Let me type it again.
If you leave the vent open, cold air comes in the passenger side vent. And if you close it by setting the air to recirculate the cold air stops, so it don't work right? So its broken or a design flaw?
Not much more to type here.......
To all others, please understand one thing: I LOVE MY SANTA FE AND I WOULDN'T TAKE ANY OTHER SUV THAT COSTS UNDER $30K FOR IT'S REPLACEMENT!!! I simply want to find out what the problem is so I can get it fixed.
There's a door behind the glove box where a cabin filter can be inserted into the incoming airstream. Maybe that door popped open or an air duct hose slipped off. Hopefully the problem will be a small one. Good luck!
It is hard to believe that Hyundai hasn't verified the problem at this point, and come out with a recall and a fix. (I even checked the owner's manual of a 2003 model and the heating/venting system looks the same as mine -- a 2001 model.)
I did call the 800 Hyundai number in my owner's manual and they assigned a problem number to my situation and referred me to the regional service engineer (who I'm waiting to see). Perhaps if more of you call the 800 number, they'll understand that many of us in the northern climate are having the same problem. What else can we do?
Purchased 11/02 and it now has approximately 1200 miles on it. Wife loves it.
Thanks for any feed back on this.
I am in the process of buying a 2003 Hyundai Santa Fe GLS/AWD and want to put a remote starter in it. The dealer informed me that Hyundai could deny warranty work if I have this installed.>
Why don't you have the dealer install it?
I've heard a number of stories of aftermarket remote starter and sound system installations screwing up the electronics on a vehicle. Why should the manufacturer be on the hook for that?
harry31's suggestion is a good one - let the dealer do the installation, if they'll agree to it. You'll probably pay more, and might not like their system compared to an aftermarket one, but they'd be more likely to stand behind it if there is a problem.
Extremely nice, went totally out of his way, and made sure I was happy..
The noise is gone and I am happy... I am very glad I bought this car over any of the other ones on the Market.
The engine had to be replaced. The service manager showed me the dead engine. One of the cylinders steel sleeve was broken apart and the piston head was also destroyed. The months prior to the engine failure, the Check Engine light came on twice. The engine was running very rough and with diminished power. It is like riding a horse. After stopping for a few hours, the car was running normal again. Each time the mechanic could not find any problem with the car.
It has been a week since I got the new engine. It is still not running right and is in the shop again. There is a "thumping" sound from the engine or transmission and the car is not running smoothly. I don't know if it is a engine problem or transmission problem. The shop manager said it could be a mis-fired spark plug. I'll find out tomorrow as they are busy today.
Thanks in advance.
I thought that automatic daytime running lights were required on all new cars. There are statistics showing that this feature reduces daytime collisions. Yes, I realize that the headlights can just be turned on manually, but no human being is perfectly consistent.
Does anyone know why this feature was omitted?
However, leaving the headlights on all the time is not really the same as a daytime running light. With the DRL feature, the voltage to the low beam is dropped by a volt or more by a diode string. This reduces apparent brightness only slightly while drastically reducing wear and tear on the low beam. Turning on the low beams restores full brightness. Expect to replace pricey enhanced brightness headlamps like the Sylvania Silver Star ($45 the pair) every six months or less if leaving the low beams on continuously.
My question was really this: Has the Federal government repealed the mandate for daytime running lights, or is the Santa Fe exempt for some reason?
Your question intrigued me so I tried to research it. I can find nothing on the NHTSA or DOT websites that say that DRL's are required, or soon will be. It could be that they gave the manufacturers a big phase-in period.
With regard to your concern about lights burning out, I can honestly say that my Santa Fe's standard headlamps are far and away the best factory lights that I have ever owned. The only thing that I can even compare them to is a pair of aftermarket lights by Cibie that I bought way back in the 70's! We have 20K miles on our Santa Fe in the first 11 months and have had no failures of any lighting component. (We also have our fog lights illuminated at all times that our headlamps are on because research shows that makes people less likely to dangerously pull out in front of you!) Again, best of luck with your Hyundai.
To me, it sounds like a normal noise of the transmission gears meshing after the transmission downshifts from fourth to third.
Try going to a couple of dealerships and taking similarly equipped vehicles for test drives. This should determine whether you have an abnormal transmission or just an impressive set of ears.
Can you please elaborate on your fuel mileage comment? Do you have the V6 FWD? Do you primarily drive in the city?
We brought the car in but the mechanic did not experience the problem. We're going to try again, but wonder if anyone has experienced this.
Will it start back up and be OK after it dies, or is it hard to restart?
If it only dies after driving for a while and then coming to a stop it may actually be a transmission problem. Most modern automatics have a feature that mechanically locks the engine and transmission once the car is at cruising speed. If it fails to unlock the car will die, just like in a manual transmission car if you stop with the car in gear. Try putting the car in neutral when you come to a stop and see if the problem continues.
Now, having said all that, if your dealer can replicate the problem they have to fix it - it's as simple as that. Many Hyundai dealers have a loaner car program, so if yours doesn't find one that does. Knowing you're racking up miles on one of their cars tends to motivate a dealership to fix yours.
If all else fails, call Hyundai at 1-800-633-5151 and tell them about your problems. They've been bending over backwards to help owners. They've worked very hard to improve their image.
Good luck, and let us know what happens.
-Jason
It stalls differently all the time. For example, it has stalled while sitting in traffic for 5 minutes, sitting in stop and go traffic for over an hour, idling at a stop light, etc. There's no pattern whatsoever.
For the most part, it has restarted OK. However, we had to jumpstart the battery a few weeks. We thought that we had left the interior light on, but that was not the case.
As far as service goes, Hyundai has replaced the crankshaft sensor, given me two new batteries and finally an altnernator to no avail. After picking the truck up on Saturday, it stalled on Sunday! Needless to say, my truck is now considered an open case with Hyundai.
I will keep you updated.
Jody
I agree with you that Hyundai should either replace your vehicle or quickly determine the root cause of this problem.
I would write a one page letter to the Hyundai VP of Customer Service/Satisfaction. Simply state the facts and do not get emotional in the letter.
Please keep us posted. Good Luck.
Then, when one of your window motors finally decides to die, you've spent two, three dollars on fuses.
Dealers can really milk those intermittants. =;-)
