Bouncing Betsy
I also have experienced "bouncing" on certain freeway sections. I have a 2000 (2500 longbox) 4X4 with Firestone tires. If I don't vary the speed in those sections, the bouncing and shaking can be a pain. This problem always occurs at the same section of the freeway that is a small part of my daily commute. For that reason, I accept the theory that this is related to the expansion seams between concrete sections and not the fault of the truck. I know that this has been discussed earlier but please give me some advise as to what if anything has been done about this problem. Love the truck and hate the ride. The problem is much worse when I tow my 5th wheel which is only 25 feet long.
PF Flyer
Velvet ride shackels will help absorb some of the bounce. I have a pair installed on mine.
You sound like you need a daily driver. If you want to compromise on towing and hauling capacity, then consider a 1/2 ton.
If your 25 ft. trailer is less than 7200lb loaded, and you tow on an infrequent basis, you would be MUCH happier with the Tundra. Read this article:
http://www.trailerlife.com/test/0002tundra.cfm
Test drive a Tundra over the same section of road. You will be amazed.
www.tundrasolutions.com
lots of serious issues concerning the tundra and it's towing capacity.
Make that sharp turn with that short box
and the 5th wheel will be smashing into the
cab.
Ziggy you have the right truck for the task.
I went from a 1/2 to 3/4 ton Chevy and the
bouncing IS more pronounced esp. unloaded.
But I needed a truck to WORK and the toy
wouldn't cut it...I can live with it......Geo
Harry
Bilstein
Front BE5-6081
Back BE5-6082
You could also check out Edelbrock and KYB. BTW, I dumped my Firestones on my Denali and replaced with Michelins...made a world of difference
I wonder why.
Why did you buy a 2500 series truck if you drive more without a load than with a load?
Do the velvet shackles help on the magma roads? LOL
-Eric
But if you compare wheelbase, the Denali is similar to a regular cab short bed. So the comparison would be different, not sure if the Denali XL or Yukon XL has the bounce.
One thing good about magma roads....it continually resurfaces itself.
Harry
Harry
I don't think Bilsteins do either, but they do (or did) have a lifetime warranty, and nitrogen charged which prevents oil foaming, or air bubbles. This insures even, consistent performance. Bilsteins had a reputation for being on the firm side.
I've often thought I'd like to put Bilsteins in the rear, and a speed sensing shock, Edlebrock, Reflex etc up front.
Has relatively new shocks - standard, nothing fancy. I'm wondering if it could be transmission, drive shaft or something else? Just started over the past year. Has about 65,000miles. Any ideas are welcome. Thanks
Ryan:
I don't have a good source for Bilsteins, I mostly sell NAPA/Monroe or KYB's. I stock some of the Monroe, and special order the KYB's from Stempf Co. in Minnesota.
Harry
