Toyota Highlander Maintenance and Repair
12357105
    rphillips2rphillips2 Member Posts: 40
    What brand and model # of speakers and amp did you use?
    macmacmacmac Member Posts: 35
    I have heard the same problem on my HL. The problem was coming from the Rear View Mirror. Move the mirror around and the sound will go away.
    malachy72malachy72 Member Posts: 325
    I have A 2001 HL 4WD V6 which makes a tapping sound that comes from the engine when the temperature is below 50 degrees F. The noise can only be heard from the passenger compartment and almost sounds like a valve tap. The service manager agrees that the sound is there but says that it is the fuel injectors. It's been there since day one and has remained through 2 oil changes and 6 K miles. Instead of driving a brand new 32K dollar vehicle, I feel like I'm driving an old car with a valve tap. Any one else with this problem and a possible solution?
    osoriobosoriob Member Posts: 44
    I used oversized 6 3/4 speakers on all 4 doors from pioneer model TS-A1767 and a 300 watt Amp from the same company,just remember when installing the speakers that you will have to raise them a bit to clear the glass behind when window is rolled down all the way.
    good luck on your HL project
    llofgrenllofgren Member Posts: 129
    malachy72.....the tapping sound has been discussed alot in this forum before. If you go to the main HL forum and (patiently) go through the posts (I don't think the enhanced search mechanism is up and running yet), you will find numerous posts pertaining to what you are hearing. Most seem to agree that this is not a problem and is indeed the injectors. Many dealers have given the same explanation you got (including mine).
    roadrunner70roadrunner70 Member Posts: 241
    if anyone has a 2002 hl factory service manual, i need the front end alignement specs asap. my 2002 hl has a pull to the left, and it has been re-aligned once already by the selling dealer. i need the caster, camber and toe in settings to find out if it is being done correctly. i especially need the caster setting, the preferred setting, and the max difference from left to right, which is what typically causes a pull or wander to one side. thank.
    mcmattmcmatt Member Posts: 80
    The specs are too cumbersome to type and I don't want to be responsible for typo.
    Email me at matt_mccaslin@eptek.com, give me a fax number and I will fax you a copy of the pages.
    There are about 3 or 4 numbers for each spec times 2 for 2WD and 4WD.
    missgail1missgail1 Member Posts: 2
    Interested in 4 cy, but a rival dealer pointed out that 4 cy loose power w/ the A.C.. Driving in southern states requires the A.C. on full blast! Any comments appreciated!
    pdalpsherpdalpsher Member Posts: 136
    I noticed this in my '90 Camry. The current 4 cyl has more power than my Camry did but if you look at the mpg numbers the V6 only costs you 1-3 mpg overall. I test drove the 4 and the 6 and I went with the V6. I'm getting 21-23 mpg in mixed day-to-day driving...you mileage may vary.
    Having the V6 also gives me flexibility in what I want to do for vacation. I can go anywhere (mountains) and do some towing (up to 3500 lbs) without any second thoughts.
    I also recommend the tow prep package as it is relatively inexpensive but provides better cooling capabilities for the major fluid systems(transmission, oil, power steering) and more amperage in the electrical system. The new car info on Edmunds provides the details on the components of the option packages.
    The V6 costs more initially and costs a little bit more to maintain (6 spark plugs + labor vs. 4) but it is a pleasure to drive. I've had my Highlander for 9 months and it is the best vehicle I've ever owned.
    xcarnutxcarnut Member Posts: 81
    Anyone out there upgrade their basic CD/Tape head unit to head unit from LTD ? If yes, what if any were benefits besides getting 6 disk changer in the head unit? Also, anyone upgrade from LTD head unit to aftermarket unit ?
    martman1martman1 Member Posts: 4
    Brand new highlander limited-v6awd-loaded-The color is all black-1000 miles-water spots on car donot come out(bird droppings)-I notice clear coat paint seems very thin. I have used a very mild car wash soloution(mothers) from dealership. Can anybody suggest how to keep this car clean.Did dealership wax car before I picked it up, do I need special cleaner?. Sounds crazy, I am afraid to take to my local car wash, or rub to hard on paint, to take water spots out. Am I going crazy just trying to clean a new car that is painted black?
    Sounds like you are very protective, that is probably a good thing when it comes to the chance of swirls.
    My recommendation is to just take it to a detailer. Don't tell them how worried you are, however. They have more tricks than we do with clay bars and conditioners, etc.
