Help me understand 1/2, 3/4 and 1 ton pickups differences
the differences in these three classifications with respect to the trucks offered by Dodge, Ford, Chevy/GMC, and Toyota. I see compact, full-size, and heavy duty variations, but I do not know if these associate or not with the 1/2, 3/4, and 1 ton designations.
I am trying to get a better understanding so that I may better consider apples to apples and oranges to orianges. Any help would be greatful. Thanks!
See Also: Everything You Need To Know About Truck Sizes & Classification
Most pickup trucks that you see on the road are of the 1/2 ton variety. They're a good all-purpose vehicle, great for hauling light loads, light duty trailering, etc, or just commuting back and forth to work but for those that want more versatility than a car
3/4 ton trucks have stronger suspensions for hauling/towing heavier loads. I think they're the best choice for using a slide-in truck camper, for example.
1-ton trucks are usually the ones that you see pulling big horse trailers or big 5th-wheel RV trailers. In addition to stronger suspensions, I think they also have beefier frames. And I think most 1-ton trucks are duallies (dual rear wheels in the back).
I'm sure some of the pickup truck people on these boards can explain it better than me, but hope this helps some.
-Andre
Most 1/2 tons weigh 4400lbs. Most 3/4 and 1 tons weigh around 6,000 lbs. Rough payload capacity is the difference between the empty weight and the Gross Vehicle Weight Rating.
GVWR is found on the sticker on the driver's side door jamb or door.
When I look at the Ram 1500 and compare it to either the 2500 or 3500 I am not sure I see this difference in frame, which makes me pause for further investigation.
I am not sure if I can begin to understand the differences on the GMC/Chevrolet trucks, because not only do they designate via # (a la 1500, 2500, 3500), but also distinct via HD and non-HD.
I have no loyalties since I've never owned a pickup, neither new or used. I have no real friends that own pickups except compact units (one has a 95 Dakota, one has a 97 Tacoma, and the other an early 90s Ranger), with the exception of one friend that has a '93 F150.
So, when I try to compare apples to apples for what my yet undetermined minimal needs/desires are, I would like to compare a proper Ford to a properly equipped Chevy and Dodge.
One thing that has bothered me is Dodge's decision to not explicitly state the curb or unladen weight of its Ram pickups. This is annoying in that one must subtract the payload value from the GVWR to get a sense of the vehicle's weight.
So, the research goes on. I will be buying around April-May 2002 when the lease on my car ends. So far, I will only consider extended cabs with functional extended cab doors and also four-doors. A 6.5 foot box is a minimum requirement. Diesel is no option due to costs. The truck's role is primarily daily driver and box hauler secondary.
I'm in Atlanta, but I've seen and am getting the strong feeling that I could acquire a Ford 250/350 for dang near Invoice. Also, I was surprised that brokers (carsdirect.com) could get me into a Ram 2500 Cummins for about $26K.
My problem is that I am months away from test driving these rigs and haven'y even determined if maybe a compact 4-door 2WD pickup could fill my needs and desires. I'd appreciate any additional feedback.
It is difficult dessimating through the information, talk, and arguements when there is a lot of hearsay, rivalry, lies, etc.
Lots of luck.
Chris
2. Underneath there somewhere was an original designation of the load carrying capacity of the different models of truck. Half Ton, Three-quarter Ton, One Ton.
3. The "rated" load capacity of a vehicle is dictated by the Gross Vehicle Weight Rating as restricted by the brake system that is installed. It appears that the physical weight capacity of the tires, axles, and suspension is not the "weakest link" in the equation.
4. The actual load capacity of a vehicle is the actual unloaded weight subtracted from the GVWR. A bare-bones, stripped of accessories, vehicle will have a greater load capacity than a luxo-barge. My K1500 ext. cab weighs about 5300 pounds according to the scales at a local truck stop. GVWR is 6550. No bed mounted camper for me unless it's a Four-Wheel Camper aluminum job.
5. Since the distinction between model capacities has been clouded, you have to decide what your needs and requirements are and shop accordingly.
6. If you are going to get a commuter/weekend project truck, a half ton will probably suffice. If you are looking at a camper (pickup bed mounted) or towing a trailer (pull behind or fifth wheel), then the heavier duty models will apply.
7. BOTTOM LINE. The capacity of the vehicle brakes appears to be the limiting factor and salespersons are usually clueless...
8. May the Force be with you and your calculator.
3:73, 4:11 and higher torque. Many 3/4 ton reg cab pick-ups can handle greater
abuse that 1/2 tons and are quicker due to axel ratios. If you want to soup up,
increase performance, 3/4 ton will handle extra power, torque without significant upgrades
to tranny and rear end....example my '00 C2500 will smoke 98 % of F150 5.4's andl all
F250/F350's due to greater power from 5.7L vortec.
Personally, I have a base model V6 Silverado and also have on old 73 3/4 ton beater for the heavy/dirty jobs. I can't see paying over 20K for a truck - I still think they are trucks, gussied up or not. But each to his or her own. Good luck.
