2001 Mitsubishi Eclipse GS
 muskiedude
                    Member Posts: 1
muskiedude
                    Member Posts: 1
                    I'm looking for some help or advice.
I just bought a 2001 Mitsubishi Eclipse GS about a month ago. The car runs fine, but several annoying noises have evolved after owning the car for a month. None of these noises were heard when I test drove the car or a week after I bought it.
The noises include:
1. A wind noise coming from the driver's side window when reaching 60 mph or above.
2. The black plastic dashboard makes a cracking noise when I go over any size bump. I have also noticed that this problem only happens when it is warm outside and am not sure if its the plastic expanding to the weather or if its a problem with the car.
3. You can hear the gasoline in the gas tank move around when you take sharp turns or when making sudden stops.
Has anyone had these kinds of problems with this car?
If so, were they able to fix them and how?
Do these problems seem out of ordinary to anyone?
The car's "wind noise" problem was worked on by the dealer, but hasn't been fixed. The other two problems have evolved just recently.
The noises include:
Later on the wipers came off (not turning) in a snowy condition. just imagine the sorry state I was in. It was such a pain. Now even my dashboard sounds like the same. Also, the plastic holder that holds the switch for the moon roof is loose and is about to come off. The drive is good but quality, it is bad
Mitsubishi was a misspelling by the Japanese, it should have been Myitsapieceashit (My o my, it's a piece of [non-permissible content removed]). Evolution of the name:
My its a piece a [non-permissible content removed]
Myitsapieceashit
Mytsupiesashit
Mitsubisashit
Mitsubisshi
Mitsubishi
In my book, Mitsubishi, compared to the other Japanese Manufacturers is the worst, and is a piece of [non-permissible content removed]. Compared to the world, it just average, the English and American cars still make Mitsubishi look good.
sounds like a speaker that has blown or something
If I had known it was made in the USA, I would not have bought it.
