Pontiac Bonneville Owners: Accessories & Modifications
What modifications have you done to your Bonneville? And accessories? Please share!
KarenS
Owner's Clubs
KarenS
Owner's Clubs
3.25" Pulley
Flowmaster Mufflers
Saner Rear bar and Endlinks
Casper AFPR
AutotransInterceptor Removed
9" Cone-filter (Building CAI)
Front sway bar on order.
Shift Kit on order
I think that is all :-)
3.4" stout snout
RAT stage 2 MAF sensor
K&N air filter (drop in)
Magnacore plug wires
RAT adjustable fuel pressure regulator
transmission cooler
heat wrap on exhaust crossover
window tinting
painted brake calipers red
painted SSEi emblems gloss black
Sylvania cool blue headlights
Plasmablue Xenon fog lamp bulbs
I am waiting for someone to experiment with the SAE computer modifications, I want one but don't want to be the first to try it. Also am thinking about a shift kit.
Thats all for now!
Dan
http://gaugepods.com/
they provide custom A-pillar gauge mounts just as long as they get 20 or more advance orders. The prices seem pretty reasonable. Although I'd like to know what extra gauges would go on those pillars.
FYI
KZM
http://www.ramairtech.com/cgi-bin/pg-product_live.cgi?Pro=12&Pur=
1992-93 Bonneville Performance Kit
Features
Bolt on 35+HP
Easy installation
Performance Tuned Upgrade
Systemized Approach
Series 2 Power Levels for Series 1 Motors.
Add 35+hp with the RAT free-flowing cone filter air intake system, supercharger pulley and billet aluminum adjustable fuel pressure regulator
Do you know if K&N makes an airfilter for a 2001 ? Also, are the flowmaster mufflers bolt-on or do they require adapters ?
Any warrenty implications here ?
Regarding the K&N filter, I had seen in a previous post that the part to use was a K&N E-0940. I checked one out at the local Autozone store. It's a cone shaped filter. Now, when I look at the filter in my car, I don't see any way to get the K&N in there. I thought that maybe the existing square filter housing would just be removed & a short adapter put between the hose & filter, but then I noticed a good sized bundle of wires going into the air filter box. So, It doesn't look like the box can be tampered with.
How did you fit the K&N on your car? Is the E-0940 cone filter the one to use?
Inputs from anyone who has done this are appreciated. Pictures would be a bonus. Thanks!
I also thought about the cone - but am interested in what to do with those wires in the box?
Thanks for the correct part number. Now, I just need to find it around here. I may have to buy it online.
Dennis- Your right about the enclosure being tight. When I was checking it out to see if the cone would fit, I wondered how to even get the drop-in filter in there without messing it up.
It's too bad Thrasher doesn't make a unit for the Bonneville like they do for the GTP. I wonder how close the GTP version would be to fitting into the Bonneville?
http://www.thrasher-ep.com/L67_htm/cold%20air%20kit.shtm
My K&N is the rectangular drop in. I thought about the cone, but was afraid of degrading performance in summer from sucking hot engine compartment air.
Please let me know how the GTP intake mod goes.
Also, where do you get the pulleys for the supercharger?
Thrasher also has a modified pulley and remover/installer tool. You can see it here: http://www.thrasher-ep.com/store_ham/store.shtm
There is also a Magnuson Nose Drive kit; you can find it here:
http://www.grandprixstore.com/ and they offer a choice of pulley sizes. Personally, I would love to do the pulley mod but am afraid of the warranty issues right now.
My K&N Drop in filter:
And my Jet PCM:
Also, what are the downside effects of changing to a smaller pulley? Other than possible warranty issues? Does the gas mileage get real bad? Can't keep the car under the speed limit & the tickets start piling up? Failed the emissions test?
Stan
there is a guy I know from the grand prix club in Toronto who owns a tint detail shop and would likely do a good job. also , he loves the GP's and appreciates the Bonne's as well. he isnt the cheapest guy around - but he uses top quality stuff . . . if interested - i can send you his email and name . . . i think his shop is in the north end of the city, I havent been there, but thats what my memory says - ill check if you want.
as for CAI, i belive thrasher makes a kit that fits our cars, but going custom is a pretty simple idea. im having mine out in this weekend (crosses fingers) and its pretty straight forward. The difference in mine is that the guy uses a 4" dia. truck exhaust pipe that is bent at the shop. It is heavy duty and easily painable, (ive done mine black). its is attached to 4X3 rubber coupling on one end, (home depot) and the sensor just plugs into a small hole drilled into it. cone on the other end. PCM will get wiretied outta the way. Im going to use some heat wrap on the exhaust crossover pipe to help reduce the amount of heat in that area, and change the tstat to a 180.
