Removing stickers, labels, decals, glue, sap...
bassman5x5
Member Posts: 1
I have tried several suggestions for removing tree sap from my truck without any great results. I would be thankful for any advise on how to clean the sap without hurting the finish. I have used: bug & tar remover, Lighter fluid, may,.....
See Also: Removing Stickers, Decals, Emblems From Your Car
town hall (in different conferences) on this
subject....
Thanks to Guitarzan's (hair dryer) advise, I was
able to easily remove the dealer sticker from the
back my new van. No scratches this time.
-Someone in another conference asked about removal of those garish (black/yellow) air bag warning labels on the visor. Just curious if anyone has been able to successfully remove those...?
Pocahontas
Community Leader/Coupes, Convertibles, and Sports
Cars
Pocahontas
Community Leader/Coupes, Convertibles, and Sports Cars
Pocahontas
The BEST way to avoid this problem in the first place is to INSIST that NO stickers be put on the car at all or you won't sign the papers! That should be on your list of things to say when you first go shopping for a car. MOST of them are UGLY anyway!
My "5-STAR" dealer DID put one on despite the fact that I told them NOT to, but I left it because it's one of the nicest I've ever seen. It's a chrome sailboat with just the name Madison on it. That's the "short" name of the dealer and the town where he's located. It's right next to the words Chrysler on my trunk. I don't mind it at all or I would have had him take it off the day I went to pick up the car.
fastdriver
I recently used Meguiar's tire gel successfully to remove some (fairly fresh) wax residue on textured black plastic parts on my new Odyssey. I have also used Aromorall and Mother's Back-To-Black with success, but they are alcohol-based and are apparently bad for rubber/plastic parts in the long run. Meguiar's is alcohol free and contains oils to condition rubber (and seems to work on plastic as well. I haven't found anything yet that's OK for flat black painted parts (Mother's B-T-B is for that, but again, the alcohol base).
Jeannette
Like an ear ring.
I not sure if this style of emblem is still being used.
If possible, look behind where the emblem is and see if it is mechanically fastened to the vehicle BEFORE you start prying it off, otherwise the sheetmetal can be bent and scratched requiring a lot more bodywork.
These decals cover some of the defroster stripes, so I sure do not want to use a razor blade or anything that will damage the defroster. Unfortunately, had to put them there to satisfy the security forces that patrol our parking lots.
Have to turn in these decals when I retire and no longer will be coming to work.
Thanks for the input. No they won't reuse the decals, they want them back for security purposes. This is a Federal Government installation and you can imagine how gun shy they are after the OKC bombing. Too late about leaving on the backing, they have been long gone.
How long does one heat the decal with the hair dryer?
If I had known that they wanted the decals returned when I retire, I would have used a spot
of glue or a small strip of scotch tape, but did not think to ask when I procured them. One gets old too fast, and smart too late.
APROX 5 MINUTES THE OLD STICKERS WHERE PEELED OFF WITH NO EFFORT AND NO DAMAGE TO THEM AND PUT THEM ON THE NEW WINDSHIELD
GIVE THIS A TRY.
EDD
then if necessary use the hair dryer. If worse
comes to worse, will take out the old windshield
with the sticker on it and take it to security office and see what they want to do with the stickers and windshield then.
They should have told me when they issued the stickers that I would need to return them if I got rid of the car or transferred or retired and was not coming to the office anymore. Would have fastened them with a small strip of tape that would have fit between the defroster filaments.
What a bunch of buttheads.
For those who need to attach a permanent sticker to the inside of a glass surface, but are concerned about getting it off later, you might wish to try this. The layer covering the adhesive will have to be transparent for this method to work.
Thanks, John
Pat
of a 1999/2000 GMC or Chevy pickup?? If yes,how?
My other option is to get a "bumper sticker caddy," so I can suction them to the inside of my rear windshield.
Thoughts?
Ntombi
Well, I have several, but the total message of them is that I am pro-choice, I vote, and I believe strongly in the separation of church and state.
Thanks, your host, Bruce.
Any suggestions?
Pat
Get a piece of dental floss and a hair dryer. First, heat up the area with the hair dryer. Then, while the area is still hot, slide the dental floss behind the plastic and it will pop right off.
prebmw,
You da man. I used the dental floss and blow dryer trick to get the dealer plastic tag off of my Honda Odyssey. It was incredibly easy. I did have some tape residue after I got the plastic emblem off but that washed off easily with mild soap and water and a little elbow grease. Couldn't even tell it was there.
On the window sticker question, I used the product "Goo Gone" to remove the sticker residue on glass. It came off easily.
Hope this helps...
Does the dental floss approach leave some of the adhesive on the paint?
BTW, these are the plastic kind of stickers, not the paper type.
Now, does anyone know how to remove duck tape residue from a car? The best thing i've found is alcohol, and that's not perfect.
Chandra
If something stronger is needed, try kerosene. Small bottles of scented lamp fuel are readily available in many places. I have also successfully used charcoal lighter fluid in some cases.
Gasoline seems way to dangerous, though for years my dad used it to wash off engines and other car parts, and to clean paint brushes. He never blew up, but I think he was just lucky.
Nail polish remover is alcohol and acetone. I would be very cautious using it with plastics.
