Car Forums / Audi / Audi A4
Quick Links
Quick Links
I do not experience this when its warmer.
Anyone have any ideas?
Given this has gone off again for you I really wonder if your problem is as big as the techs are saying. I would be very careful in replacing an expensive part based on the info you have now.
I've owned a 2007 A4 2.0 quattro, drove 25k without any problems whatsoever. Visited the dealer service for scheduled maintenance Only. Recently upgraded to 2009 A4 2.0 PremiumPlus, soon will reach 5k miles -- everything is perfect.
I understand that older A4 models might have had some reliability issues... But i don't think the same can be said about the recent year models. Or it would be more fair to say, there has not enough time passed to judge objectively about B7 (2005-2008) and especially B8 (2008-present) generation reliability.
Regarding tire question -- Afaik, all new Audi's come equipped with all season tires in standard package.
Guess all I am saying is that when you take the vehicle in for service DO NOT rely on the dealer to do the right thing. Follow up to see that it has been performed as required by Audi (who by the way is reimbursing the dealer to perform this service)
Yours is tow noew for such a problem. My guess is its a faulty sensor.
Now the brakes start applying by itself after a 1 Km or so and comes to a point when I just cant move the car at all.
What can be the problem please.
Sarat
415 258-9619
They know what they're doing.
Based on my experience, my A4 has been very reliable with average annual maintenance cost of about $500. I drive a 99 A4 V6 with 143k miles which are known to be more reliable than the newer models. However, based on some internet chatter and what's posted on this site, they are to be steered clear from. I know I will not buy another Audi, not because I don't like the car, but because of potential issues with it. As I understand it, a warranty for Audi does not mean anything these days.
Anyway, hope this helps, and as always more feedback would be helpful from other readers.
D
My name is Joe. Ask your dealer to replace the Intake Flap Runner. This should stop unusual consumption of oil. Why Audi does not issue a recall for this problem, I do not know. These vehicles can run on 89 octane gas without harming the oxygen sensor.
Apparently (although I haven't checked all this out myself) the flap in the intake runner gets stuck allowing oil to seep into the intake and thus get burned up. This doesn't harm the engine in any way but you can use up a lot of oil and if you aren't careful you could reach a dangerously low level.
it's got some sort of electrical problem, and the car won't start. I'm thinking it's got some issues to do with heat, because the car only starts at night, or when it's cool. usually I take the car out at night, and dawn, and most of the time (95% of the time) it never starts in the day, because it is a bit warm here. some people tell me it's the starter, and the dirt needs to be cleaned off, to reduse overheating. but I think it's much more than that...anyone have any ideas?
Any help is greatly appreciated.
If you mean the car CRANKS OVER (starter motor turns) but the engine doesn't catch, then you probably have an ignition component failing or a bad fuel pump that is binding when hot.
Exhaust leaks are dangerous and should be investigated right away.
sometimes people mistake an oil leak dripping on a hot exhaust pipe for an exhaust smell---they are similar,--so I'd also check for an oil drip somewhere.
Don't mess around with this kind of problem...
1999 AUDI A4 QUATTRO
~135,000 Miles
Lately the car has been giving a few problems. A couple days ago white smoke came out of the exhaust for a while (5-10 minutes). The car itself drains a lot of oil and leaks a little, I brought it to a mechanic and he said it might be the head gasket or just simple the car may be burning oil. Yesterday I left a light on in the car by accident and the battery died. I charged it today and the car gave a engine check light. When I tried driving it, the car would go up a few rpm and would suddenly drop no matter how hard I held down the pedal, meaning it wouldn't get above 5-10mph. It would just rise and let go, rise and let go...
What could be the problem? Maybe an electrical malfunction, maybe the battery needs replacing? Or maybe something wrong with a cylinder?
Please help me as soon as possible, thank you.
Thanks for your advice.
Ed
Cheers
I've got a 2005.5 A4 2.0T with about 44500 miles. At around 33k, I began to notice a slight engine knock when the car was at idle, after it was warmed up and idling at a very low RPM.
I took the car to the dealership and they had it for nearly 3 weeks, and they had trouble diagnosing the problem. They eventually replaced the camshaft and some other things, but the noise remained - they didn't really fix the problem.
I've now got around 44000 miles on the car and the warranty expires in about a month, and I'd like to know if this "knocking" or "tapping" is a sign of something detrimental, or if it is no big deal.
I've since moved and am going to take my car in to another dealership to have it inspected before warranty expires, and probably have them look into the noise. If it isn't a big deal, then I won't fight them too much if they can't fix the problem. However, if could possibly lead to bigger issues down the road, I'd like to contact Audi and find out what my options are before warranty expires.
