Toyota Highlander Maintenance and Repair
14748505253105
    henrywanghenrywang Member Posts: 2
    thanks!
    scoti1scoti1 Member Posts: 676
    I did not mean to be tough on you. As a matter of fact, I was trying to "nicely" be critical of those who were being tough. The "nice" part of it probably distorted my message. I think many people come to this forum for the first time to post a problem. To be critical of someone because this is their first time to post here is ridiculous. This forum is for "problems and solutions". You stated your problem. I would like to help you find a solution. All I am saying is that Toyota has a history with this problem, and if you cannot provide some proof of reasonable maintenance, then they probably will not do anything for you. But who knows. Your engine is only 3 yrs old and it should not be sludging up at such low mileage.
    There was a sludge hotline of sorts set up by Toyota corporate. I am not sure if it is still in operation. You can find more information at http://www.autosafety.org (they had a link to the letter Toyota sent to the owners of 1997 - 2002's, but I can't get that link to work right now). I recommend that you call the hotline or a corporate number to report your problem and see if you have any recourse under the sludge policy. You should also post your problem on that site as well as www.nhtsa.gov. This could be related to an inherent problem with the engine or it could be due to negligence on your or some other parties part -- we don't have enough information right now to figure that out. Absent any further data, and given that these engines have a known problem, I suggest that you proceed with pursuing this through Toyota. It certainly can't hurt to try.
    See if this link works for the Autonews article about the problem. If this doesn't work, go to the Autosafety site (link above) and if you go to their Toyota Oil Sludge page, you will find a link to it that should work. http://www.autonews.com/article.cms?articleId=38921
    Unfortunately for you, it says that the Highlanders covered were built from November 2000 to July 2001; I think a later article came out that extended this into 2002, but it only covered the earlier months and probably doesn't cover those that were assigned the 2003 model year.
    robert19robert19 Member Posts: 2
    Finally got our Highlander back today. They said that they replaced the VSC computer part in the steering column. I asked them if this one was going yo go out at 7,000 miles and they assured me that this new part is an upgraded version of the older part. Hopefully it won't happen again.
    jrfierojrfiero Member Posts: 123
    Re Message #2419 Update to warped rotors by nimrod99, and replies to it -
    I just had a front hub/wheel bearing replaced by Toyota, under the driveline warranty. The symptom was I could hear it. I don't know how to describe what it sounds like, its just something I've learned over the years. Its like increased road noise over time. It wasn't to the point of feeling it through the steering wheel yet.
    I was surprised the dealer agreed with me that there was a problem, and didn't argue about replacement under warranty.
    While I was at the dealer for post #2519, I also mentioned for the umpteenth time, that my driver's door window made unusual noises going up and down. They agreed, and wanted to charge me ~$500 to replace the regulator and motor (2001, 37000 miles). I pointed out that I'd mentioned it several times (documented) while the HL was under its full warranty, and they changed their mind and fixed it! The whole dealership has had a physical remodel, and I guess they changed their customer service attitude while they were at it.
    Koons Arlington Toyota, Arlington, VA. I kinda recommend them.
    herzogtum71herzogtum71 Member Posts: 470
    Another possibility is that the people you paid to change the oil didn't actually do it. This has happened to me twice that I know of -- once 20 years ago at a Chevy dealer in Colorado and once 12 years ago at a lube place in Massachusetts. Now I make a point of checking the oil level and appearance whenever I get home from having the oil changed.
