Subaru Impreza WRX Wagon
-Colin
"Solo II Novice Handbook" by Kate Hughes
http://www.tirerack.com/features/solo2/handbook.htm
and
Secrets of Solo Racing by Henry A Watts - $14.95 from most large booksellers. Amazon has it too.
These have lots of good advice. I'm planning to do the same some time soon. Hope you have a great time.
Tim
What do you think? Think Subaru will make the mod in '03?
Thanx Tmeout
Should I be concerned about a fairly long trip (about 450 highway miles, round-trip) early in the break-in period? I know the deal about varying RPMs and staying under 4000 RPM, so I had just planned to stay off the cruise control and conciously vary my speed. We'll probably also make one or two stops along the way, on each leg. If I'm careful about it, should I be OK?
I was looking through www.nhtsa.dot.gov at the Problem and Issues section for Subaru's. I found under customer complaints something shocking and very disturbing! Here is a summary of over 20 issues on bad brakes:
"THE BRAKING SYSTEM OFTEN FAILS WHEN THE BRAKES ARE APPLIED WHILE TRAVELLING OVER A ROUGH OR BUMPY SURFACE, REGARDLESS OF SPEED (I HAVE HAD IT OCCUR SEVERAL TIMES, FROM 5 TO 35 MPH). IN THESE CASES THE ABS IS WRONGFULLY TRIGGERED UNDER MILD BRAKING, THEN THE VAST MAJORITY OF BRAKING POWER IS LOST AND THE CAR BARELY STOPS AT ALL. THIS BRAKING IS COMPLETELY DIFFERENT IN FEEL AND PERFORMANCE FROM THE ABS FUNCTIONING PROPERLY ( I.E. VERY HARD BRAKING ON A SMOOTH SURFACE. THE BRAKES WORK FINE IN THESE CASES.). THIS IS A COMMON PROBLEM THAT I AM HEARING ABOUT FROM OTHER 2002 IMPREZA/WRX OWNERS."
Have any of you had this problem? Please reply.
Thanks, Heather
I wouldn't zero in on the WRX with that "problem".
I think it's a problem with the ABS in general (industry) and I think it's tough to replicate. The condition(s) has to be right (wrong) to produce such an effect.
I have the '98 OB and had had that experience, so it is not a WRX "problem". I have since I upped the psi on my OB to 34/33 and have not encounter this... until the next right (wrong) condition(s) is met - hope not.
-Dave
What they found was that when most abs systems engage on ice, they do a decent job of stopping, but don't allow the wheel to respond to steering input. When the abs system releases the brakes on a very slippery surface, it takes a while for the wheel to start gripping and start turning again. The WRX abs system uses less braking force and pumps the brakes slower allowing the wheels to begin spinning again and giving the driver better steering control.
I found this very noticable when driving in snow. On all of the other abs cars that I have owned, once the abs system kicks in, the car slows down better, but almost all steering input is ignored. My WRX retains much better steering response than other my other cars once the abs kicks in.
These things are usually a trade off. Do you want to retain steering input, or better braking. Current technology doesn't really let you have both. That said, Subaru may have gone a little too far in one direction especially when the abs system kicks in on non-slippery surfaces when you would expect to have better traction. The abs system might also be a little to sensitive and engage at times when it's not really needed. Again, a trade off because on really slippery surfaces, you want it to kick in as soon as possible.
This may also provide an explanation for the WRX's less than stellar 60-0 braking numbers.
So basically what you have is an abs system that probably works as intended, but is so different than what people are used to that it makes them uncomfortable. I personally haven't run into this problem. I haven't had the system engage unexpectedly on dry roads, and prefer the way it works on extremely slippery surfaces.
that's not the best way to stop fast.
-Colin
Date of Failure: 04/26/2002
Component: BRAKES:HYDRAULIC:ANTI-SKID SYSTEM
Summary: BRAKE WAS APPLIED AT 35 MPH, PEDAL WENT TO THE FLOOR, NO BRAKING ACTION. ON SECOND ATTEMPT BRAKE GRABBED. DEALER REPLACED ABS MODULATOR.*AK
sound familiar? Apparently it's just a design artifact of ABS, possibly made worse by the 16" wheels, several people have said 17" wheels have helped (though I'm still gonna start with the 16"s); if it is particularly extreme in certain vehicles, it's probably due to an overly sensitive modulator unit.
personally, I didn't get the slightest hint of brake problems on the car I drove the other day at the dealer, in fact the brakes were noticeably stronger than in either of my two honda accords (one too many... ;-)
tmetravler wrote: They could have done it even, just to seperate wrx wag vs. 2.5 wag??
What do you think?
Personally, I think 62hp separates the wrx vs the 2.5, that's good enuf for me ;-)
Like Wheeldog (who posted before in MSG #1904) I'll be picking up my silver Rex wagon this week. I can honestly say that this is the first car since my '87 CRX that I'm actually thrilled to be purchasing.
