Tire Pressure??
Does anyone know the right tire pressure for
P175 70R 13 tires? I got new tires the other day. I used my tire gauge two of them were 38 psi, the other two around 36psi. Since their not all equal, I was wondering if anyone knows what is the right pressure for this particular tire size. thanks.
now, if it looks like you have a little volcano of rubber coming up on the side, or a big watery-looking blister that shimmies as you run your finger across it, you DO have a big problem possibly happening... a delamination of the casing. any tire tech who can tell flat from inflated should be able to tell at a glance and a finger-poke if you have an issue ready to be adjusted onto a new tire under warranty.
It is prudent to add some pressure to protect the tire when you turn as up to 400 pounds of additional weight could be placed on the tire during the turn. 3-4 psi is enough [unless you're turning all the time. Generally the front tires have the highest load so they are the critical ones except when car and trunk is loaded down to max then the loads may be equal so best policy is to have equal pressure front and rear. Certain rear drive loaded [1000 extra pounds] luxosports may need higher rear pressures under certain conditions.
24psi for a truck tire is kinda low. I am running LT285/75/R16 BFG's on my truck at 52PSI max is 65psi
When I got my van last summer, Mazda originally had the tire pressure at 32lbs. Winter, they made a tire pressure "recall" and reset that to 35lbs, and sent us a door sticker. I liked the slight improvement it made on handling.
So Spring, I set it to 40lbs. Immediately the van felt a lot more substantial, more stable, leaned less on turns, and improved mileage.
I had been planning to slowly reduce tire pressure to compromise handling and ride. If g45man is right, 38 or 39lbs should be within 3 to 4 lbs the recommended pressure.
But since I love to take turns fast (more than one person has commented on this), I may keep 40lbs yet.
Can some tire experts share their insight on how safe(or unsafe) this is?
so im ok at 40lbs then - now i'm happy.
...hmmm :-O maybe i should try bumping that up and see what happens.
The minimum is 28 PSI the maximum is 38 psi. same pressure front and rear. I use 36 psi at all 4 corners.
i wonder why...
29 psi is only 66% of max safe COLD pressure for most tires [44 psi] something like 35 psi COLD is 80%.....generally a 3 psi increase [over tire placard] will result in slighty improved tire life and mpg!
If you are concerned with best handling in curves you must get more envolved at calculate the correct pressure.
I think on a FWD car tire rotation (front to back, not criss-cross) is a good idea. I'm not sure about the mileage, but if you're a hard driver with a FWD car with some HP, every 5,000 wouldn't be too soon IMO.