    The spots sound like hard water spots, but they would know for sure.. We have a black one also, but we haven't noticed the spots. We do use a brushless automatic car wash sometimes. It seems OK so far.
    Good Luck
    sin21856sin21856 Member Posts: 14
    Hello, I was just wondering if anyone else has had this problem. Yesterday as I was leaving my friend's house I noticed that a bunch of warning lights were on (engine light, brake light, abs...and a couple of other ones!). I was just a block away from his house when I noticed, so I immediately pulled over and turned the car off. I started the car again after a minute and only the engine light stayed on. We decided that it'd be best to pull into my friend's driveway and check it out. We found nothing wrong with the engine, nothing noticebly loose. I just got my oil changed last weekend so that probably isn't the problem. We left the car there, went to the gym, and came back a few hours later. I turned the car on and the light still stayed on, so I decided to bring it in to the Toyota dealership the next morning so they can check it out. I wake up early and head to the dealership this morning and since I don't have an appointment, they won't be able to get me in till Monday. What do you think happens next? I get back in the Highlander to head to work, and now the engine light's off! Arg!!! This happened once before, all the warning lights turning on I mean. Same deal, except this time all the lights went out before I could get to the dealership...they said there's not much they can do unless the light's on. What should I do? Keep my appointment for monday and let them check it out? I'm not sure if they'll do anything since none of the lights are on now. Is this just some glitch or should I be worried...this has only happened twice but its really annoying since the Highlander is still pretty new...its a 2k1 Limited with 20K miles. Thanks for any advice you can give.
    I'd still take it in to get it documented...just in case. It may be an electrical or sensor problem. This isn't good since it's just like the story of the kid the cries wolf...sometime the lights will work, it will be a real problem but it may not be taken seriously due to the number of 'false alarms'.
    brad_22brad_22 Member Posts: 154
    Might want to check your fuel door. I didn't fasten mine tight enough one time and it caused the engine light to come on (strange feature...).
    Anyway, it gave me fits trying to figure out the problem.
    k_timek_time Member Posts: 7
    Goldston post #55 is right. I own a 2001 honda accord and it has the same wupping sound when the two rear windows are down. Just open one of the front windows and the sound will go away.
    We just bought the 2002 4 cyl Hl this week. The performance of the engine with full air conditioning on in 90-degree weather is not to bad. The acceleration is almost in line with my 2001 accord ex, I expect even greater performance when I start putting premium gas in it.
    cmunizcmuniz Member Posts: 604
    The most common problem is a loose gas cap. Make sure that you hear a couple of clicks when you tighten it after gasing up. If the light stays on it is a problem with the emission system and can be driven, but should be checked by the dealer. If it blinks, then then it's a more serious problem and should be taken to the dealer asap. If I am not mistaken once the light comes on it sends a code to the computer that the dealer should be able to pull out even if the light is off when he checks it.
    The dealership looked at the HL today and they're ordering a new controller/monitor free of charge since its still under warranty. Thanks for the advice everyone :)
    crrnamcrrnam Member Posts: 2
    I just read message #179 from spensiv66 regarding tire/road noise. Has anyone experienced this problem or is anyone aware of its resolution? I just drove my new 2002 HL AWD 6cyl (7,000mi) from my home in the Washington, DC, area to San Diego, CA. I had no problems on the trip and during my first week in this area. Then about a week ago, I started experiencing the same type of problem discussed by spensiv66 -- an intermittent tire/road noise when driving on the freeways at highway speeds. At first I too thought it was simple road noise, but I noticed that it was occurring on a variety of road surfaces. Today I took the car to a local Toyota dealership where the problem was evident during a test drive. In talking to my service manager this evening, they are stumped and are contacting the Toyota factory for help. Can anyone offer any suggestions? I'm trying to head back to Washington, DC, but, as long as this problem persists, I'm hesitant to get started.
    madmommadmom Member Posts: 1
    I too have had a problem with a squeaking noise which seemed to be coming from the dash. I have likened it to finger nails on a blackboard---most annoying. It isn't in the dash...it's the cowl rubbing on the windshield. This is why temperature, speed and wind direction appear to impact the problem. The dealer tried weather stripping on the inside of the cowl which worked for a while but the problem returned gradually. They are now replacing the cowl which (I hope) will permanently resolve the problem.
