help
Can anyone tell me how to remove my glove box on 2003 GCH.
Can anyone give me any hints tips on replacing heater blend doors 2003 jgc
Thank You
So... I'm currently having a problem with my oil pressure. It's dropping drastically low after my car warms up (I'm in Minnesota). I've ensured that the oil isn't low or anything like that. So when I come to stop signs/lights I keep on foot on the brake and rev the engine a little to keep the oil pressure up.
Are there some simple things that I can look for as the culprit or am I just going to have to bite the bullet and take it to a shop.
Thanks for the help.
I highly recommend that all Jeep owners who have had to have the wiring harnesses replaced because of electrical problems in their Jeep Grand Cherokees, contact Jeep headquarters concerning issuing a recall on the wiring harness with the design flaw so they can pay for the replacement of them, saving us the owners a huge repair bill. Maybe if we can get Jeep to issue the recall they will refund money paid to those of us who have already had to pay for these repairs once and will more than likely have to pay for the same repairs again!
Thanks. I'll let everyone know if that does the trick.
Also what can I look for to be sure these problems are not existing.
Sorry, no fix yet. The battery, ignition switch and console unit with the A/C knobs have all been replaced, but still flickering. If you get a fix please post. I will do the same
Any ideas about the cause? I would rather not tear the dash out again. He does not live at home and I wanted to get a little input before he brings it to me. Kind of like "no heat =broke blend doors" Thanks, Steve
Good luck!
Is there any additives that people have used in the rear to quiet this down? I don't want to spend big $$$$ on a bearing fix as I would probably just sell it instead.
Mark
I have a 99 jeep grand cherokee that has recently developed this squeal only above 15 mph. The squeal doesn't change when turning left or right , no change when shifting to neutral (coasting), no change in 4 wheel drive, the belt is good, new brakes and rotors, when slowing down at 15 mph the squeal stops. Any Suggestions
Also The sound appears to be in the front right side of the vehicle
Would synthetic fluid help quiet it down? I hate noise! Hence, my last Jeep. I want something less problematic. I'm going to drive it into the ground, and I am looking to keep it going for as long as possible. One less car payment!
Mark
Works only on high at any temp setting. Is it time to look elswhere.
The audio system is a base single CD w/Bostons Acoustics amp adder. This REF model radio has AM/FM stereo, single-disc CD player w/bass, treble, balance, and fade control through on-screen menu -AND- front mount auxiliary audio input jack. I did not want Sirius since I have had XM for many years and own the Delphi portable XM that I dash mounted. In our 01 & 04 cars we used a cassette deck adapter to direct feed audio from the XM unit and the car audio always stays in cassette play when you turn it off/on. However this Jeep radio goes back to FM radio mode upon restarting the Jeep when you turn off the Jeep with the radio in AUX mode (the XM unit powers off/on automatically when is senses a loss of 12VDC power, 4 years old and perhaps "smarter" then the newer Jeep radio?).
Anyone with a 07 or 08 model feeding the AUX with XM or even a MP3 player ie ipod figure out how to keep this Jeep radio in AUX mode?
Good luck
