Think You Might Have Been Cheated? Ask the "Judge" and "Jury" Right Here!
Mr_Shiftright
Member Posts: 64,481
in General
Hello, this is "Judge" Shiftright, your Host in Maintenance and Repair....
and this is the place to state your case! Let us help you decide if you've been "done wrong" or not.
RULES FOR THIS DISCUSSION:
1. Do NOT use any dealer's or repair shop's name! Posts using names will be deleted asap!
2. This is a game, not a courtroom. We are not lawyers or judges and don't claim legal knowledge. This is a Support Group for consumers, by other consumers.
3. Aggrieved Consumer: State your complaint and give us as many facts as you can. Try to be clear and fair.
4. Jury: Listen to the Aggrieved Consumer's story and then give your opinion...was he/she cheated or not? Give reasons, and try to be fair to both consumer and shop/dealer.
5. Judge Shiftright will also render his amateur opinion.
6. Don't forget to smile and have fun. Rants, raves and cusses are not the point here. This is your chance to rationally state your case and maybe get some ideas.
Alternator replaced to the tune of $495
$60 towing
$330 part
$50 charge battery
$55 labor
I do not feel I should have been charged to charge the battery, most places would do that when they replace the bad inginition part, kind of a free service. The part itself, well, that's another story.The labor is about right, part is easy to get to.
What do you think?
And...50.00 ???
Are you serious??
Also, how far was this tow? I'm wondering if that was "packed" as well.
Told additional coolant was an overspill.
Told 124 point check done on van.
Two weeks later needs new engine
One month later needs another new engine
Asked for refund of $3000.00 and return of van.. they refused.
contacted Attorney and they took my loaner away.
Today another leak, think it may be transmission this time.
Because of homepage I created, they put new tires, brakes and rotors on.
one day later, another brake job, they put a warped rotor on.
Seat belts don't hold car seats in, they require an h-latch, they knew this but didn't say anything. Tested against 4 other windstars and none of the seat belts hold car seats in.
Should I be made to keep this for the next 5 yrs??? Thanks all.
Lisa
This sounds like you are already in all-out war with the dealer, and with attorneys involved, I don't think we should comment. But sorry to hear of your troubles. Sounds like a big disappointment.
Okay, next case please!
-$55.00 labor charge actually sounds very reasonable for both ignition part and alternator replacement.
-really steep prices on the parts but I figure it's because you went to a dealer and he used new manufacturer parts and not reconditioned parts. (A reconditioned alternator runs approx $115.00 for the '97 Rodeo)
-the charge for the battery recharge is bogus and unjustified, not to mention way high. They should have jump started it and then tested to see if the alternator and charging system were working properly.
If the dealer will not comply, go to small claims court with this, after getting an estimate to repaint the bumper from a good (the most expensive would be just fine, thank you) body shop....pick one that paints Rolls Royces.....show the dealer the small claims summons and the repair estimate....he/she may then offer to paint it at their own shop....which is fine if they give you a written warranty on the paint....whatever the standard paintwork warranty is at most reputable body shops...is it one year?
A. THE CUSTOMER WAS NOT BILLED $50.00 FOR CHARGING THE BATTERY. THE VEHICLE CAME IN WITH A "NO START,JUST CLICKS " PROBLEM. THE CUSTOMERS BILL HAS A LINE ITEM THAT READS "BATTERY/CHARGE SYSTEM DIAGNOSIS" $24.95
IN ORDER TO DETERMINE THE PROBLEM, IT WAS NECESSARY TO TEST THE BATTERY AND CHARGE SYSTEM, AND THIS DIAGNOSTIC CHARGE WAS $24.95-----AND FOUND THAT THE ALTERNATOR NEEDED TO BE REPLACED.
NO WHERE ON THE BILL IS A $50.00 CHARGE FOR CHARGING THE BATTERY!!
B. THE CUSTOMER WAS QUOTED BEFORE WORK WAS DONE, IN FACT ACCORDING TO OUR REPRESENTATIVE THEY QUESTIONED THE PRICE OF THE PART AND DECIDED TO LOOK AROUND AND SUBSEQUENTLY CALLED BACK AND APPROVED ALL WORK BEFORE IT WAS PERFORMED.
WE ARE A FAMILY OWNED AND OPERATED DEALERSHIP SERVING THE RICHMOND AREA FOR OVER 70 YEARS. WE DO OUR BEST TO PROVIDE QUALITY SERVICE AT COMPETITIVE PRICES.
CHIP
Makes no diff. The above dealer is history! They should really visit the www.contour.org page for an ear full of Ford service!!!!!!!
Time for new topics!
But, we need to move on to new cases in this forum. Mine is old hat now. Thanks for listening.
she took in for a routine oil change to the
dealer. The dealer informed her that the timing belt needs to be changed as the mileage has
exceeded 60K. She could not find me, so she
authorized the ~$400 repair.