    I agree. I haven't had that happen (oil not really changed), but I do check it after every oil change. Would one lapse in an oil change cause the engine to sludge up though? If he was following the 7500 interval, it could mean 15,000 miles between oil changes which is alot, but I know many years ago I would go that long between changes with no problems whatsoever, at least at low miles. Probably caused the engine to die an early death, but not at less than 30,000 miles.
    skibear36skibear36 Member Posts: 1
    Can anyone recommend the best snow chains or cables for my front, 2 wheel drive, 2003 Highlander? I still have the stock 225-70R-16 tires that came on the vehicle.
    edhedh Member Posts: 246
    yes some of the Toy sludge problems were from that people on long intervals (7500 miles) missed one. or they had a "car detailing place' change it and they really did not.
    change your oil every 5k miles/6 months =no problems mon
    Please keep in mind, remember, snowchains ONLY on the front of any vehicle is potentially a very hazardous situation. Due to rear tire/suspension clearance snowchains cannot be fitted to the rear of the HL, RX, or Sienna.
    Baically it would be best, safest, not to take a FWD vehicle into a area where adverse roadbed conditions might exist, and certainly not a vehicle wherein rear snowchains cannot be fitted along with fronts.
    grahampetersgrahampeters Member Posts: 1,786
    sage3sage3 Member Posts: 47
    I have an 01 4wd with 42K, and occasionally have engine knocking ( like marbles rolling around the engine) with acceleration especially when climbing a hill. Toyota dealer states it is a detonation problem and using higher octane fuel should help. It appears that when using 93 octane the noise is not present.
    This is actually mentioned in the manuel page 180 under Octane Rating.
    I am wondering if anyone else has esperienced this, and did you do anything about it? I would rather not have to pay for the better gas since my work does involve alot of driving...
    Thanks for your reply. Yes I know this is a problem in Toyota, and actually several other makes, too. But should this be happening? What has changed in engines to make them less tolerant of missing an oil change? As I mentioned above, it is only in recent years that I have become diligent in oil changes due to the sludge problems being reported. I never had a problem with sludge when I was not diligent in oil changes. This has not always been a problem...and it still does not seem to be a problem in all Toyota models or in many other makes of car. It is disconcerting to read of sludge problems after the 2002 model year in the Toyotas with the problem when this was supposedly fixed with the minor tweaking. Maybe this 2003 with sludge reported here is an anamoly.
    I did a quick check of Edmunds and the NHTSA and Center for Auto Safety complaint sites and can report that these sites really have very few complaints of sludge in 2003 and beyond Toyota models as compared to the pre-2003 time frame. I know this doesn't mean much since these sites really don't represent Toyota owners as a whole, but it is encouraging to see less reports in comparison to previous years. Maybe the tweaking did some good, or possibly the publicity of the problem has made owners more alert to maintenance needs.
    rpell46rpell46 Member Posts: 15
    If you're "pinging" and engine timing is not the cause, you can almost cut the difference in the cost of having to use a higher octane in half by experimenting with periodically filling up with premium. It might be only every third fill or even every other, but it will cut down on the extra cost. Do NOT buy the PLUS (89 octane) grade. This is blended at the pump at a ratio of 2 parts regular(87) and one part premium(94). The difference in price does not reflect this ratio and will actually cost you more than if you fueled with premium periodically.
    I'm really disappointed in the FM reception on the radio in my '03 HL. I've tried a better antenna and added a signal booster, but a number of relatively local stations still either fade-in and out or are static plagued. Of course, the local Rock or Rap stations are "loud-n-clear" but the stations I enjoy, soft rock, jazz, etc., can't cut it. I'm in the NYC area and this occurs outside of the city as well. Is anyone else experiencing this? Any solutions other than replacing the radio?
    suvtimesuvtime Member Posts: 58
    Has there been any word from Toyota on fixing the hesitation problem with the Highlander yet? I'm still considering buying an 04 or 05 but have been waiting due to this problem.
    The transmission is supposed to adapt to your driving style, so how does it handle households with 2 or 3 drivers. I've even seen that some car rental places will rent out Highlanders. Can the transmission adapt to a new driver almost every day.
    Artificial Intelligence.
    In cars, insofar as driving style is concerned, "AI" is restricted, typically, to the past ~180 seconds of history. Within ~60 seconds of having started the car and put it in motion the "intelligence" has mapped your driving style into one of 4 types. After 180 seconds the mapping is more refined and you will now be mapped into one of ten driving styles.
