Mine is a GLS FWD so there may be a difference in the transmission noises, not sure but this is all I can think of for now. Hope this helps.
Blue
Thanks for taking the time to respond
emen7: I have an early 2002 GLS FWD and do NOT have a 'tea kettle whistle' noise. Or anything like a 'tea kettle whistle'.
You might try folding the outside rear view mirrors in and see if that makes a difference at speed. I remember reading a thread (who can remember where) about a failed/missing gasket on an outside mirror, causing a whistling noise, on a Santa Fe.
Let me try to explain again.
I described this noise as a tea kettle whistle. It might also be described as more of a whining noise. I used the term tea kettle because it is not a smooth clean sound, more a little garbled as a tea kettle sound.
The VERY ANNOYING NOISE becomes apparent at speeds of 35 to 40 MPH. When I accelerate to 40 and they let off the gas and slow to 35 it is the loudest and most obvious. I did drive another new 2002 GLS and noticed the same noise at the same speed. It was however very faint, mine is louder.
If I have the radio on or the fan set at the number 3 speed the noise cannot be heard. Maybe I am making a big deal out of nothing but to me it is without a doubt a VERY ANNOYING NOISE.
I have been thinking of your problem with more thought and I have serveral ideas. Seems maybe a door gasket air leak, Check and make sure the A/C fresh air vent is closing all the way and not making a whistle from the outside air. Also does it make the noise if the air is off completely with the a/c fresh air vent closed with no air comming through your vents? Also check and make sure that the foam rubber gaskets that meet the door and dash close tighly when the door is closed. I had a problem with passanger side. The foam gasket would whistle with the air on and the door vent closed causing back pressure and the air would whistle around the foam gasket. If not If I think of anything else I will let you know.
Blue
thanks for you input but the gaskets are not the problem.
I am amazed that I could drive another new GLS FWD and hear the same sound. I initially bought into the suggestion from the dealer that the sound is normal coming from some place in the drive train. I live in Florida and the dealer is a very large one. The problem is that not a single person has responded saying they have a similar noise. This leads me to believe that the sound is not normal. If you had it you would know it unless you never drive without the radio on. When I test drove the car, it was 90 degrees outside so the AC was on full blast making it impossible to hear the noise. I was hoping and expecting to find several people that have the same problem. I have searched the internet but as yet have had no luck. I intend to make this an issue with the dealer but have this bad feeling that when everything is said and done I will still be stuck with this VERY ANNOYING NOISE.
if your co worker had the noise fixed as I defined in Msg. #357. I would love to get a little more info. I do not know if the name of the dealer can be posted, but maybe the town & state location. I would love to speak to the dealer about the repair. Any help would be greatly appreciated. My dealer has a tendency to try to dismiss this problem. I really love the car
By the way today I received in the mail, a letter from Huyndai describing the error in the HP rating that was published at 181 when in fact it is only 173. Hyundai offers an apology and to back it up an offer to increase one of the following.
Extend roadside assistance to 10 yrs
Extend 5yr 60,000 to 6yr 72,000 mi.
Or extend powertrain from 10yr 100,000 to 12yr 120,000.
I am taking the extention of 5yr/60,000 mi. to 12/yr. 72,000mi
WHAT A WARRANTY !!!!!!!!!!!!!!!!
HOPEFULLY THEY CAN FIX MY VERY ANNOYING NOISE
I really hope they find your noise but if you have dealers like in my area, everytime you bring it in for a problem they say thats normal. Once I did that with 2 dealers and they both said the same thing. I called the Hyundai number told them the situation and was firm on getting it fixed. The very next day as my Santa was still at the dealer they found the problem, and even said I was rignt to begin with. Well if you think it is a problem call soon and report at least.
Blue
It is very noticable on vehicles that have part time 4WD (when engaged, my '00 Rodeo has the noise). The noise stems from the front differential gears not having as smooth helical gear as the rear differential. It is just the noise of the gears meshing. If anyone has driven anything with a manual tranny with 'straight cut' gears (usually without synchros), you know exactly what the noise is. Also the distinctive noise of the old cars in gangster movies accelerating.
Usual indicators are a more prominent noise when accelerating or decelerating at certain speeds. If it really-really- (and-I-mean really) bothers/annoys you, have the differential fluid changed, and also have the propeller (not as in airplane) shaft checked.
Hope this helps
Anyone here has any idea if this is ok?
Is this only on Santa Fe's V6? Or Are all Hyundai V6's lower then advertised? What about the 2003 Santa Fe's?
HOST, TALK TO ME!
Host and others...your comments please. Either on the Town Hall or direct to maximas00@hotmail.com.
Apparently several models are affected. You can read more about it here. This article has an 800 number you can call for more detail and you can also visit this site to see if your vehicle is affected and what remedies are being offered.
I hope that helps!
tidester
SUVs; Aftermarket & Accessories
When you drove it, you either felt the power was adequate, or it wasn't. If it wasn't, you shouldn't have purchased it. Anyone with serious towing needs is not buying a SF, or CRV, or Rav4, or any other car-based SUV. Hyundai is being incredibly fair by extending their warranty for this "problem". In case you couldn't tell, I still love my SF after 12,000 miles in the first five months!