I then looked into the manual and learnt that
Toyota recommends the change at mileages above
90K.
Well, I don't think we were ripped off, just
something that left a sour taste.
However, in my opinion what the dealer did was impose his maintenance schedule on you They all have a dealer recommended schedule which is always more service then the manual and they all claim that the service is needed due to "where you live" In short, if the manual says 90,000 you were ripped off! And the cost, sorry, my Toyota dealer runs discount coupons all the time for timing belts at $198 including the belt and labor. Most that this should cost is $250, $300 if they replaced the two other belts as well. You did not mention replacing the two accessory belts that have to be taken off to get to the timing belt?
water pump. What other two belts? Please elaborate.
The repair came to $350 with the oil change.
I guess their prices are on the higher side.
Now the question is should I wait till 150K miles
or 120K miles for the next one?
As for the water pump, I agree, once you are in there already on a car with 66K, I would replace the pump if it were not a terribly expensive part.
So, at worst, I would judge that you have been somewhat "oversold" by some people's standards, (not mine) but certainly not cheated.
In October, I had some body work done to repair both of the rear quarter panels on my car (95 Accord). Rust was beginning to bubble through the surface, and I wanted to get it fixed before winter started. I also had the car undercoated at the same place, the wheels painted, and touched up all the chips I could find. The cost was $CDN 750. On my receipt, the words "No Warranty on Rust Work" are printed in boldface type.
In February, the same two panels appeared to be in poor shape. Rust is plainly visible where the panel meets the rear bumper on both sides. I contacted the body shop manager, and he said that there is no guarantee on rust work, and that these repairs sometimes last months, sometimes years. He said there was nothing they could do. I was under the impression that any repair should last least a couple of years. Now, in April, the two rear quarter panels look worse than when I took the car to the shop in October.
I would be grateful for any advice in this matter. My problem is not with the car manufacturer, because I bought the car used, knowing there had been some body work done on it in the past. My problem is the shoddy work that I paid for - is there anything I can do about it? Or should I expect to get a few months out of this type of repair? If I have a leg to stand on, what would be an appropriate course of action?
Jeff J
http://www.gomemphis.com/caraudio/15bump.htm
I see all kinds of problems with interpreting the "facts" here....one being a possibly disgruntled ex-employee recently fired. I'd really need to see some proof if I were on the jury, beyond the testimony of a person who may or may not being trying to rectify a bad situation vs. just getting even. Hard to say, hard to say. Took him long enough to find his moral compass though. But maybe that's okay, too.
I think people are sometimes tricked and both intentionally and unintentionally confused at dealerships. This is why sites like Edmunds are so great if folks can get 10 minutes access to a computer. Once you know the numbers, or can use a finance calculator, you can defend yourself against people who don't mind seeing consumers staying ignorant.
The lesson here is that you should have obtained a second opinion prior to okaying any further repairs by this dealer after the first one The coolant and oil leaks should have been found the first time. It is possible that although you did not see any coolant loss while under there they saw the leak around the pump???????. Is this your regular service dealer, have they been good to you before etc.? Not sure where to go on this one!
Also, I doubt if the shop "caused" a problem. Often shops get things blamed on them when a customer refuses to believe they have a problem.
Like to hear the other side of this one.
The only issue I see here is whether the oil pan gasket was necessary. That would depend on the severity of the leak. But certainly if the trans oil tank had ruptured into the coolant tank, this is a serious situation and needs immediate attention.
If, in fact, my guess as to the type of repair is correct, then I'd say there was no cheating going on here. Just typical high labor rates at a dealership, due to high overhead costs passed onto consumers.
labor 1 hr 73.00
filter kit 32.89
gasket op 29.81
lube atf 17.00
total 152.70
lines, transmission/transale oil cooler
repai or replace both
labor 2 hrs 146.00
1 pipe 22.63
1 pipe asm 31.18
total 199.81
replace water pump
labor 4 hrs 292.00
water pump kit 104.90
2 gal coolant 26.40
total 423.30
The question then becomes whether or not the water pump were leaking at all, or bad enough to be replaced.
Is it possible for a water pump to leak but not to drip on the ground?
Well, yes, if the shaft bearing is just starting to go, a little coolant could pool in some crevice and be noticeable to inspection without actually dripping all over the place.
So, IF in fact the pump was starting to dribble, it would be a good thing to replace it then and there, as a leaky water pump could cause serious engine damage.
I'd say that you might have been able to control the costs somewhat....was it necessary to replace BOTH transmission lines? maybe, maybe not.
Did the transmission need a full service and filter or was this done recently?
Is the old water pump available for inspection? On what basis was it replaced? Leak? Loosness?
Anyway, it's hard for me to know if the work was really necessary without inspecting the car itself, but if a) trans oil was leaking out from the lines, and b) someone did in fact see some drops of coolant from the pump, then the repairs seem to be in order.
this is one of those repairs I call "a matter of degree". Dealers tend to do EVERYTHING and cover all their bases. If you fixed every little glitch and seepage in an old car, you'd go broke, so you have to pick and choose what to fix and what not to fix. The dealer likes to fix everything, of course.