    I have a 2001 Highlander. I too thought that the sound came from the dash. Mine squeak came from the rear view mirror. The sound bounces off the wind shield and distributes the sound all over the place.
    After much teeth gnashing and hand-wringing, the service technicians at Toyota Carlsbad in Carlsbad, California, appear to have solved my tire/road noise problem. Fortunately, the fix was a simple one -- improper reinstallation of the splash/engine guard after an oil change at a local area quickie oil change establishment. The technician's comments may be of interest: "Whoever performed last service on vehicle did not reinstall engine guard correctly. It is supposed to go under front bumper skin cover, not over. Installed guard correctly, test drove, and noise is gone."
    hammersjslhammersjsl Member Posts: 11
    I've noticed a color problem with the black plastic areas of my dashboard and interior door trim. In areas where the doors have been scoffed up as well as a small spot on the top part of the dash, the color appears to be rubbed off. I've tried cleaning the areas and the marks are still there.
    Does anyone have any suggestions on how to repair/clean these types of marks? Is the color on the vinyl pieces actually painted, and if so, is there some kind of touch-up paint that is available?
    On a quality note, I'm kind of disappointed by this problem. I figured that Toyota would have colored the interior plastic pieces so that they could stand up to reasonable wear.
    Thanks for any suggestions.
    joandeejoandee Member Posts: 3
    As soon as the car moves 5-10 feet, a "clicking" noise is heard in the rear somewhere. It sounds very similar to the click one would hear with an automatic door lock. The Dealer does not know what it is. We drove another one and it does the same thing. It only occurs when the car is first started. I have read the other posts about "clicking" noises, but I do not have a sunroof or a spoiler, and it does seem to be coming from "down" in the rear, not the roof.
    b717b717 Member Posts: 38
    It is the self test of the ABS system.
    Thank you very much. You are better than all the service people at the dealer. They "guessed" it had "something to do" with the automatic transmission." They ignored me when I questioned how the noise could be in the rear of a front wheel drive vehicle. Thanks again.
    robnaorobnao Member Posts: 29
    I am also very picky when it comes to the looks of my all black HL, but I messed up and washed it when I did not have enough time to dry it. This left water spots (wonderful San Diego hard water) that do not come off. I have tried MOTHERS brand clay bar, it helped, but if you look closely there are still spots. I have yet to try a MCGUIRES product (scratchX, I think) that is supposed to get this stuff off without scratching (clear coat safe), I will post how it works. The instructions state that if this product does not work take the vehicle to a professional detailer. I would never use polish paste or a rubbing compound it will most likely scratch the clear coat.
    As for normal washing, any quality car wash should be safe. Never use dish soap, it is too harsh and it strips the wax. Any quality liquid wax (MOTHERS, MCGUIRES, etc.) should give you good results. I say liquid wax because CONSUMER REPORTS reported liquid wax generally had the least amout of scratching compared to pastes in their tests. They also reported that most waxes start to loose effectiveness after about 1 month, even the ones that claim much more.
    As for the brushless car washes, they should be safe, nothing is actually touching the paint except water. I had no place to wash my HL for the first 2 months I owned it, so I used these several times with no ill effects. I did notice though that after some time there was still a slight dirt film that only a regular hand washing would remove. I would never use one of those roling brush car washes, they can scratch the paint.
    Hope this helps. Happy HLing
    There was some discussion of water spot removal recently on another Board...the waxes, etc no Zaino posts. Sorry I don't have the exact name in front of me. The folks on this board can tell you exactly what you need to know about keeping you HL looking like new.
    seahskerseahsker Member Posts: 6
    Thanks for the information on the click noise mine was coming from the front wheel area and ABS would make sense.
    I have trouble with water spots from both the left and right side mirrors. The guys at the car wash dry them off but water seems to be collecting inside the mirror housing. I don't know how you can dry this area when you can't even see it.
    gwleonggwleong Member Posts: 36
    I know this issue has been raised before, but I don't recall the solution. I have a 2001 H/L 'non-limited' that has finally developed this rattle. Can anyone provide the solution to this problem?
    Thanks in advance!!
    Gary
    bikerjohnbikerjohn Member Posts: 52
    I'm bringing in my 2002 Highlander for its first full service next month. Does anyone know if there is a TSB to fix the sunroof popping noises?
    I read about the problem on this site last year before I bought mine, and sure enough, I have the same problem.