I suppose the car manufacturers will start covering their bases by adding the "up to xxx horsepower" language just like the aftermarket guys do, if the feds will let them.
Steve
And the commercials will all end with Your Horsepower May Vary (YHMV) right behind the line about gas mileage (YMMV).
tidester
I purchased one of the early 2001 vehicles. At 1632 miles the engine blew (the details of this are downright frightening). Then the replacement engine blew. The third engine was noisy, a gas hog, and never sounded right. We had an electrical problem that shut off all the lights, radio, blinkers, etc while you were driving. Several sensors blew in addition to the known throttle position sensor. Then the transfer case developed a leak that they tried to fix three times. They finally replaced the whole unit. My wife is on a first name basis with Roadside Assistance.
The Santa Fe was too unreliable to take on a long vacation road trip so we ended up buying another car. We finally cried uncle and amazingly Hyundai replaced our vehicle with a new 2002 model (GLS, 6Cyl, AWD, ABS).
I should play lotto. The new vehicle developed a miss in the engine. It was like someone tapped you from behind. They replaced the power control module. We picked up the car and two hours later the engine was barely running (module was not programmed right). Next they replaced something with the fuel injection system. The problem reappeared. Finally they called in the regional service expert. I was told that ultimately they replaced the plugs, wires, distributor, high voltage coil, fuel injection system, and anything that could possibly cause that problem. All this involved over 40 days in the shop, several visits from our Roadside Assistance friends, and multiple trips back and forth to the dealer.
Through all of this Roadside assistance worked well, the warranty worked great, we were always offered a courtesy car, and the people at Manly Service did everything in their power to help us. We never paid a nickel for a repair.
So anyway after three engines, two transfer cases, two vehicles, half a dozen blown sensors, countless towings, almost 80 days in the shop another thing comes along. Actually my choice should obviously be to extend my warranty.
I wouldn't call it being pompous. Frustrated and disappointed is more accurate. It's more than likely that I am taking out my frustrations on the horsepower issue.
Like I said before, I still like this vehicle. As a matter of fact my sister just bought one and she loves it.
-Jason
Mr. jchatt 55, you have every reason to be disappointed, but please don't take it out on me.
the exact same symptoms.
Faint whistling/ringing most noticeable around
65-75 mph and 35-40 mph. I heard the noise at
other speeds as well, but not as often. And yes,
it is annoying!
It appears when the throttle is released just
enough to put the engine/transmission in between
load and cruise.
To me, it sounds like the gear noise made by a
slightly worn older manual transmission.
I took it to the dealer last week, and he couldn't
duplicate (of course). So, I went on a ride with
him, and what do you know, I couldn't duplicate
at the 35-40 mph range, either. So we went on
to the highway, and there it was, around 65-70.
He thinks it comes from an air baffle (or airbox
or something like that) into which compressed air
is rushed when the throttle is released. Says
it's normal. I think not. He even showed me the
box.
This Thursday, he's gonna give me a similar
loaner and keep ours, so he can check it further, and I can see if it also has the noise.
I'll keep you posted. If you find more about it,
please let me know. Also, if you have similar
symptoms, please post.
M. Hizlan
P.S. We like the Santa Fe in general.
At times, there appears a buzzing noise/vibration
felt at the steering wheel and brake pedal at
full stop after braking. Its intensity varies.
The dealer suggested that it was normal, and
happens when the engine is under load at idle,
like when the cooling fan comes on. I did verify
afterwards that it is slightly felt when the AC
cycles on. Didn't have time to check about the
cooling fan, but he is probably right about that
cause as well. Perhaps it's worse when both are
on at full stop idle.
My question is, does anyone else have this?
Would you consider it normal?
M. Hizlan
vallynne
miles, took it for maintence today and was told that the freon was low and that it would be 72 dollars to fix it. I have a 7 years old nissan and it has never been charged.. They say there is no leak. And best yet its not covered by warranty! Anyone else had a similar problems
Lex
As you found out, Hyundai A/C freon warranty is for one year. However, the REAL question is: 'Does the A/C work OK?' If so, forget the charge.
Not sure about the hot and cold at the same time but was your outside vent closed when this was happening? I had a problem with the damper that closes off the outside air from comming in and it had to be replaced. It was all electronicly controled. Maybe yours is stuck half way and it is allowing the heat from the heater core and the cold outside air to come in at the same time and directing one to one side and one to the other. Just suggestion.
mark
In California, how much do you think a reputable body shop will charge to replace?????? From where would they get a Santa Fe bumper anyway???? I may decide to pay out of pocket and not go to insurance. Any thoughts would be appreciated....
One thing that i cant figure out is that the manual say parking lights will go out if left on when driver door is open but this is not happening. I am just afraid if i leave lights on by mistake I will have a dead battery. am i doing something wrong?
My interior lights go out after 30 minutes if I leave a door open, but parking lights doing the same thing is a new one to me.
The lights will go out when the driver's door is opened, if the lights were 'on' while driving and you did not turn the light switch 'off' when you shut off the engine/ignition.
If you turn 'on' the light switch while parked and the engine/ignition 'off', the lights will remain on, no matter what door is open or closed.
At least they did today. =;-)
