Just thought I would pass this on for information purposes only.
First Visit.
R&R Sunshade Assembly Reinstalled correctly.
Second visit.
1.R&R Headliner and insulated both drain tubes.
2.Resecured all hardware associated with sunroof and realigned glass.
I will be taking it in again next week for them to try again.Can anyone suggest what may be the cause of the rattle? They didn't completely drop the headliner.Except for this problem, the Santa Fe is one solid,comfortable driving suv!
They also make an anti-squeal grease that you put behind the pads that fixes a lot of squeals.
http://www.hmaservice.com/webtech/iindex.asp?id=394886672#_394886- 672
Good luck!
They opened a file on this and agreed to reimburse me for the $50 cost of a Hyundai wind deflector upon sending them a receipt. It does not cover the installation, which I'll do myself anyway.
Two comments about this. One, my dealer will most certainly hear about this, at least from me if not from Hyundai as well. "They all do that" is not the right answer to give a customer when dealing with a vehicle problem, regardless if it is by mechanical failure or design flaw. Second, this is not the first time Hyundai has helped me out when a dealer either wouldn't or couldn't. One more reason to purchase a Hyundai.
1- Be sure the cross rails are not installed backwards.
2- Move the front cross rail rearward aprox 19.5 inches from the seam line on the factory side rail. Positioning them in this manner will reduce wind noise, especially in sunroof-equipted vehicles.
Upon reading the directions, I noted that mounting in accordance with Hyundai's instructions would have placed the front cross bar right across the moon roof opening. Hence I have figured out that if your vehicle is equipped with a factory moon roof, you will not get cross rails as a factory supplied accessory.
Be careful if you actually use the cross rails to carry a load and hang on to your letter from Hyundai. If something happened while carrying a load on the roof that caused the center of gravity to contribute to a crash, you can bet Hyundai might try to use "improper mounting of the cross bar" as a contributing factor.
To contradict myself, if that were so why do they make the cross bars/roof rack in such a way as to allow random positioning of the cross bars?
On the tiny deflector in the front of the moonroof, there is a thin, blue protective covering (put there for when the Hyundai was shipped). Peel this off and and the problem will go away. This covering restricted the air flow by covering the openings on the deflector.
link (http://www.hmaservice.com/). Then go to the WebTech section I guess.
I'm not sure how you get there using your WebTV account.
skrenze
I bought my 2003 Hyundai Santa Fe (New) three weeks ago with 25 miles on the odometer. Since then, it's been a nightmare. First, the transmission went out and a brand-new transmission had to be put in. Then, the Crankshaft Sensor malfunctioned and had to be replaced. Each time my car spent 2-3 days at the dealership while the authorization and parts had to be ordered and installed. The final straw came today when my insurance company informed me that the VIN the dealership gave me (which matches the VIN on the card dashboard) cannot be verified through DMV's database...hence...the VIN doesn't match my car...so....no registration....no license....no insurance! I'm very frustrated and wondering if I'm not supposed to be owning this car!
Thanks for any suggestions.
Sorry to hear you had so many serious problems right from the start. Look at the bright side... it's gotta get better, and you've got 10 years to get all the bugs worked out at Hyundai's expense!
Looking for some help here. Friends of ours have a 2002 GLS (that is what they told me). Our friends took it in to the shop because it kept stalling. The dealer told them that it is because they were running all the electrical stuff at once lights, Radio, AC. The dealer informed them that the alternator is too small for the Santa Fe and the dealer is in the process of installing a larger one.
We also have a 2002 GLS and are wondering if anyone has heard of this becoming a recall or anyone else had this problem?
We have not had any of the stalling problems, the only thing we have is sometimes when you push the AC button it does not respond. It takes a few times to get it going. (not that I believe that is in anyway related to the alternator)
Otherwise 15K miles and still love it!!!
Let me know if you know anything. FYI if you have had this problem.
I have had the same problems with the intermittent squeaky noise. Been to two different dealers. Same answer, brakes are fine. However, they did find leaky struts. Coincidence? I am having the struts replaced next week (warranty item), and will let you all know if that fixes the problem. But for the meantime, I am waking up various neighborhoods at random, lol.
I have had the same problem. No leak diagnosed, but I have been 3 times in the last 6 mos. They charged it and it cost me the first time, the second time, they topped it off for free. Now, they filled it up and put dye in it and I am to go back in two weeks and have them check it. They think there might be a leak so small, it is unnoticeable. Between that and the squeaky brakes problem, I am about to go crazy. I love that car, but it is wasting alot of my time visiting the shop between oil changes.
Any other LX owners have this problem?
Call me old, but I remember the days with an 85 amp alternator was more than enough. I guess I lucked out when I purchased the LX, as I didn't know about the alternator specs and didn't even give it a thought. Like most, I assume that they design every system in vehicle to meet or exceed the expected "worst case" scenario.
I went in to my dealership and cancelled the GAP insurance, expecting that I would get the $500 premium back. WRONG! They made a principal payment on my loan with the money, and when I called the corporate office, they informed me that because the GAP insurance was financed with the car, they can not just give me the money back. It must 'remain' with the loan. What a crock of crap!
So now I don't have the money to pay my insurance agent for a GAP premium, and Hyundai will not allow me to reinstate the GAP insurance through them. The net result is that the money got tacked onto the END of the loan, and I probably save about $2 in interest because my last payment has been covered. I guess I'll appreciate this... 65 months from now. C'mon Hyundai, cut me a break!
I have an '01 SF6 AWD w/42k on it now. It has a number of quirks, but overall a good buy I think.
Some comments and questions for you all:
1. I take my x-rails off the roof and store them in the back. It eliminates the noise and since they come off easily... I would rather have them when I need them.
2. I also have wheel vibration problem - in the 60 mph range. I've had two tires replaced free by my tire dealer. They now think the problem is with the alloy wheels. I plan to follow up w/ the dealer.
3. I haven't noticed the hot/cold air problem in the winter - but find that the fresh air vent in the summer seems to be warmed up from the engine - which forces the A/C to be used. Anybody know if the T-stat can be lowered?
Also, has anyone actually installed a filter in the vent system. Seems like alot of fumes come in through the vent system - more than any other car I've had, although this is my first SUV. Could it be because It's raised higher off the road?
4. Had the Crank Position sensor replaced after it wouldn't shift past second gear this winter. No problems since.
5. They need to improve the drivers seat/ manual adjustments. The lower part of the seat seems to "move" when cornering tight. Sometimes the lumbar adjustment pops back to off if leaned on too hard. Dealer can't replicate this problem... Maybe the later models are different?
6. Gas mileage seems to be in the mid 20's on trips. Not bad for AWD I think.
7. Rear speakers need to be raised - as w/full loads, they can get covered up.
8. Have been looking at the new ones with sunroofs. They seem positioned to far back into the rear seat area... comments?
9. And then there is the sulfer smell!! whew ! Never encountered this on any car I've owned. Not a good thing - when on a date!!! The dealer has adjusted the Oxygen sensor - which has helped, but I have adjusted my driving somewhat, especially getting on the on-ramps.
10. Have had the front-end bushings replaced three times also. Usually hear a "thumping" noise when going over bumps. Dealer hasn't given me any problems so far.
All for now... thanks for listening and the good advice!