The noise is not easy to describe, but you would understand it if you heard it. It noticeable enough that if I start the car in a parking lot and let it idle, I get many glances from strangers. It's kinda like a "tap-tap-tap-tap-tap-tap-tap", at a rate of about 3 taps per second.
Thank You'
Bundy
Mine does too. Has 3000kms and was a dealer demo. It's got Michelin tyres which are also very noisy. I had the tyres changed front to back, wheel alignment and 4 wheel balance and I still get enough vibration to annoy me at between 100 and 120 kph. The only thing I can think of to do is to change the tyres to something else like Pirelli P7 which I know are better. These are virtually new so I will wait a while. Have you had any further info?
Please let us know. thanks
Btw, it's a 2005.5 A4 2.0T
I just got my car back today from the dealership - this is in regards to the "knocking" at engine idle that I've had since I purchased the car at 33k. I've already had it in the shop about a year ago, but they couldn't fix it. I took it to a different dealership and I am happy to announce the "knock" is GONE!
For anybody curious what the issue was, here is how the invoiced reads:
CAUSE:
-DEFECTIVE CHAIN TENSIONER - REMOVE/REINSTALL
-CAMSHAFT ADJUSTER - REMOVE/REINSTALL
-CONTROL HOUSING - REMOVE/REINSTALL
-OIL PRESSURE SWITCH - REMOVE/REINSTALL
I also reported an issue with the starter that made "grinding" noises prior to the engine cranking over, and this issue was also fixed and was directly related to the first issue.
I'm really pleased!!!
Now I need new tires. 2005 A4 2.0T w/TPMS Quattro. Tire size 235/45/17.
Audi Dealership that fixed my knock problem has Cooper Zeons at $780 which is everything including allignment. I'm currently kinda residing in the sticks, so I can't do Discount Tire or anything like that. We have snow 6 months outta the year, also.
My first concern is how good of a tire this is in terms of wear? Second, what is a better all around tire for the price? My most important conern is bang for the buck, so if a tire is a bit noiser or has less traction, that's ok.
I have no experience with A4 tires, so any info is good info.
If you can ask the original owner and if it snows where you are for 6 months a year and you said the car you have owned for over a year, how did the tires on the car now hold up in the snow.
I've got Pirelli's on now, but I think they're a bit pricey. I was just curious if anybody out here recommends a specific tire ranked in the following order:
-tread life (not advertised, but actual)
-road noise
-traction
Also, what's an average price to pay for new tires and everything that goes along with new tires including alignment? Is $780 reasonable and are Cooper Zeon's ok???
car. I have a 2005.5 a4 2.0t quattro and complained to the dealership a couple
times and they say they can't fix it. I eventually called audi of america and
told them about the problem and also to ask them if they knew anything about it.
They said it was due to the engine oil not heating quickly enough or something
but doesn't do any damage to the engine. They also said there is no repair for
it.
So what you had done actually corrected the problem? Which dealership did you go
to?
Yes, whatever I explained in my post above in regards to fixing the "knocking" sound in the engine, definitely also addressed the sporadic "grinding" sound of the starter. I should mention that the sound of the starter was something like you would hear if you've ever accidentally kept cranking the starter once the engine turned over - it's a difficult sound to describe, but I knew it was an issue because I could reproduce it at will - not a big deal, but my initial worry was the starter going bad and my warranty is due to expire, so wanted it addressed.
Again, I'm not sure if we're talking about the same thing here, but if you look in my post outlining the fixes, you can maybe mention this to your guys. Do you have any issues with a slightly noiser engine at idle? I didn't really notice it until my brother mentioned it to me saying that didn't sound right - it almost sounded like a diesel with a continual rat, tat, tat at idle.
Since my car is also a 2005.5, our issues might be related. I'm really particular about my cars - especially expensive cars, so I wouldn't doubt if a lot of people have this problem but don't really care about it.
The dealership that finally addressed my issue is Kocourek Audi in Wausau, Wisconsin.
I think it's the same exact problem. It doesn't do It all the time, but I would say 8 times out of 10 it happens.
I have found a temporary solution to our problem. If you turn the key to the 3rd stage before actually turning the car on (so all of the electronics are on and the lights on the dash) and wait a few seconds before starting it, it will eliminate the problem probably 50% of the time. However this still doesn't completely fix the problem. I will bring my car in again and tell them to do whatever it is that they did to your car to fix it.
Luckily, I had the dealer look at the problem before my warranty ended (which was at the end of march) so I should still be covered
Thanks for all your help and also, have you had any other problems with your car?
Sam
