95 Jimmy Braking Difficulties
I bought a 95 Jimmy with 73K miles on it. Previous owner said he had never done anything to the brakes. When towing my boat, the truck was hard to stop, and I ended up downshifting in addition to braking (on a level, paved street). I re-did the front brakes, but the backs were hardly worn at all so I left them alone. Same problem. So I also did the back brakes. Still having problems. It almost feels like the back brakes aren't working. (A different Jimmy that I test-drove with 135K had a similar problem.. new brakes, but you had to stand on the petal to stop it, without a trailer) My mechanic said that the brakes on this vehicle are under-designed and oh well. Is this real? The boat is 3000 lbs, but the truck is OK to pull this amount.
Is the truck hard to stop w/o the boat? If so it can be the power brake booster, or the vacuum filter may be plugged giving a hard pedal. It could also be a bad proportioning valve, or the rubber hoses are flexing too much. I changed he ones on my car to stainless steel braided and it made a HUGE difference.
I can recommend to have trailer brakes installed. Will help greatly in the stopping power. I really don't think this should be nessessary with only 3 K lbs. Plus in addition to the brakes, you will need a controller and more wiring on the truck itself.
I believe my brake problem stems from GM using a hard pad compound, which wore my rotors to under service limit in the front (@ 38K miles) and the rear (@ 46K miles). I replaced them with NAPA premium pads and rotors, and flushed the system. Brakes work well. and I live in a hilly region, and pull a boat trailer, although I use electronic brakes.
So give the fluid change a shot... you'd be surprised how gunky brake fluid can turn, especially if it's original in your '95.