    Other annoyances I want to have them fixed are the rattling glove box, creaking drivers seat belt latch and a vibration/buzzing sound coming from the accessory plug cap. The last one took me a long time to find. When I leave the cap off, the noise is gone.
    I also want them to check the wind/road noise. When driving above 50 MPH, it is louder then I think it should be. I'll have them check door seals & the splash engine guard mentioned in post 223.
    If anyone knows of fixes for any of these things, please let me know before I attempt to get the dealer to fix. Thanks
    goldstongoldston Member Posts: 110
    Gary,
    I fixed the rattle in my 2001 H/L by using little rubber pads with adhesive backing that you buy at home depot to the glove box door. It seems that the latch in not quite holding the door tight as it should be and you get a slight rattle. I also had to do the same fix to my wife's 2002 H/L.
    I hope this helps.
    Best Regards, Philip
    tmc1417tmc1417 Member Posts: 11
    Last week I had my 01 HL in for its 15,000 mi service and had a list of things for them to fix including the all too common glove box rattle, sunroof clicking and the wind noise while driving in strong crosswinds. They fixed the rattle and clicking without any questions..but when it came to the wind noise they said they could not reproduce it (I had given them the TSB # on it and the fix I had gotten off this board..and OH how they hate it when you do this...they give you THE look like how dare you know anything.) I asked how they thought they could reproduce the noise and they said to bring it in when the winds are gusting over 40 miles an hour and they would take it out and see. Like I can plan ahead for that! Any suggestions from those who have got this fixed without having the service dept reproduce the noise themselves?
    I got the same runaround from the service dept.
    The bulletin states the seals will be replaced upon customer report, it does not require the tech to witness the symptom. As long as the VIN number is within the range of VIN's identified
    on the bulletin they are authorized to change the door seals. The wording is very clear and after pointing this out, they went ahead and changed mine in April and the cure works vey well. Good luck.
    Arg! My engine light went on again for no particular reason, while I was on a road trip this weekend. I brought the HL to the dealer earlier this month and they said it was a faulty ECU and replaced it, now it's on again. Anyone have any wild guesses as to why the light would turn on? I've driven the HL under normal driving conditions, have about 22K miles on a 2k1 Limited model...this is the 3rd time the light has come on since I got it. I've made sure to check the gas cap and other suggestions that have been posted before...this problem just seems very random and has me a bit worried that something might be terribly wrong with the engine. Well, I'm taking it back to the dealer tommorow at 7am (wohoo!) so they can take a look at it, again. Can anyone provide me more info regarding the crosswind noise and the TSB regarding that problem? Where can i get info about about the TSB, such as the VIN numbers affected? I figured that if I'm there then I might as well have them look at that too cause the noise does get noticebly loud on the freeway. Are they suppose to inform us somehow of these fixes? If not, how do I get informed of any fixes to existing problems that I might just regard as normal, not knowing any better. Thanks for the help!
    On another car I had, a bad spark plug set the light off. Also, it might be an O2 sensor or other pollution control device. The code should tell the dealer what it is, unless some electrical problem is ruining your ECU. Those are my guesses.
    pasqualpasqual Member Posts: 22
    Has anyone located an aftermarket maintenance manual for the Highlander. Factory manual's price is out of this world.
    ash732ash732 Member Posts: 5
    I recently bought a 2002 HL Limited. When I asked the delaer what is the ideal "schedule" to break in the engine, he told me drive only up to 55 mph for the first 1500 miles. He said it would help in the long run. It will take me at least 6 to 8 months to break in the car this way (I only drive it on weekends). How have some of you driven (what is ideal) ?
    ash732
    Although you shouldn't drive over 55 mph for long periods of time, I believe you can exceed it from time to time w/o any problems. The most important thing is to vary the speed a lot and don't come to any sudden stops if you can avoid it. Driving it in a variety of conditions is ideal.Most break in periods are 1,000 miles, not 1,500 but I don't remember what the manual says.
    waynel2waynel2 Member Posts: 3
    I recently bought a HL 2002 V6 4X4. The feeling to drive it to go over small bumps (such as cracks on road) is noticeably worse than driving my another car - a 1995 Honda Accord. Is it normal to HL (because it is heavier), or there is problem in the suspension on my new HL?
    You asked for a reminder to look up the TSB number for the popping sunroof noises. I think you also had some additional info regarding the wind noise from some trim molding in front? Thanks in advance for your help.
