10 most common mech problems with S10 and Toyota Pickup?
                    Hey ive pritty much decided to get one or the other it will probablt be a late 80s early 90s modle nd id like to know the most common problems with each im looking for a reliable pickup and want to know the pros cons of each
The first-generation S-10s was also awful for rust; the newer ones are much better (the redesign took place sometime in the early 90s; don't remember the year).
Steve
Toyota may have redsigned the truck for the 89 model year, but when did you first see them on the road? I think the correct answer is 1988! So Eneth's assumption is partially correct.
Your post runs the S-10 into the ground but in your profile you state you LOVE all 3 of your vehicles. Sounds a little strange to me, or maybe just hypocritical. 3 clutches and the steering gear box is hardly the whole drive train, regardless of how many times you rebuilt. them. How many time did that little truck stick you on the side of the road some place? My guess is none. If it is such an awful truck I would have gotten rid of it long before 100K miles, or 10 years of service. If the only problem you have had on your Toyota was the bad clutch master cyl., them why did you post on the other pickup topic you have a problem with a clunk in the truck when shifting from 4th to 5th gear?! One other thing you mentioned was the very low mileage on the Toyota Tacoma, in my experience the clutch master rarely goes bad. I have seen many a truck and car with the original unit pushing 150K - 200K miles on it. So your reliability issue is not even truly based on your own personal experience.
When I go to post, under the box I type in there is a "post My Message" button and a "Check Spelling" button. I can't explain what is going on over there, maybe check your profile preferences and see if you selected auto spell check. I did that on my mail program by accident.
