What are the advantages of getting the 17 inches tires option rather than the 16 inches?
Same mileage, more hauling ability.
Awesome looks.
My husband liked the Vibe's looks more than the Matrix. I kind of preferred the Matrix and wanted stability control but he won.
We love our car but after owning BMWs we are kinda spoiled and wish it were a bit quieter (road noise - it IS quieter than all the rest in its class!) and that our year had offered telescoping sterring wheel, now standard.
Can I buy a Matrix without that option and buy a remote starter and install it in a remote starter dealer? or it will cost almost the same? or have problems with it or with the car? or the remote install by someone else will damage something and then Toyota will say that their not responsible for the damage caused by the remote starter and tell me that the warranty does not cover the damage and bla..bla..bla...?
What would you do?
I do mostly city driving with short distance on the freeway and take 1 road trip (vacation) each year in summer, usually from Upper State N.Y. to Florida but next year we plan to go to Washington State so got to cross the Rockies.
Will the 1.8 L be powerful enough to cross those mountains or I should go for the 2.4 L?
The 1.8 L or the 2.4 L?
I made it with a 4x30" piece of black foam core and a couple of cable ties.
I hope I save a little gas by warming up the engine faster.
2010 Toyota Matrix or 2010 Chevrolet HHR? and Why?
Andy
My friend told me that I can install 225/70/16 winter tires on the same rim.
Is it possible or I need the exact size?
On average I see 10 Matrix for 1 HHR.
How come? What's the reason for that?
Did you ever owned a black car?
If so, how was it?
If no, would you?
kcram - Pickups/Wagons Host
Some light reading for anyone interested.
We went to put new plates on vehicle and guess what folks - they are PLASTIC! The heads of 3 out of 4 of them simply broke off - leaving us to use a wrench - drill - and muscle to get out. I could not believe how they bent! I phoned dealership service department to see if they'd fix this for free (I know you are all laughing and slapping your knees) and of course they would not - claiming it would take 1/2 hour because they'd have to drill out the screw then re-whatever it's called to put new threads on the hole to hold another screw. At first I thought how ingenious to have plastic ones that won't rust - then I saw how the heads just popped off when trying to loosen screw and shook my head. If you own one - double check to see if they are plastic or metal and replace as soon as possible.
Send to: karen@edmunds.com
karen@edmunds.com
Here is a description of my problem:
Intermittent issue of gas pedal feeling "hard" as a rock and difficult to push down while driving (this occurs mostly on the highway when I'm driving at speeds 55+ mph. When I push down my gas pedal as hard as I can the car barely accelerates. When I finally get the pedal to move... acceleration happens in rigid and intense speeds. It almost feels like it jumps through 2-3 gears in seconds. That is the most severe. Other times... I just have very weak acceleration and it almost feels like my engine is flooding (you get that feeling of a lot of air going through the engine, but not actual acceleration).
Is anyone having this problem with their 2008 Matrix?
Speaking of accelerator pedal, the 08 Matrix use drive-by-wire accelerator. (electronic) It might part of the recall, Those are the same manufacturer of this parts. CTS who make this parts not Toyota!
Bob
I have a 04 toyota matrix & Im recently hearing some sort of vibration/resonance on my gas pedal and the sound of the engine has also increased . Have anyone ever experienced such a thing before if not any clue wat can be wrong ??
I would like to add that I just made a trip on it with a full capacity weight on it. I hve been hearing these vibrations soon after the trip.
1. Any -trix owners experiencing a light rattle from the front driver's side (small rock in a can sound) at low speed (driveway/parking lot) normally indicative of a strut top bushing or lower steering gear rattle?
2. Any of you regularly experiencing the camshaft timing gear actuator one second heat shield sounding screech at start-up on cold mornings? Is Toyota covering the cost of repair on this? GM has a news flash on it but I am uncertain whether they will cover the repair. Apparently the Equinox is also suffering from a similar camshaft timing gear issue.
The timing gear is my main concern. My valve tappet noise has gotten louder upon initial start-up, but normally dies down as the engine gets warmed up. I have been told that the camshaft actuator noise I experience (once a month) could also be causing the valve tappet noise.
Any comments/suggestions for these two issues?
Is this something we should be reporting to Toyota?
Will they do something about it??