I live in the Minneapolis/Saint Paul area and for $23,950 we got the car with the following options: bumper cover, added security system, mirror with compass, cargo tray and net, air filtration system, rear differential protector, rubber floor mats, and (as a specialty item) dealer installed heated seats. Essentially, we came in about $450.00 above true market value - which is what we're being charged for the heated seats.
So, if you're in this area and are looking for the Rex, the TMV seems to be accurate.
Also, like Wheeldog we're looking to take a Memorial weekend trip - any feedback on break-in and the like?
Thanks again,
DigiDawg
Vary your speed
Don't go above 4000 RPM
There are more details in the manual
I'm in Mpls near the Mississippi and the Falls. Only seen one silver wagon so far. Mine's black (the color everyone says is so hard to keep clean). Buddy at work has a blue wagon. Almost no one around here seems to know much about the WRX except guys in Hondas and Acuras. I'll look for you. Enjoy!
SOCPROFINBLREX (THOMAS)
Revka
Hatchbacks & Station Wagons Boards
Thanks - I'm really looking forward to picking up my new wagon. I found an excuse to drive by my dealership today so that I could visit my car. I found it sitting with a 'sold' tag on the rear view mirror, and with the options that I had asked to be added (gauge package and rear bumper cover).
Digidawg,
Congratulations on your new purchase - excellent choice!
Perhaps, if we go on this trip, we'll just take twisting, turning backroads, etc. so that we can vary our speed - oh, the suffering and sacrifice one needs to make (grin)
Funny that the color gets mentioned in the above post. One of the reasons that we're getting the silver rex is a concession to my wife's sensibilities about keeping the car clean ('course, that's because she's the one who's actually responsible enough to do that regularly -Je m'accuse).
If it were just me, I think I'd probably lean toward the blue or the red, but we're talking shades of a degree here - I like all the colors.
So, have you had trouble keeping it clean? And, any paint chipping issues as it relates to that color?
By the way SOCPROFINBLREX (THOMAS), we're within rock throwing distance of each other here in the frozen tundra. We live on the eastern edge of Lake Nokomis. Look forward to seeing your Rex in the environs...
DigiDawg
-juice
...and then I saw 50k miles per year. well, I'll shaddup now because that's plenty to feel the $.14 - .20 difference in US dollars.
-Colin
add-ons: electrochromic mirror, security system upgrade, cargo net, bumper cover, rear diff. protector, roof cross bars, armrest extension, wheel locks
final price: 22,950 (a fabulous price on its own, but don't be too jealous tho, cuz they pretty much socked it to me on the trade-in... but what can ya do, I GOTTA HAVE THIS CAR)
hys
Break in periods (I recently passed 1000mi.) seem to take forever, but you've been without the car for decades, a few more weeks won't kill you. I kept it under 3000 for the first 500mi and under 4000 for the next 500, then I couldn't resist, and have been winding it out every chance I get. :-)
(Don't look for the spark plugs, it's depressing to think that you'll have to pay somebody to replace them.)
Good luck and congrats to all you new owners. I know I'm enjoying mine.
My dealer has a new-owners meeting once a month, mine's tonite. See what useless things they have to say to me.
Russ: if you ask about using regular gas in one sentence, and then 1/4 miles times in the next, this may not be the car for you. If you're ever going to explore those 1/4 mile times, stick with premium.
I imagine a knock sensor will retard timing with regular, but you would lose even low end torque, not just top end power.
That plus an auto tranny would sort of kill the whole purpose of owning a WRX. IMO the 2.5l engine in the RS or Outback Sport may be better suited to your 87 octane needs and 50k miles/year pace. You'll likely get 26-30 mpg on those highway drives on cheap ol' regular.
-juice
2 days with the Rex and I'm quite happy. Couple issues with which we are dealing that I thought I'd pass along; my wife and I are in the 5' 7" range and have found that the armrest extension clunks into our elbows while shifting. In fact, while test driving this was quite the turn-off, but we were told it was an option not a standard feature. The car we purchased came with the extension and is to be removed next week. In the two days of driving I've whacked myself pretty good, so - if you're "stump daddy" size - you might wish to reconsider.
Also, we decided to get the clear coat finish after talking with a local rex owner. He's got a beautiful blue sedan that's less than five months old that has little paint chips in the front fenders already. He wishes that he had clear coated his too.
So far, we love the car a lot. Waiting for the first thousand to pass will be a test of patience...
DigiDawg
-mike
-mike
Stephen
Paint
Clearcoat Finish
Fog Lamps
Black Rocker panel protectors
REAL Glass windows
caps for the valve stems
headlights and taillights
-mike
Automatic tranny - this is up to your taste... Performance is still very good, it's just less fun. From what I remember, Corvette sells more automatic transmittion cars than manual. But WRX ain't no Corvette.
