Oldsmobile Calais -145k Worth fixing?
                    Where did my message go?!!!!!! (Why were my first two messages deleted?  Now I have to type my problem all over again!)
I have an '87 Olds Calais V6 auto.
It has 145,700 miles on it.
Here's the problem:
After I drive for a little while (probably only 20 miles at this point), and then slow down from 35mph or above, sometimes the car will shake/studder, and then when slowed down, will die out. It will start back up fine, but as soon as I put it in gear, it dies out again. I've tried to give it some gas in neutral, and then switch into drive, but it just jumps forward and stops (similar to how it jerks when driving a manual, and not giving enough gas when letting off the clutch)
If I let it sit for a few minutes, it eventually goes into gear without quitting, and I can drive it.....at least until I have to slow down again.
I talked to a mechanic and he said it's the TCC (transaxle converter clutch) solenoid. With parts and labor it would be over $300, maybe $400.
Does anyone have any idea about this?
He said that only from what I told him, so...I don't know...
Also, I have trouble code 44 coming up, which is the oxygen sensor/lean exhaust code, but I don't know if that would be it, maybe that's yet another problem.
Thanks for your time.
Here's the problem:
.....but that depends on it's location, I guess.
Is it possible to do this work myself?
(seems unlikely, considering the mechanic said he doubted anyone around could do the work(he's ASE certified and says he know all the guys in the shops around here)...but maybe he was just saying that)
O.K., so what did I do about it? Well, with the mileage on my Pontiac there was little point to paying for the extensive labor to remove the transaxle and repair or replace the torque converter and clutch without doing a total rebuild of the transmission. This was the universal recommendation of the people I talked with --"Rebuild the whole thing." Like you I hesitated at the expense, especially since my car was still fully drivable and, other than the occasional shudder, the transmission worked fine. I asked a transmission shop if it was possible to "pull the wire" that engaged the TCC and just drive the car without it ever engaging. (I knew that on earlier TCC designs it was just a single wire connected to the TCC.) He said it was part of a large harness and trying to run the car that way would "tear up the transmission". This didn't make sense to me, as the clutch won't engage at all until the engine is fully warmed up. Even then it only engages at cruising speed and will disengage at the most modest of acceleration. I went to the library and did some research of my own. After looking through several manuals I found one that showed a detaled wiring diagram for my car. It showed the exact wire on the transmission harness that controlled the TCC. I found the wire, cut it, and installed a quick connect so I can reconnect it any time I want to. Presto! The TCC never engages and my shudder no longer occurs. I've since talked with another mechanic and he assured me this would not harm the transmission itself in any way (as I thought as well) and the only ill effect would be to fuel economy. I did note an immediate drop in strict highway fuel economy of 2 to 3 miles per gallon. the effect on combined city/highway or all city driving is negligable, again, all as I would expect. The only other "problem" is that every time the computer calls for the TCC to engage, it detects that it doesn't and momentarily lights the "service engine soon" light on the dash.
I share all of this only to give you a low cost alternative to think about. It is at your own risk. Remember, one shop did warn that this type of "band-aid" would be harmful to the transmission. I figured I had nothing to loose and the car has been running with the TCC disabled for about twenty thousand miles so far with no further problem. As for the slightly reduced fuel economy, well it will take one heck of a lot of driving to have that even begin to approach the cost of a new transmission. Good luck!
Couldn't you have just disconnected the electrical connector? I don't know...I'm referring to the one on this page:
Click here
Or would that mess up the whole transmission?
Well, I could at least try to replace the solenoid. That page has a good explanation for a Monte Carlo SS, and I know an Olds won't be "much" different. (except for way more oil and dirt on the bottom of the pan, lol)
Thanks for you response, and tell me if you think I should try this.
The parts and tools would add up to less than $100, and I'd still have a cool oil change pump(refer to bottom of that web page).
the link you provided shows a 200-4R rear wheel drive transmission. Your vehicle is equipped with a front wheel drive transaxle. The TCC solenoid on yours is located behind the valve body cover on the left (driver's) side of the vehicle.
kruzer1:
read post #'s 440, 450, 452, 453, and especially 460 in Transmission Trauma topic area. You might have been driving for 20,000 miles with the TCC disabled because your car needs spark plug wires. That's the #1 cause of perceived converter clutch shudder with G.M. 3.8 and 3800 engines.
Make certain of the exact transaxle you have and have the correct documentation before you try anything. I couldn't just unplug my harness as that would disable control of my electronically controlled transmission. Good luck and let us know your final outcome.
Alcan:
Thanks very much for the references above. When my trouble first started I changed plugs and wires on the advice of the transmission shop. I then had the car "scope checked" and checked for any error codes. Everything checked O.K. I'm not sure if the computer in my '92 stores a code for misfires. I thought it would, but I'm not sure. I found the post about aftermarket wires most interesting, as that's what I installed. I thing they're MSW. Maybe it would be worth trying a new GM set. My symptoms don't quite jive with the other posts in the following ways:
My "shudder" lasts only momentarily as the TCC locks up. --maybe 1 to 2 seconds. Once it's locked there is no further disturbance, even at low speed and very low RPM. Anything that causes the TCC to unlock and then relock (like a quick tap on the brake) causes the momentary shudder to re-occur. Also, the problem is actually more pronounced at higher speeds. At 65 to 70 MPH, say after making a pass, the engagement really shakes and you can visably see the needle on the tach bounce up and down a bit. Again this lasts for a little over a second and then all is smooth until the next time the TCC cycles. This led me to believe it is actually the clutch being sluggish to engage. What do you think? Thanks!
Anyway, I've read the posts here and wonder what I should do. I cannot do the work myself. Does anyone have advice as to how much this repair should cost and how I can know for sure that this is the problem? Also, should I go to a transmission specialist for the repair or can most mechanics do it? I live in Seattle. Thanks.
Sounds like the TCC solenoid. I'm going to change mine myself. Not worth the $$$$$$ to have someone else do it.
I don't know a whole lot about cars, but I've done quite a few repairs(fuel pump, wheel bearing, alternator, starter, fuel filter)
The problem is, I took insurance off my car when I got a new one. I still want to fix it, but I can't do it on my 45 degree angle driveway in my trailer park.
I guess I'll have to put insurance on it for a day or two, and drive over behind Autozone LOL, when I have a day to spare, that is.
They disconnected the damn thing. I had the dealer give an estimate:500 dollars. My folks have also had no problem and the thing seems to have better pick up with out the lock-up.
I hear this all the time on Leon Kaplan's KABC radio car repair show and it's always the same thing:defective or corroded torque converter switch.Seems to be a common problem.
Best Wishes and luck to you.