    Thereafter it keeps a running history of the past ~180 seconds and if you change your driving style it will adapt and remap you into another "bin".
    There a second level of "learning" involved with newer vehicles but that has to do with basic operation of the engine and transmission.
    For instance if you disconnect and reconnect the battery on my 93 Ford Ranger PU it will now have to "relearn" the proper power duty-cycle to use on the fuel injectors and the solenoid controlling the idle air bypass valve to achieve idle of 760rpm and the correct output from the exhaust oxygen sensor.
    Starting from a factory ROM approximation it automatically adjusts the air/fuel mixture at idle using the oxygen sensor output as feedback and then remembers the "settings" required to keep the engine at ~760 RPM and low emissions.
    Several people here on edmunds talk about a drivers window road noise problem caused when the window is all the way up the rubber seal moves away from the glass letting road noise in. Other windows may do that too who knows.
    Mine, when the window is all the way up at 70MPH you get road noise. If you bump the window down 1/8 inch the road/wind noise quits. When you bump the window back up, the window pulls away from the lower rubber seal, the one where your elbow would be if you lowered the glass and rested your elbow on the window.
    Is there a fix for this? anything from the factory????
    jbolltjbollt Member Posts: 736
    My dealer fixed this on my 2003 Highlander...they claimed to never seen it before, but where able to fix it. I'm not sure what they did, but the window is tight to the weather-strip with the window all the way up. Much less air/road noise now. The only window I had that problem on was the drivers. This has been the only issue in 25,000 miles. Hope this helps.
    No word from Toyota yet, to my knowledge. You may want to check out the Engine Hesitation forum (there is a link to it under "Helpful Links" on the left side of this forum, right under Advanced Search.
    Any idea how they fixed the front windows road noise (at 60 MPH)?
    I was on the interstate yesterday. both front windows do it.
    If you lower the window 1/8 inch or so the noise really drops. If you raise the window fully, as the motor drives the window up, the window bottom just above the door bows out and the glass pulls away from the inside rubber piece, allowing a gap that lets in the noise. A lot of noise.
    is this a defect they all have???
    what stops the upward progress of the window glass/ is that point adjustable? If you leave it down an 1/8 inch it rattles when you slam the door.
    If this fixable by a dealer or is it a defect??????
    johnny5johnny5 Member Posts: 13
    ACGC, I finally had the 15K checkup and they noticed the clicking this time and also gave the same explanation you seem to have gotten with the added information that the spring was somehow involved with the electrical connections for the airbag in the steering wheel. I can live with it.
    They also fixed a problem that had developed with the heater where it would only blow air at full temp unless set at 65 where it would shut the heat off completely. They replaced the entire unit under warranty and gave me a loaner for the extra day it took to get the part in.
    Great Service experience.
    mscolejmscolej Member Posts: 1
    I own a 04' 4WD Highlander Limited, and it has had a hesitation from standing start and low speed acceleration. Has anyone gotten a fix for this. I was told it was the traction control system kicking in and zapping the power.
    I also have a vibration(jiggle) thru the whole truck that starts at 70 mph and gets worse as you go faster. The tires have been balanced (road force) 3 times, they have replaced a drive shaft and, and taken all 4 wheels and tires off of an 05' still no resolution for the vibration. They are calling Toyota Tech Support today to see if they can help. Has anyone experienced this and more importantly had it fixed.
    edh...I really don't know what the dealer did to fix it on my 03, but it IS fixed...I believe that the window still goes up the same distance, it just doesn't bow the top of the lower door panel when fully closed anymore. It was just the drivers door that had this issue on my vehicle. We looked at several other 03 and 04 Highlanders on the dealer's lot, and a few (maybe 2 or 3 out of 10 or so looked at) showed the bowing on the driver's door with the window fully closed, none at any other door.
