Mazda MX-5 Miata Accessories & Modifications
link title
go there and check it out!
Here's what I mean - the stock 14"x6" rims weigh just 12 lbs or so. The BBS rims on some SE models weighed just *nine* pounds.
Even forged 17"s will probably weight close to double, maybe even more. You'll have to swap out the whole suspension else the wheel will be hopping up and down overwhelming the shocks that just can't handle that kind of unsprung weight.
I just think 17" is too radical. That's my opinion, anyway.
-juice
I had quotes ranging from $500 to $599 for mine. I will get it done after I take it out of Winter storage. I did it to my 530i - the entire front - 3 years ago and it has eliminated any front end scaring.
You do give up the option to drive with the "bikini top", i.e. all windows open but the top up.
I was OK with that.
-juice
I had to add those two straps that pull one of the beams down while you are lowering the top. Some times it sort of snags on the vinyl, I have to manuall push the window glass down slightly to get it to go all the way down. That doesn't happen in warm weather because the vinyl is more flexible, but when it's cold and the vinyl is hard, it's tougher to get the top down.
That may be the non-professional install job, though, so it's hard to say.
There are a couple of minor wrinkles near the rear window, but no wind or water leaks, anything like that..
-juice
Thanks Juice!
-juice
Took a day to remove the old one, a day to put that on. Not an easy job! Get help if you do it yourself. Get a cordless drill to help, too.
-juice
I love almost everything about the car, but the Bose stereo in the GT was very disappointing. The speakers are clearly in need of an upgrade, but it is difficult to tell if the head unit will drive a good set of speakers effectively.
It also looks like it would be pretty difficult to add aftermarket units that would fit cleanly.
Any recommendations on audio upgrades?
I have an 06 MX-5 Miata, my question is, can the head light beam be adjusted-cars at night are flashing there lights.
Can't get an answer from the dealer.
Don
I have done many high-end, aftermarket audio upgrades from ADS etc. but I am pleased without an upgrade in the GT. I moastly listen to Sirius Sat.
Evidently, both the Sirius and IPOD integration unit use the same input so you can only use one or the other.
The dealer says that a new version for the IPOD integration unit that is compatible with a Sirius installation has currently just released in Japan and will be available soon.
Bummer, really looking forward to playing my IPOD in my new car but I guess I have to continue to wait.
I did replace my horn, but with a slightly louder "honk" rather than the wimpy OE "beep".
Due to the flimsy fiberglass bumper, the clips will not hold on, ast he bumper flexes and releases the clip. It also sits the bike quite low to the ground.
Has anyone encountered a rack tha works better or have a solution? Our guy at the regular local bike shop advised the easiest solution may be to have a mechanic DRILL from underneath the vehicle into the steel/aluminum under the fiberglass bumper and affix some sort of eyelet to allow a stabe strong clipping to occur.
Apparently a hitch rack and of course a roof rack is not an option.
Please email directly with any known solutions.
ggusta@gmail.com
Why? Well, officially, the Miata isn't rated for towing. A rack and a couple of bikes will probably put a good 100-120 lbs or so of tongue weight. Payload for mine is only 360 lbs to begin with, so with 2 people inside it's already overloaded.
Any how, companies do make hitches that fit. The tie-down hooks come off, and the hitch bolts in their place, behind the bumper.
I still would not recommend this. I'm 205 lbs, add the wife and we're over 300, add a bike rack and two bikes and we'd be well over the rated payload.
The OE stereo sends very little sound to the headrest speakers. They get much less wattage than the door speakers do. I've seen mods where people change that on Miata.net.
http://www.gomiata.com/
The aftermarket for these cars is strong...more stuff that I could ever buy in a lifetime.
I think I got my top from Go Miata. I'm still on their mailing list. Once in a while they have free shipping specials. Register so you get those types of offers.
-Thanks
