Buick Rendezvous Accessories and Modifications
because my wife puts the position of the driver seat quite differently than I and that the electric motors are quiete slow, I would like to add the memory1/2 buttons found in the luxury version(CXL)car door (I think) to my own car - is this possible? do I have to change seat?
thanks to anyone that could help.
JK27
In terms of versatility attachments, carriers etc?
I've been told it's not DOT compliant, can get a ticket.
Thanks all!
IMO Far better deal than buying a comparable Thule or Yakima unit (often double the price) AND you still have to buy the mounting kit!
Crosswinds affect the RDV alittle more than without it up there, but not unsafe feeling or scary.
Hope that helps!
We drove through a big rainstorm once and everything inside the carrier was dry when we reached our destinations. Most soft carriers are not waterproof.
Thanks for the info! I really appreciate it. One more question ... does this unit attach to the cross bars or to the side rails (or to both)? Thanks again!
JK27
I did the latter, but they stripped the key so that it didn't work, but still bypassed the electronic code to allow the remote starter to work.
Does anyone know if its possible to add 3rd row seats to a 2003 Rendezvous that did not originally come with 3rd row seats? Thanks.
To do it correctly, you should also add the 3rd row seatbelts as well. You will need the belts and buckles of course, but also D-pillar plastic trim covers from an RDV that had 3rd row seat... Although you can probably drill holes in your current pillar covers for the belts. The mounting points ARE behind those pillars.
You can locate most of the parts for a reasonable price through salvage yards or fleabay.
Good luck and happy hunting! HTH
Matt
you posted.
That one Is so poorly designed..
I have the auto climate control version and, in the winter, it will put 100% of the air (heat) on the floor -- not through the dashboard vents. At first, I thought this was a bit weird, but seeing as hot air rises, I've found that this very quickly heats up the car. The volume of air that comes through the vents on the floor is HUGE.
There's definitely something wrong with your heater. I could not keep my heater at 80 degrees (even in the winter) without opening all the windows! My heater keeps the car very comfortable when set at 72, 73 or 74 (e.g., warm enough that I do take off my coat -- and I live in Wisconsin!).
Are you setting the vents to the floor (not through the dashboard vents)? A lot more heat will come through the floor vents than through the dashboard vents.
Take it to a different dealer if your car still does not heat up sufficiently!
Had no problems with AC during last summer, mileage 0 to 5000
One has to remember that it is a large area to heat up so I won't work like a small baby car.
The others who have heating problems, what year is your vehicle and do u have Auto climate controls and if so does pressing the vent button make a difference?
I just got one from the Hitches-forless and it labled 300Lbs tongue!
I don't get it!
This morning only level 5 works and it is very loud.
Anything I should check before I take it to the dealer?
I did the obvious CB and nothing is blown.
Perhaps it is mechanical contacts, but I am not sure.
Any suggestions? Anyone has the Michelin LTX® M/S P215/70R16? Are they quiet?
Have anyone had problems with excessive noise from the rack and pinion when turning?
~Ken
I removed the 4 screws holding the glovebox and the large plastic covering the air blower below the glovebox but it still will not come out. I suspect it is clipped to a bar runnning under the bottom of the glovebox - but not sure and I do not want to break anything. Anyone know if clips hold it to the
black bar?
Also, has anyone put the Xenon headlights in, or know which ones would be good for them?
One more thing, is it worth changing the stock CD/Cassette player to get a new CD player just to get a system put in the rear? If it's a lot of hassle with all the speakers in there, the steering wheel controls and all that, I'm not going to mess with it.
Thanks for all the help in advance!
Thanks again for the site, if only they showed more sizes.
Also want to give thanks to everyone on the board. I cut and pasted all the recurring problems and when I went to my dealer for service I pointed out the elbow for the BCM, the rear bearing issue and the head gasket and all issues were well taken and resolved without problem.
Now - due to the board's experiences that pointed out problems with my CXL - I still love my CXL and want to keep it for a few years but I don't dare go alone without an extended warranty.
How much is decent to pay for a $0 deductible 7 year 100,000 mile warranty?