Probably a good choice not to fix the oil pan gasket at this time. Maybe a little tightening will work, or you can just live with a few drops every day. Keep an eye on it, though.
thanks for letting us look at and comment. Any more remarks or jhelpful suggestions on this one?
armtdm - $73/hr? city in Wisconsin
As a side fact: I had repair work done at another Buick dealer (Kenosha, WI) for 10 years until owner retired and closed shop. They had been the ultimate in integrity, fairness, honesty, and a high reputation for never taking advantage of women or senior citizens. In short, I always felt "safe" in taking my automobiles to them. Thus, I was searching for another dealership with equal reputation. Did I find that in this dealer? I'll never really know if their repairs were entirely fair or not, but I do know I won't return to them.
And, 73.00/hr. labor charges are pretty common. I've seen over 100.00 per hour in some speciality shops, Jaguars, etc in the Bay Area and that was more than five years ago.
I knew a guy who needed his heater core replaced in his Peugeot 604 a few years ago. TWELVE hours of miserable labor plus the core was another 200.00. Add coolant, clamps tax, etc and do the math!
3 months after buying the car I felt that the steering wheel was vibrating.
1. took it the shop and theyu said that my tire on the front was a bit low so they put air in it and it stopped the shimmy.
2. 4 days later the shimmy returned and the car began drifting to the left. took it to the shiop again and they claiomed that they didn't feel the shimmy in the wheel but agrred that the steering wheel was a bit off center. so they did an aliment.
3. a day later I did feel the shimmy and tokit back to the shop, they claimed that I had a nail in my front right tire and they replaced the tire.
4. two weeks later the shimmy returned and now the car drifts to the left. took it to the shop and they claimed that I had anoher nail in the left tire. So they plug the tire.
5. The shimmy stops but the drift was still there. after a confusing diaagreement with the dealer they claimed I had a tires pull and need to to take the matter up with the tire manufacture,. Which i did. after a review the tire guys says the plug that they put on the tire had damaged the tire belt and had to take it up with them. Which i did and they replaced that tire, rotated the wheels.
6. on the same day that I took the car the shimmy returned, they said that they had to re balance the tires and ddi an aliment.
7. The shimmys stopped but the car pulls to the left, took back to the shop and thy got really nasty with me claiming that with high performance tires you'll get a pull sometimes, and they way they determine aliment problems is by driving the car and if it doesb't pull witthin 5 seconds then it ok. and if i still have problem take it up with the tire company again
8. 3 days later whenever i press the brake the shimmy returned, took t baack to the dealer and they smoothed out the rotors to stop the shimmy
9. 7 days later i got tired of the car pull to left took it back to the tire company and they claimed that I may have front end problem took it back to the dealer afetr a long disagrement agian they kept the car over nioght and had a outside source look at the car and found maybe that thieer aliment equiment was off so the outside source did another aliment, rotated the wheels . they said it stopped and that the steering is tight everything was ok but now two weeks later I starting to fell the left pull again, I'm sure if I'm tyher problem here and this type of pull is common for these high performacne cars. I'm not sure if anymore. I'm very hesitate to take the car back maybe its not a problema at all
Your advice is needed
Thanks concerned and mad
I have seen complaints on the 300M board (haven't seen you post over there, though) about a pulling tendency. It looks like it's an issue with the tires (Goodyear) although I have Goodyears on mine and they have had no problem.
What kind of roads do you drive on? Are there a lot of potholes or rough roads? Is it possible that you might have bent a rim? Is it a forceful pull that you have to fight to keep it going straight, or is it something that "pulls" when you let go of the wheel?
I'd suggest you post your problem in the 300M topic in sedans. As I said, some people have had this problem, and they can tell you what they had done to correct it.
Now, shimmy, that's another problem and certainly solvable.
Why don't you take another 300M out on the road and see what it does? If it feels the same, then that's just the car no doubt.
I don't really think the 300M is a "high performance" car, and that's probably part of the problem. The suspension may be designed to be very forgiving and compromising. You might, in fact, not much like the suspensionfeel and ride of a real high performance car.
It sounds to me like the dealer is trying to solve your problem. He doesn't want to see you anymore than you want to see him. Besides, there is no motive for him trying and trying to solve your problem, time and time again, and not doing it right. Profit? Sadistic fun? I doubt it.
I think, if anything, this pulling is either a quirk of the car itself and not the dealers fault or b) you are expecting too much of this car's ability to track straight on today's often lousy roads.
As for the shimmy, this is a balance issue with wheels or tires, and shimmy while braking is a brake rotor issue usually.
If they cannot fix the shimmy problem, you may have a case under Lemon Laws (check the laws in your particular state, don't follow blind advice on this). As for the pulling problem, I do not think you have a case under the Lemon Law.
