Oil Weight vs. MPG
How much would you expect gas mileage to deteriorate by switching from a 30 weight oil to 40 weight? From 30 weight to 50 weight?
Hypothetically starting at 20 MPG with 30 weight ...
30 to 50- 1.5 to 2.0 mpg.
According to general knowledge Synthetic has less friction. Generally they say in Oil a slippery subject part II that you can go up from 30 to 40 without any loss in mileage.
I do remember some friends of his had a 1982 or so Bonneville G with a 231 that ran poorly. He changed the oil for them, putting in 30W, and it ran fine. When I bought an 11 year old '82 Cutlass Supreme with the 231, I put 30W in it, and it ran fine. But then one of my friends told me that I didn't need oil like that in a modern engine, and would get along fine with 10W-30, along with better economy. Weeell, about a month after I changed my oil, with 10W-30, it lost all oil pressure! Ended up changing the gears in the pump, which were all chewed up from engine fragments, and it ran. Not well, but it held oil pressure. Also needed a quart every 300 miles or so. I took it to my local garage, who said I should shoot it there and not put any more money into it.
I'm wondering now if that car was on its last legs to begin with, and putting the straight-30 oil in just prolonged the inevitable. I wonder how long it would've lasted if I'd stayed with the 30. Well, I guess when you pay $800.00 for a car, you can't expect it to be perfect!
I'd be afraid to use a thick, straight-weight oil in a brand new motor. There are tight, tight tolerances that the thicker oil may not make it into in sufficient properties for effective lubrication. Use the thinner stuff (5W30, 10W30) until your motor shows some evidence of wear and then gradually move up to the thicker stuff like 1040, 15W40, etc ...
acd100, I'd never express even a mileage gain guess in terms of miles per gallon. Whatever you think of the issue (and I DO think that synthetic oil which flows easier and has a lower coefficient of friction provides better mileage) you should probably post guesstimates in gains in percents.
For example, if I have a Honda Civic that normally gets 40mpg and my brother drives a Ford Expedition that gets around 12mpg and we both switch to synthetic, we could both gain about 2-3% more mileage. For me that would be 1.5-2.0 mpg but for him, it would mean an increase around 0.5 mpg. See how that process works out to more realistic numbers?
--- Bror Jace
As a result, the management talking heads nixed the conversion on the basis of no percieved energy savings. At least I got a performance award for initiating the project. Works for me. He-he.
You're right, there are plenty of variables but you hope the pwerson asking the question understands that going into the discussion. Like my car LOVES jihj temperatures. Once it got into the 80s and 90s around here (Saratoga, NY) my car went from 39-42mpg (fall/winter/spring) to 43-45 mpg.
zr2rando, STP is viscosity improver like that used in most multi-viscosity oils. The stuff works (as you've found out) but you have to watch it under severe duty service (extremely high temps and RPMs). Those conditions can break the long-chain STP molecules down and you are left with varnish and goo inside your motor. So, either keep the conditions to the point where the STP won't be broken down or change your motor oil & filter fairly often ... like 5,000 miles MAX.
--- Bror Jace
I filled a mayo jar with used 10w30 and another jar with used 10w30with STP and compared them to each other (visual comparison, not very scientific..)
Out in the garage (temp about 85F I live in NC) the stp oil looks a little smoother, when you shake it up and watch it drip off the top it drips in longer strings from the lid...
I put both jars in the freezer and expected the stp oil to really thicken up more than the 10w30nonstp but they both looked just as thick.
I change oil every 3k miles so hopefully I'm not pushing any limits too badly
The stp bottle says it contains "olefin copolymer"
I think I've seen that listed as a componant in synthetic oil too (not positive though) any comments on that ? is that the Viscosity Improver your talking about?
Harry
I've found in the heat that air conditioning has far more influence than an increase in oil weight.
Whether to move up depends on a number of things. How old the engine is, Manufacturer's recommendations, and whether synthetic is used. Many in the oil sites have said you can go up one grade (i.e. from 30-40) with synth without much influence.
QS 5W-20 already meets the new SL standard. the 5W-30 should soon, but I wouldn't put in 5W-30 until it qualifies for the highergrade.
Synthetic already meets the higher standards, so a 5W-20 Syn might be the best. At least during the warranty period. After that, the SL should be out, and you can move up to a 5W-30.
Speaking of standards, are we SURE that SL will be better than SJ? We know one of the things that changed when they moved to SJ is that the amount of ZDDP (zinc phosphate), an important anti-wear additive, was significantly DECREASED. SH oils may actually be BETTER for your car in the long run. Look at some of the racing formulas ... many are SH rated.
--- Bror Jace
Results:
Subaru 27 MPG
Mazda 26 MPG
I'm not going to worry about the heavier weight.
I wouldn't use a wide-spread motor oil. The polymeric goo that is used in them is an oil's weakest link. This stuff is the first to break down in the oil (after only a couple thousand miles) and when it goes, your protection is compromised and the leftover, broken goo can sludge up your motor.
If you use it, don't EVER leave it in for any more than 5,000 miles.
--- Bror Jace
They also said this about their mileage.
A 50 Weight synthetic will take about 1-2% reduction in gas mileage over a 30 weight oil.
Conventional oil reduces mileage performance by 1-2%.
So roughly, a 50 weight synthetic has roughly the same performance as a 30 weight conventional.
The down side is that there is no anti-wear package and TBN additive. Mobil ran lots of tests against competitors' syns and many did not meet TBN and wear requirements after tripple and quadruple Sequence IIIE, VE tests (API). This would imply that QS could not be used for extended drain intervals. I have found that the guys that answer the 1-800 calls for the oil companies may just be talking heads. Others on this board may be able to shed more light here.
http://www.sae.org/servlets/index
The report is Technical Papers Series- 951026
Pretty lengthy report-worth the 10 or 20 bucks I paid for it.
