You are assuming that the mysterious and ethereal "they" know what they are talking about. :-)
Thank God Slick Willie isn't in charge.
I can't help but notice that Hillary hasn't had much to say. I wonder why.
And speaking of gas/electric hybrid, they do make sense even if the bottom line gas mileage isn't stellar. Think of the NSX hybrid as an economical supercharger.
I merely stated that people from Texas should not comment on driving in snow because of their laughable level of knowledge and skill on this subject. The only thing laughable about my knowledge on snow driving is that I got more today. Yes, April six and more fresh snow.
I do not want an award for living in Siberia er. Saskatchewan and having to live with a very long winter.
I do however think that my opinion on dealing with this kind of road condition should be revered over that of a Texan with nothing to back up anything he says. Seems to be a common trait among among Texans these days.
Can you hear the applause ??
IdahoDoug
Agreed!
"Why did truck-based SUVs suddenly become popular just as Detroit shifted to front-wheel drive for its passenger cars? Was it (as anti-SUV activists claim) because the SUVs were exempt from various safety and economy standards -- or because the SUVs still had rear-wheel drive, with all its subtle satisfactions?"
Why Front-Wheel-Drive Sucks (Slate)
I think you missed an important point in your article, a very important point.
Natural human instinct.
Absent any training specific to the incident at hand, say like in an aircraft flight simulator, what does your mind tell you to do the very INSTANT things go wrong?
Hesitate, think, ACT!
In a RWD vehicle in adverse roadbed conditions when the rear end starts to come "about" (the most common circumstance in RWD) your natural instinct will cause you to lift your foot from the throttle. That, in turn, will result in the rear wheels going from being driven to providing drag on the vehicle, sort of like throwing an anchor out the rear of a boat floating downstream.
Conversely, in a FWD vehicle on adverse roadbed conditions when it begins to understeer (the most common circumstance for FWD) your human instinct will still cause you to react in the same way, lift the throttle foot. Now you've just succeeded in throwing the anchor over the bow of the boat, applying front braking via engine drag, and you're likely to go from understeering to oversteering in a big hurry.
Regardless of the result, as you can see, driving a RWD vehicle on adverse roadbed conditions will always be more benign than FWD. Again, absent specific situational training.
Willard West
On a FWD vehicle at the limit of adhesion (thus it's sliding), stepping off the gas does not cause the rear end to break loose in a typical car (some racing exceptions). Why? The front contact patches were using X percent of their friction for the cornering force, and Y percent for the acceleration (forward or rearward) force before you let off the gas. After you let off the gas, they are still using X percent to corner, but now Y has diminished as the power from the engine is replaced by the much lesser amount from engine breaking. So, this is a relatively benign thing to do compared to a RWD car which we'll now look at.
On a RWD car, the rears typically come loose into understeer at the limit (exceptions abound). Letting off the gas instantly transfers weight off the rear wheels, reducing available traction. If the car was already at the limit of the rear wheels, this will likely cause them to slide more and faster.
I'm surprised you are not aware of this as you mentioned you are a Porsche owner. The Porsche 911 series - the signature vehicle of the corporation - has been synonymous with oversteer for over 20 years. The term "drop throttle oversteer" was coined for the 911 series, which had a nasty habit of oversteering rapidly and wickedly when the driver backed off the gas at the limit.
So, RWD is far more dangerous when cornering at the limit. Having said that, it is also worth noting that my position is accurate in general, but it is possible to design a FWD vehicle that oversteers or a RWD vehicle that understeers.
IdahoDoug (once a victim of 911 drop throttle oversteer myself, BTW)
And you're absolutely correct again, stepping off the gas does not cause the rear end to break loose, especially not in the FWD vehicle of your example.
Okay, I'll bite......
All cars (all objects for that matter) have a "center of gravity". Briefly, it might be described as a 3D balance point for the vehicle. The "polar moment of inertia" describes how the vehicles mass is distributed about the center of gravity.
Example: Cars 'A' and 'B' both have perfect 50/50 weight distribution. The center of gravity would be located midway between the front and rear axles. But Car 'A' may have a larger portion of it's weight way out over both axles (large moment of inertia) while Car 'B' may have it's weight tucked in much closer to the actual center of gravity (small moment of inertia).
Okay, now I'm gonna go out on a limb (I'll let idahodoug and wwest correct me when I stray); vehicles with large moments of inertia would tend to be more stable in a straight line and resist turning movements. Vehicles with a small moment of inertia, because the weight is tucked in close, tend to 'turn in' quicker. They are more responsive. They also may tend to swap ends quicker.
FWD vehicles, in addition to the problem of poor weight distribution (typically around 60/40) have the majority of that up front weight over (or even in front of) the front axle. This tends to exacerbate the problem of understeer due to the large moment of inertia. On the other hand, a mid-engine car (Toyota's MR2 for example) typically has a fairly small moment of inertia which adds to the responsiveness of the car (and also a tendency to swap ends easily).
Think of the old analogy of a spinning ice skater: the CG doesn't move but with the arms out (larger moment of inertia), the skater spins slower. Tuck the arms in close (smaller moment of inertia) and the skater spins faster.
Too many 911's in the borrow pit.
At least that was the case with my 01 AWD RX.
Again, this was not a planned happening. I was driving down a dirt road going about 25, when the road got "mushy". Within seconds, I was down to 2mph and in 12" of mud.
wwest...thanks for the explaination. Shortly afterwards I turned the vehicle off, and upon re-starting, the lights were off.
The second and more common use is for those who don't like getting all the way into the truck to start it to let it run and warm up. MAKE SURE THE PARKING BRAKE IS ENGAGED BEFORE DOING THIS!!!
Push the clutch-start-cancel button, reach in and turn the ignition on, walk away. For those who warm up their vehicles before driving, it saved climbing in and out to start it.
HOpe this helps.
Ken
Was that actually a Sequoia that you were driving when the VSC/Trac system shut down due to the ABS pump being over-taxed, or potentially over-taxed?
Trying to confirm with Lexus, but it appears there might be a 30 to 45 second limitation on brake modulation torque apportioning due to the need to protect the ABS pump from overheating.
I guess great minds must think alike. Hehehe !!!
The starting when not in the car thing is not mentioned by Toyota because it is inherently dangerous. Either the customer left the car in neutral with the brake on and uses it this way (not the safest thing as it should be in gear for safety), or they may one day forget it's in gear and the truck will start and drive through the garage wall. Great feature, but one day it will disappear for this very reason thanks to some attorney somewhere. While I'm at it, another heartfelt "thanks" to the attorney who successfully forced Montana to eliminate their unlimited freeway speed limit (insert appropriate hand gesture here) a couple years ago. I used to make it across that 700 mile state in under 8 hours.
IdahoDoug
Changing the law is one thing, forcing Montanans to abide by them and the law to enforce them is quite another.
Montana Autobahn
Steve - Montana indeed expressed their displeasure at the ludicrous 55mph speed limit in the 70s. They set the limit at 55 to remain eligible for the funds, but if caught you only got what was termed an energy resource fine of a few bucks. Then it was unlimited until a few years ago. Kinda fun, but you really had to pay attention at 94 as there are curves out there that even an Audi Quattro won't negotiate at that speed - so you really were not able to relax fully with the cruise on. One day, I missed a crucial gas stop in the LandCruiser and slowed to 55 for 20 miles to avoid running out of gas. I can therefore vouch that 55 would be incredibly frustrating in that state as a maximum.
I have the V6 model, Sport Edition.
