sure if this is what your problem is but thought I'd give you my info.. Best of Luck. :shades:
P.S. a very good source of TSB's and all other information on all JGC is http://www.wkjeeps.com/.
