BMW 5-Series Maintenance and Repair
I am wondering if folks have any recommendations for repairing scratches on paint. My bumper got scraped and I want to see what I can do.
Works good for little rock chip scratches...
Any recommendations for chip fillers?
There are two screws located behind the whole headlight assembly. Unscrew those. Also you must remove the plastic "filler trim" under the headlight assembly from the outside.
The whole headlight assembly will then pull forward from the car.
On the top of the assembly, you will see two plastic clips...these are the ones that can break easily if you do not take your time. Carefully pry them up a LIITLE with a small screwdriver. The clear plastic will seperate from the assembly with a little coaxing, as there is a gasket that seals it pretty tightly together.
Zeen
I finally put some grease on a piece of hard paper and slid it between the door frame and the vinyl. The noise was gone. I have usually been able to eliminate rubbing noises this way.
Any ideas what could be causing this. Have talked to some who say some 528's have this problem.
Thanks, Rich
First, my computer indicated that I was low on washer fluid. This was true, and I filled up the container under the hood. However, the indicator continues to go off every time I use the car.
Next, all my computer settings (date/time, mpg, average speed, speed limit, etc.) were wiped out for no apparent reason.
Next, on one occasion only, the speedometer and mpg gauge stopped working one night. The next day they worked, and they have worked since (about 5 days).
Has anybody else experienced these problems and had them resolved?
Any advice would be appreciated.
I too have the same problem in my 2000’528iA. The noise appears at speeds between 75-80Mph only when the gas pedal is lightly pressed. If I release the pedal or press it harder, the noise goes away. The noise doesn’t appear at any other speed and it doesn’t affect the performance of the car in any way.
I scheduled a service appointment to have the problem fixed; however, the caveat is that I had already taken the car to service before I saw the aforementioned post and sure enough they hadn’t found anything wrong with the car. This time though I mentioned to them that somebody else had had such a problem and that it had been fixed. They said it would be useful if I could find out what exactly had been fixed. So, I’m wondering if somebody had this problem, if it was fixed, and if so then what exactly was fixed.
Thanks in advance.
K.
My car also has very noisy brakes. see my no. 13 post.
THanks
Rich
you can email me directly at luckyman6777@hotmail.com
Anyone encountered this before? Any good advice?
We both have a 2001 525. I went to the dealer (as did he) and had them program two of my keys. This would hopefully allow both my wife and me to be able to open the door and have the seat in the correct position.
The dealer said that the key remembers the last person to use the key and would put the seat back in the position it was when that key was used.
This has never worked. I thought I was going nuts until my friend said the same thing happens to him and his wife.
Does anyone have a good explanation of how this works.
Question #1 I live in the Midwest and snow is a problem. Both dealers have told me I will have to replace the 17" tires with 16" all weather tires in winter. One dealer also indicated that the car still will not handle very well, even with the 16's, because of the sport suspension.
Question #2 If all of the above is true, does the suspension make enough of a difference in performance to warrant the additional expense involved with a second set of tires and rims?
We went on a ski trip last April, and his was the only car that could not make it up the mountain to our condo. Even my RWD 5-series BMW made it up with no problem. Even getting his car moving on a flat surface, with some pushing, was a problem in the snow. The traction was terrible.
I therefore think that based upon where you live, a set of winter tires is necessary at a minimum to make sure that you can get around. Try to find out if others have used them and how effective they are. That I don't know, but I do know that with a sport suspension and regular tires, you will go through hell in the winter in snowy areas of the midwest.
Lar
Lar
Ty Bowink@cfl.rr .com
I found the sport suspensions I have driven have increased cornering ability and are confidence inspiring. However, while not harsh, they are in a word abrupt. In handling interstate road imperfections it can be annoying and not as enjoyable on long trips as the standard suspension.
My 2001 525iat sport wagon has a perfect 50-50 weight distribution and handles like a sports car.
The all season COntinential H rated tires are a great compromise and handle very well in snow and ice. In fact it is all but impossible to lose control on solid ice due first and foremost to the skid control program. This would no be true with the sport suspension standard summer tires.
Hope this helps.
Spyderred
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
This has never worked."
I was told the same thing by my salesman with my 2002 530i. I never saw a response to klevey's note. Is the salesman correct? If so, any ideas on what we could possibly be doing wrong?
Gerry
The car always assigns the profile when you press a memory button so you can always reassign a key. The only thing that is bound to the key is DRLs and double-click all door unlock.
As a note, we had to have the programming done twice, I guess they just didn't get it right the first time. After that, everything worked the way it should. If you just can't seem to make it happen, take it back to the dealer and show them.
Many European cars initially feel like they have hard seats. But when you drive them long distances they are quite comfortable. A soft, initially comfortable seat can be brutal on long trips.
Did you buy CPO? Have you had a dealer look at it? Have you checked list of TSB's for your year's model to see if there has been one on seats?
Give it some time. Take it on a long trip. Adjust, adjust, adjust.
