should we get rid of or pray alot
keith
Jim, Mexico
I have a 2004 JGCL that makes a loud/high pitched grating noise when I go from park to reverse or part to drive. The vehicle has 39,800 miles on it. It also seems to 'lurch" forward when I am proceeding from a stop. Any suggestions as to what this might be???
Michelle in CT
i would look over your hoses real good and check the bolts that hold the manafold on they should be gust snug don't over tighten
If the Transfer Case has to come off, does this involve lowering the transmission?
My 2000 JGC Limited (4.7 L) does the same thing. It was both 'grating' and 'lurching' occasionally when we bought it with 35,000 miles and it still 'grates' and 'lurches' occasionally now, with 98,000 miles. My "occasionally" is about 2-3 times/week. It has never given us any problems (other than concern when it happens).
I have just taken the 1 to 1.5 seconds of grating as being an electric movement in the transmission. They are both annoying, but, in our case, at least haven't cost us anything for 6 years. Good Luck!! Brad
keith1517, "Chrysler Town & Country Electrical Problems" #103, 23 Aug 2007 11:10 am
miesk5, "Ford Bronco Problems" #60, 27 Sep 2007 5:17 am
Jeff
I occasionally hear a weird and horrible noise from the center console which originates after hitting a bump, pothole or whatever.
It sounds like some sort of flapper or butterfly valve gets stuck and the noise gets louder with motion and stops when the vehicle stops. The noise lasts only 20 - 30 secs (as soon as I pullover) and the vent valve seats itself (i presume). The noise sounds god awful and would make you think explosion is near, but it fixes itself before I have a chance to pinpoint it.
My questions are:
1. Has this happened to you, so you know what I'm talking about?
2. Is there a vent buried in the center console that controls the ac blow to the back seat?
3. Any ideas?
Thanks for your help!
JW
mike
http://www.wjjeeps.com/climate.htm
http://www.wjjeeps.com/hvac_sub_assembly.htm
good luck
enter complaint under visibility:defroster/defogger system:windshield:blower
We have to unite to get results!!
I think the shop is responsible for the problems becuase of the MIS-DIAGNOSIS the first time. Possible they cut a wire for the remote started that caused some kind of system error. There are many different things that could of lead up to where you are but what I do know is that iof they would of used a back up battery device, changed YOUR battery and terminals and then removed the back up device, you would not of had any problems with the theft system or other issue. (IN MY OPINION)
