Ford F150 Towing Capacity of bumper hitch
I have a 1996 F150 4X4 LB SC with a 5.8 L. I need to know what the rear bumper hitch is rated at. I need to tow about 3500 lbs. I have no idea what the hitch weight will be. I'd add a CAT III hitch, but I'd have to reroute the exhaust system to do that.
Think you'd be better off with Cat 3 Hitch. It's easier to change the ball for different diameter hitches. Also with added height of your 4x4 you may need to use a receiver with a drop in it to line things up a little easier.