    BTW, we just bought a 2005 HL Limited to add to the family, and none of the Highlanders we condsidered buying exibited this.
    spencer327spencer327 Member Posts: 106
    2004 HL LTD V6AWD. I have front end noise last 2 weeks. started at 15000 miles builds with speed, very noticable decelerating. Sounded like tire noise so I used it as an excuse to get rid of the goodyears and got michelins. The noise is still there. On the road a swerve to the right keeps the noise, however a swerve to the left makes the noise disappear till you center the steering.
    Has anybody heard of this?
    failure "noise" is often directionally sensitive.
    wheel bearing?
    off road stuff?
    teen age drivers?
    driven by senior citizen , highway only, conservative driving. 5000 miles hwy, 10000 miles local stop and go. Brakes look fine. I will see what my dealer comes up with.
    that Paul Newman is a senior citizen, a VERY senior citizen!
    You know, the 80+ year old that drove a Daytona Prototype in last month's 24 hours of Daytona.
    touche
    noise is front differential. At least a week before Its available. I am really starting to question my choice of vehicle.
    Brakes,tranny now differential. At least this is a problem, that can be fixed.
    ddpstcddpstc Member Posts: 44
    After changing oil at 4700 miles, I could not reset the Maint Req light in my 2004 HL that keeps showing up above the Fuel guage. I followed the manual, turned the ignition key to lock, press down the trip meter button, then turned the key to ON position for 5 seconds, the number resetted to 0000 but the Maint Req light keep showing up. What did I miss?
    Why does Toyota make it too complex to reset the Maintenance Ligh? In my Honda CR-V, all I have to do to reset the maintenance light is to insert the key to a reset hole, why can't Toyota make it simple for driver?
    Is there a way to disconnect the fuse to the Maintenance light for good? Most cars in the market have no maintenance light and they worked fine.
    loucapriloucapri Member Posts: 214
    i hate the maintenance light!
    I mean, that little oil change sticker the dealer put on is good enough.
    It sounds like you did everything right. Was the light working properly before the oil change? I believe after 4500 miles it was supposed to flash for something like 12 seconds each time you started the vehicle. You may have a short of some kind that they should take care of under warranty.
    middleageguymiddleageguy Member Posts: 42
    I had to have the Toyota dealership show me how to clear out this light. Turn the ignition (don't start) to Accessory. Hold in the black trip button until the odometer turns to 0000000. The light should turn off.
    The good news is the light did not go on at 10,000 miles.
    mckeownmckeown Member Posts: 165
    Accoring to the Shop Manual (and my wife's 2004 now has 27K on it so I know this works).
    Key on...doesn't matter if the engine is running or not, push trip button until ODM is displayed.
    Key off......push and while HOLDING Trip button...Key turned to on (do not start engine). After 5 sec. of holding the Trip reset, the Maint Req inducator should turn off.
    This will reset it to the Next 5K interval. Approx 4500 miles from now the Maint Req indicator will stay illuminated for 15-20 sec after the vehicle is started as a subtle reminder that the next Service Interval is nearing.
    is an unnecessary frill.
    i would rather have auto locking doors when u drive off
    I had a Honda Civic that had the maintenance light, but it came on at 10,000 mile intervals, and that seemed way too long for an oil change, altho that is what Honda stated in the manual for that car. We always change oil at 5,000 miles. If I have to reset the light, oh well... Perhaps it should be an owner setting to specify at what mileage the light comes on? or not on at all? That would allow for the different usage types (normal or severe) :-)
    Everyone is different. I hate the auto locking doors, and always disable them when I get a car that has them. Just personal preference. I think that a vehicle in the class of the Highlander should offer the auto locking doors, but also allow for personal settings. BTW, I had my dealer set the remote so all the doors unlock with one push of the unlock button on the remote. (this should also be able to be done by the owner) My wife prefers the ability to only unlock the drivers door with the remote, so her car takes 2 pushes to unlock all doors.