Dennis
Thanks for the tinting place offer but I already have an appointment made for Monday here in town. I'll just stick with it.
Will the PCM be ok just tied out of the way then? I was just concerned about water and such when driving in the rain. I figured it was put in the box to protect it from the weather. They can be pretty hardy though I know. The air intake could be quite simple for me to do then. I already have a large K&N cone, 3" copper pipe, and a 4x3 rubber reducer from my CAI on my last car
Also, I just got back an e-mail from Superchips. They are making a Micro-Tuner that will work on the 3.8L Bonneville. They said to expect it in a couple of months!
http://www.superchips.com/domestic.htm
A little knowledge is a dangerous thing my friend, and I have so little I am practically a one man wrecking machine!
I supose, if the pcm gets wet there, and Im not sure it would be bad, it could be wrapped in a plastic bag or similar..
Ive got 2 winters under my hood, and havent noticed much in the way of dirt (I do clean it a lot though). My guess is the light assy keeps it protected.
I've always had the understanding that the PCM is in the air intake for cooling purposes. Otherwise they could have put it many other places that were protected. The air intake location will get a lot of airflow over the PCM box. If it is out in the open it may not get enough airflow to cool it properly. I wish there were some GM powertrain engineers lurking here that could provide some insight.
RB
The improvement in power is , well - simply astounding and extremely noticeable. Below is my story at the track following the install.
Argh - too much power! I had previously posted my 2000 SSEi's times here, and they were excellent @ 14.78 stock.
Had my 3.4 and cone installed Saturday, and hit Cayuga Dragway on Sunday. This track is legendary for not hooking up well (Im told) - and I hope its true.
First run with the mods on, and I did my normal start. Took it to 1800rpm, and stomped it on 3rd yellow. sat there spinning for an eternity, and slowly started to move forward - rpm's got wayyy up there, and the tranny dropped into 2nd gear and slowly i pulled away. It ended up that my 60ft on that run was very close to 3.0 !!!!! The run ended in the mid 15's. This was going to require a new strategy.
Feathered start on the next run, after an good cool down - and things got better. It was my best et for the day at 14.47, and the 60 was 2.26 - which has been a pretty consistent # for me in the last track visits with dumping it at the line.
I did , after a couple of practise runs (without cooling down cause the lanes were open) get a better 60 of 2.17 - but top end sucked without cooling down and came out 14.82.
Overall, I was very disappointed with my times - but it looks like I need more practice now to manage the improved performance.
Thats it for now.....thanks for listening...I feel better
Dennis
p.s. Thanks to Scott for the information on the install. It went without a hitch ! The old pulley didnt even "pop" - it practically slid off after 59,000KM.
It isnt a true dual, it does split at the back end off a wye. Then the mufflers and tips.
Dennis
Thanks for the info!
Love this car though.
iceman: That was my first thought. Get the chrome duals from the Grand Prix special edition, or similar. However I compared the Bonneville exhaust to the Grand Prix and it doesn't look like an easy swap. The bonneville exits the muffler on an angle due to the muffler position, where the Grand Prix has a staight shot out of the muffler.
What process (steps) did you follow, and has the paint helpup?
Since mine is black - blacked out tips might be cool
I wonder if the dual muffler and tips from the Seville would fit our cars?
Had my windows tinted and a remote starter installed today. I love the look, and hopefully it will keep interior temps down.
i have lots of black hi-temp paint left from painting my intake pipe for the cone i installed.
Stan
Stan
He printed out the directions from the computer for me, and I have tried their advice - which shows arrows and say to push back a bit and then lift up - Uh Uh! Hernia time.
Maybe ill just try the "grab and lift" method. Sounds like ill need one of theose Russian weight lifters from the 80's doing the 'clean and jerk" on my seat.
I really wanted it out for weight reduction at the track, and to disconnect my battery to reset the PCM after pulley and cone install.
