Astro air vents fail when accelerating uphill
I have a '97 Chevy Astro van, AWD, 80k miles. Recently, while accelerating uphill, the airflow stops coming out of the 4 upper air vents on the dash. This includes Vent and A/C. Air continues to flow from the lower vents as well as the defroster. The airflow returns to normal when I stop accelerating, or go downhill.
A friend told me that it is probably a vacuum leak. My question is.... how do I find and repair this leak?
Any ideas? Thanks!! Rick
One check, start the vehicle, let it run for a bit, then shut it down, wait a couple minutes, and pull the valve at the brake booster. You should hear a decent hiss from it. If you don't. the check valve is bad.
How does it idle?
How are the brakes?