For Paisan and company - as far as the clear coat goes, -yes I'm aware that clear coating is quite common. This is an extra layer of protection that I was willing to buy after seeing (on sites like this) and speaking to (neighbor with a Rex) folks who've had paint problems with the car. As well, the Subaru guarantee (if I understand correctly) does not deal with rust caused by road salt. Well, in Minnesota, that's THE main cause of body cancer on cars. We got a ten year warranty on rust-through pertaining to any and all forms with the added layer of protection.
A local auto scribe, Paul Brand of the Star Tribune (who's quite respected),recommends this in our climate so we felt that this was the only dealer add-on that had any merit. Seemed to us rather prudent after seeing a five month old Rex with a few chips. Dunno - I guess time will tell on this one.
You folks have had negative experiences with this type of service? Its not something for which I would have typically bitten but, based on the a priori info, I thought it might have been a good decision. Comments welcome.
Nixomose - thanks for the insight. They must build these cars for Americans of standard height. Being short, (by American standards) I run into this type of thing often enough. Glad that it works for you. If they could just saw off two inches I'm sure I'd enjoy it as you are! :-)
Great group - appreciate it.
DigiDawg
-Colin
Gary
All manufacturers rust warranties are for rusting from inside out. If you lose paint and primer and have exposed metal on any exterior surface which is not repaired, there is no manufacturer which warranties that. Also any after market rustproofing which involves drilling holes in closed compartments will automatically void your factory rust warranty. Some of those box sections once galvanised and painted aren't supposed to be messed with ever again and if you do, you are on your own as far as the manufacturer is concerned.
Do you need to have annual inspections for this protection package? The one I got made you do that. Only good thing about it the first few years I complied was that you got a hand carwash in January! Had to pay some token fee for that inspection though. The company providing the warranty went bust too,found that out when the inspection place no longer did inspections! But for a price they had another product and company to reprotect my, by now, slightly old car!
-mike
good luck with your purchase decision,
Phil
Thanks in advance for any assistance. (PS: I complained earlier about the shifting, and as several of you predicted, I'm definitely getting used to it, and I think it's actually changing\easing a little after 2500 miles.)
The seats may feel a little firm at first, but I have found them very comfortable on long trips (considerably more comfortable than softer seats) as well as very supportive in harder driving. If you're a bit large, the bolstering may be a little tight, but you can get your dealer to change that for you.
There is a little road noise from the big tyres, but, again, I find it quite acceptable at freeway speeds.
I quite regularly do a 250-mile trip in one stint and have found the WRX more than comfortable enough for the purpose, and have done several longer trips, and have had no complaints.
So, yes, it's quite practical as a daily driver. But, on a Sunday morning, find a stretch of deserted, twisty road and go a drive. If you don't come back smiling I'd recommend a visit to your doctor
The Corvettes naturally aspirated V8 also works a whole heck of a lot better with a manual transmission too, than Subaru's small turbo H4 does. So what is the point ??
The Automatics and the Manuals both have turbo lag right off idle, but both of them take off like bats out of hell, when the turbo spools up, which is at any speed about 15mph, which is where I do 99% of my driving.
The Automatic is a great commuter car and offers thrilling acceleration when needed and superior handling, when compared to a lot of others on the road, including the manual-WRX, primarily by being equipped with sportier springs than the manual-WRX and by the better power re-distribution afforded by the kick-[non-permissible content removed] AWD system of the Auto-WRX, that the manual-WRX lacks.
The manual-WRX however, offers better control over the gears, which is a big plus, inspite of its other lacks when compared to the Auto-WRX.
Later...AH
Additional rust protection is usually sold as "under-coating" or some variation of the term. At best this procedure (if it's even done, dealers have been known to charge for such things and never do anything since its hard for the buyer to tell the difference) may provide a slight improvement in reducing road noise. At worst if can actually void the manufacturer's warranty (as pointed out above). In fact, improperly applied, it can actually accelerate body/frame rust by trapping moisture next to metal. The statement that the manufacturer's rust warranty doesn't cover road salt is also false.
Re clear-coating: In the past, this term has meant nothing more than the dealer waxing the vehicle (which could actually cause harm if the paint isn't fully cured). Also as previously mentioned, Stongard is a clear acrylic product that is applied to the front end and reportedly provides excellent protection from paint chips caused by road debris. However, I've yet to see a dealer offer to install Stongard so I suspect that what you really paid for was a very expensive wax job.
-Frank P.
Rob
They seem very well made, but yet they're reasonably priced. A lot of the cost of the more expensive wheels is in the brand. The OZs and BBS are lighter than Rotas, but they're double the cost per wheel. I've been very pleased with my investment.
-mike