    Here is a repost of #186
    Have your dealer look up TSB NVO12-01
    Title is "Wind noise at 'A' pillar"
    Dated November 30, 2001
    Front door weather strips, left and right, were changed in accordance with this bulletin and the noises went away on my vehicle.
    Old part number 67861-48020 rh
    67862-48020 lh
    New part ends in 21 instead of 20
    Warranty covered this change at no cost.
    This noise was most noticeable when gusty wind conditions were present and speeds were 50 mph or above.
    I have the same type of HL as you and noticed the same thing when I first got mine.....small bumps felt harsh. After reading the postings on this board, it became apparent to me that they ship the HL's with their tires over-inflated to preserve the tire. I then lowered the pressure to the correct value (I think it is 30 psi) with a noticeable improvement in ride.
    Les
    Actually, I was looking for a TSB for the sunroof popping noises.
    sodafastsodafast Member Posts: 10
    The AT button is released via the brake pedal, so your problem could be related to the brake safety feature. Ideally, you would like to have it fail for the mechanic, but these intermittent problems drive us all crazy so you are going to have to do a little experimenting on your own. Here are some tips which might provide some insight into the problem: Even on a properly functioning system, if you press firmly (or perhaps even lightly) on the button BEFORE you fully press the break pedal, then it will likely put the button/release mechanism into a bind and the button WILL NOT GO IN until you release the button COMPLETELY and you may even have to release the brake pedal and then reapply the brake pedal completely before trying the button again. In addition, moving the shift lever at all prior to fully depressing the brake pedal could also get the button/release mechanism into a bind. If you are not already doing so, try to get into the habit of not touching the shifter at all until you have the brake pedal FULLY DEPRESSED. Then, if the button will not go in, let go of the shifter completely, pump the brake a couple of times, and try the button again. If the button still will not go in, keep the brake pedal fully engaged and gently rock the shift lever fore and aft a couple of times WITHOUT PRESSING THE BUTTON and then try pressing the button again. An important point is that with this particular brake safety release, IF THE BUTTON WILL NOT GO ALL THE WAY IN, IT IS HIGHLY UNLIKELY THAT PRESSING HARDER WILL HELP. You are much more likely to succeed if you release the button completely, rock the shift lever slightly, release and reapply the brake pedal, etc. If you find that one of these techniques predictably solves the problem after the button first malfunctions, report the details precisely TO THE MECHANIC WHO WILL BE WORKING ON YOUR CAR. Your accurate description of exactly what helps free up the button should help narrow down the likely cause of the intermittent malfunction. Hope this helps. Good luck and keep us posted on any new developments...
    jerryo3jerryo3 Member Posts: 1
    I purchased a 2002 awd v6 highlander two months ago. It currently has 2050 miles on it. So far I like it very much, but recently(less than a week ago) I strted hearing a noise (sounds like it's coming from the rear) when coming to a stop and also when taking off. Has anyone experienced this problem? If so, what is it and what is the solution. Along with the noise, I started to hear my rear brakes scrape a little when breaking. Maybe I just over-sensitive about the brakes since my last car (97 Mitsubishi Galant) had nothing but brake problems.
    tielgirltielgirl Member Posts: 8
    I have a 2002 FWD limited V6 Highlander that purchased one month ago. It has about 1800 miles on it and I absolutely love it. I regularly use the "auto" feature on the headlights; according to the owner's manual after shutting off the car and opening the driver door the lights turn off. I've noticed a couple times where this did not happen and the lights turned off as soon as I shut off the vehicle (before opening the driver door). It did it most recently when stopping the key at the auxiliary position. Has anyone else experienced this with the auto feature?
    I had experimented with our Highlander some time ago and discovered a couple of ways you could intentionally defeat the auto off, but I can't remember exactly what I did. The engineers anticipate that there may be certain circumstances where the driver desires the headlights stay on after switching the ignition off and exiting the vehicle (for example, in an emergency roadside situation). They didn't want to deny you this option unconditionally. Unless you do something out of the ordinary, the auto off should shut off the lights to prevent you from draining the battery.
    It's encouraging to know someone else has "defeated" the auto-off feature. I would feel a whole lot better if it did the same thing every time though. Have been experimenting this week and thought that maybe the lights turning off when stopping at the auxillary position was by design but tonight was proven wrong when the lights stayed on when doing the same thing. Makes me wonder if have an electrical type issue.