    I have an '04 4-cylinder Highlander. While driving I don't hear any unusual noise, but a week ago I heard a high-pitched squeeling noise or whirring noise when my daughter opened the front passenger door when I dropped her off at her job. I rolled down the driver's window and even opened the driver's door a bit, but didn't hear anything.
    This morning I heard it again when I dropped off my daughter, and when I got home I left the engine running and got out. Once I stepped out of the car I could hear it. It's hard to pinpoint, but it seems to me that the noise is coming from the passenger side of the engine compartment where there are two belts, one higher and one lower.
    I'm due for 15,000 mile service in the next week or two. Does this noise sound familiar to any 4-cylinder owners? Does anyone know the purpose of these belts? (Alternator? A/C?) I'd like to be able to say more than just ask the service technician if he hears the noise, too. Thanks. Any input is appreciated.
    My 04 highlander has the manual air conditioner. The heat / cold dial is a large round one on the dash.
    When its on "full cold" (counterclockwise i think) I still get a little heating, that is, outside air is like 10 degrees warmer when it comes out the vents..
    Is this dial mis adjusted?
    is the dial a water control valve or is it a air control (damper door0 valve??
    Anyone know?
    typesixtypesix Member Posts: 321
    Others have stated that it's a damper that modulates the heat. Outside air will be slightly warmer as a result until that area is cooled down enough from incoming air, but will still be higher than outside, but maybe not as high as 10 degrees.
    So the hot water heat exchanger inside the climate control plenum will always be at ~180F and the radiant heat therefrom will ALWAYS result in the incoming air being warmed slightly.
    You can purchase a Ford motor driven fuel tank selector valve and install it inline with the hose and turn off the flow in A/C mode.
    bm2bm2 Member Posts: 1
    Make sure the meter is showing ODO xxxx miles instead of Trip A or Trip B. Turn the key to the Lock pos. press the meter reset switch, turn to the On pos. while holding the reset switch 3-5 secs.
    or a shut off valve in the line to the heater core - any idea what its inside diameter is? Turn it off in may , on in October where I live.
    I had a firebird with no hot water valve - put a brass water valve in it.
    samovarsamovar Member Posts: 4
    Just brought home 2005 V6 AWD Limited purchased for invoice +$300 - $750 rebate. Two questions already on the ride home:
    1) The defrost wires on the two rear side windows are different: one side has vertical wires covering only half the window, the other side has horizontal wires. Is that normal? Why the asymmetry?
    2) Moonroof controls don't seem to operate per the manual. I have to hold down in either direction to open/close/tilt, and it moves so fast it's hard to know exactly when the roof is closed and sealed. The manual indicates that if you push the switch it should open or return to full closed position automatically and that you actually need to give it a little push to stop in a part open position. How is it supposed to work?
    those wires are the antenna for the radio..no defroster in the back SIDE windows
    read the manual again for the "normalization" procedure for the moonroof..takes only about 30 seconds to get it so it works as you want.
    Thanks. Great vehicle.
    I have a new 05 Limited, and this is my first vehicle with automatic climate control. I have a question for those of you that have this sysytem in your Limited. Why does the recirc come on every time I turn the car on when I have the A/C off? The outside temp is in the middle 60s, and I have the temp control set to 65 (the lowest) to just get fresh air coming in from the outside. If I push the recirc button to "off" (to get fresh outside air) the next time I start the car, it sets it back to recirc again. Why? It's not a big deal to push it to get fresh again, (I read an earlier post describing this as well) but I wonder why it does this when the automatic setting is set to off? I guess the AUTO function doesn't really turn off?
    I can understand when I have AUTO on and ask for A/C, the recirc comes on, at a higher fan speed at first, then, as the interior of the car cools off, the fan speed lowers, and the recirc turns off. But when the A/C is off, and the recirc comes on, (and never does turn off by itself as it does in the A/C AUTO mode) the car can never cool down with interior warmer air recirculated. The manual seems lacking in it's discussion of this feature.
    Thanks for any thoughts and comments.
