Honda Accord Accessories
Prior to purchasing my '97 accord, the dealer assured me that I could get the remote keyless entry installed on the vehicle - is that not true?
Please let me know! Thanks!
My probable next change will be tires, after the original MXV4 Plus Michelins wear out. What tires have people tried, with what results?
I also want to add an exhaust eventually but I'm not sure. Do the aftermarket cat-back exhaust systems retain dual mufflers or are they just one?
Doug
What intake did you put on it??
Doug
I would like to add Keyless Entry on my Accord LX. Any ideas how much it should be? Any good sources? I am willing to install it myself in case it's not too demanding.
2002 Accord Value Pack:
I would like to add power locks in the front since I want keyless entry in the front. I have also been considering to add power window to the drivers side?
Any suggestions???
Your help will be really appreciated.
Tom
and as an aside, make sure any aftermarket intakes you get are CARB legal. i know AEM intakes are made to factory specs so you won't fail any emissions tests etc... which is why they're so popular. mine's great. you gain a few extra horses, a touch better gas mileage and great sound. (can't wait to transfer it to my '02 accord coupe that i just bought..had it on my '00).
I guess you have a coupe? I don't know of any horizontal guards you can put on to protect against dings.
-Chris
-Chris
Also, has anyone upgraded their sound system? I am looking to make a moderately cheap upgrade (under $500) and am looking for suggestions.
Thanks!!
my only problem with it was on the coupes there is a dot matrix pattern that the tint won't stick to, so it has to stop short of it. but on the 4doors that isn't an issue.
I am a new EX L 4 cylinder (eternal blue) owner. I would like to know has anyone had Honda foglights installed onto their vehicles? I am asking because the manual says you can't have them due to the "external temperature module" that's on the EX-L's and EX V6's.
Please advise....
In the almost 2 years i had them on my car i never had any problems with external temperature etc, and the light output was satisfactory for me. i'm sure that hella and philips etc. might have a brighter beam, but i was pleased with the OEM ones. probably one of the best non engine/suspension mods i put on my car. (the roads are kinda dark where i live).
can't wait to have the money to drop on a new set for my '02 coupe.
The dealers are charging an arm and a leg for the lights and install.
Maybe I will order from collegehillshonda.com for a decent price.
I'm a bit confused with the temp sensor/external temp module comments regarding fog lights. Can you clarify?
Also, to avoid any other existing wiring and/or sensors, why can't the fogs be wired directly to the positive terminal on the battery, through a relay and to the switch, with a fuse in between. I mounted two sets of Bosch lamps on two different vehicles this way a while back and aside from an occasional blown fuse (maybe three times in ten years), it worked well. It also provides independent control over the lamps from existing parking/head lights. Any thoughts?
http://www.collegehillshonda.com/instructions/03accord/foglights.pdf
cheers..
lots of people have bought from them, myself included.
there is also http://victoriatire.com/, and if you go to http://groupbuycenter.com, they generally have some really good deals b/c you're getting a group of people to buy car parts in bulk basically.
Please give me a email to kelvin@hkspeed.com, but is it possible to put it on my 03 accord LX?
Kelvin
Why 9005? 700 lumens difference.
