Find an empty parking lot. Do the low speed turn to recreate the noise. Now, VERY carefully, accelerate back up to 20mph or so, take your foot off the gas and put the shifter into neutral (making sure you don't go into R or P). Then bring the car to a stop in the exact same way that caused the noise.
The reason to do this is to disconnect most of the drivetrain from the wheels during the stop. If you still get the noise, it is probably brake or bearing related.
Do you have any warning lights on? If ABS was malfunctioning I would expect an ABS light.
Do you feel any pulsation in the brake pedal when this is happening or is there only a stuttering feel in how the car stops?
==-Kate-==
Let's hope for the easiest.
How many miles on this vehicle?
Fuse 32 in the main fusebox under the hood.... a 20 Amp fuse. See the picture below (note arrows)
Nick">
1. Last week the blower fan died speeds 1-5 and I saw the fuse was blown. I went to the store & got some new 25A fuses, put one in and the fan started to work again but only on speed 5.
2. I googled this information and read it might be the blower motor resistor, I got the part for $35 from autozone and watched a youtube video of changing this on a chevy, so I did it myself. (the old resistor was discolored & actaully could see a soldered connection on the metal part was melted off.)
3. After the new blower motor resistor was installed, putting the blower back in etc., I put a new fuse in & started the car. As soon as I went to fan speed 1 the fuse blew in the car. I made sure the A/C was off. I put another fuse in and started the car with the fan on speed 5. it ran and as soon as I changed the speed to 4, the fuse blew again.
4. I looked up more online and though maybe the blower motor itself was bad.
I disconnected the blower motor connection, and I could turn the AC off and on, or any dial position speed w/o the fuse blowing, so now I thought it was the blower motor.
I bought a new one for $92 at autozone and decided to hook it up to the connection, holding it under the dash w/o installing it and started the car. As soon as turning the fan to speed 1, the fuse blew again.
SO.....at this point I am at a loss. I was hoping changing these parts would correct the problem, but it hasn't. I am not an electrician, so don't know how to diagnose wire problems.
Before heading to the mechanic I was hoping to get some advice on this, from anyone who knows. :confuse:
Thanks!!
In addition, I have an intermittent problem, especially when accelerating, where the battery light will come on, all of the alert lights on the dashboard will flash off & on and it will make a dinging noise for a few seconds. Then the AWD disable lamp comes on. Sometimes it will go back off when I come to a complete stop, but not always. Sometimes the battery light will alternate a few times with the ADW disable light before it stays on the AWD disable light.
Recently, my battery also died when I left the radio on for an hour or two. Previsouly I've done this with no problem (we have a drive-in movie theater nearby where the sound is broadcast over the radio, and we've watched movies there in this vehicle with no battery problems). I was able to get it jump started.
The delaership was unable to come up with anything for any of these issues. They did fix a loose battery cablewhen I had it back in the shop the other day, but did not find anything else. Within a day or two the gas cap lamp was back on (not constantly, it comes & goes) and the service engine soon light is back on. When getting on the highway earlier today, it also did the lights flashing / dinging, battery light, then AWD disable light thing again.
I'm getting frustrated - there has to be a cause to all of this. Any ideas?
A weak battery can drop voltage enough and the various computers quit operating at a voltage too low.
I've had NO problems at all with my car. I have only done oil changes, and fluid changes and tires, and one hose, that was getting old, as I have had the car since new, and it's now 7 years old.
I'm looking for another SUV, only I HATE the looks of the Enclave, and also they took off standard features I have in mine. The only way to get the passenger and driver adjusting seats (up and down) Is to go all the way up to the Arcadia Denali, for about $50K.
Anyone had any suggestions on what you may have replaced your car with?
2007 RDV owner here. Very few problems like you, and we like it a lot.
There isn't anything quite RDV sized in the market. Do you want to go slightly bigger or slightly smaller? For slightly smaller I would look at the GMC Terrain and Ford Edge. For slightly larger, since you don't like the Enclave, and you've checked the Acadia, take a look at the Chevrolet Traverse and also the new Ford Explorer. I know you may be thinking "I'm not looking at an Explorer" but the new design is very nicely done, attractive and good materials. As they say "you owe it to yourself to at least take a look". Good luck!
Sorry to hear about your lemon.
So, you said you were having "problems" and "even had a fire under the dash". What were the problems you had before the fire happened? What were your initial symptoms, so that we can try to help. Thanks.
Brian
I apologize for your frustrations. Have you spoke with GM Customer Assistance? If not please feel free to email me and we can discuss setting up a case for you. Enjoy your weekend!
Christina
GM Customer Service
The keys are programmable into the list of 10 acceptable key entries by putting in an original key from the list, turning it to ON, then removing it and putting in the newly cut PK3 key. Turn it to ON for a second, and then turn to crank the engine and start.
The key fobs must be programmed into the computer by a Tech II or other electronic device capable of accessing the computer. This will be hard to find outside of a dealer. There may be a local mechanic who has one products that can access the computer and handle the programming, but they are also going to charge--unless you have a friend with access to one.
There may be some websites that list local companies that can do that for setting up your key fobs. But the dealer can check and program in a fob, that you conveniently buy from them!
It may appear to cost more, but I think your best bet is to have a dealer check into this for you.
There's a manual method of programming keyless entry transmitters also. Make sure that you have all the transmitters you want to be able to use handy because the system will have to "learn" each one, even if they already worked before. If you have the memory seat/radio/mirror option you'll need to program the remote for 'driver 1' first, then 'driver 2', then up to 2 others.
1. Close the vehicle doors.
2. Turn OFF the ignition.
3. Remove the ignition key from the ignition lock cylinder.
4. Press and hold the driver side door lock switch to the unlock position.
5. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
6. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
7. Insert the ignition key into the ignition lock cylinder. (Do not turn the ignition key in the lock cylinder.) Leave the ignition key in the ignition lock cylinder.
8. Release the door lock switch. The body control module (BCM) will sound three beeps in order to verify the Program Mode has been activated.
9. Press the lock and unlock buttons on the keyless entry transmitter simultaneously for approximately 5 seconds . The BCM will sound two beeps in order to verify that the transmitter has been successfully programmed.
10. Perform the previous step to program up to four transmitters.
11. Remove the ignition key in order to exit the Program Mode.
12. Verify the proper operation of each transmitter.
Good luck! Nick
The shop foreman told me he hasn't seen this happen but a couple times in the past 5 or 6 years; that its kind of a fluke thing to break. I'm still in shock but I have to repair it, as the car is worthless as a trade in if its not fixed.
Thanks for any tips or comments.
http://www.amazon.com/ACDelco-D1469G-Ignition-Lock-Cylinder/dp/B001S7N4AC
That is your part there. OEM Part # 15298923. You can most certainly replace just the bad ignition lock cylinder and its CHEAP ! I would go back to them with the printout and be polite, but firm, that they almost took you for $1800, that you are not happy, and that you want the work done at a discount or you will take it elsewhere. Even if you have to pay for another tow, that is far cheaper than letting them rip you off.
Of the repair bills, I found I spent about $8000 on repairs.
I would recommend asking the dealer to look into them. If you do not trust the dealer I would recommend a second opinion from a different GM dealer. Please keep me updated on your situation.
Christina
GM Customer Service
We had a similar problem. Have the dealer (or yourself) take the front wheels off. On the back of the brake rotor, there is a piece of sheet metal (probably used to protect the brake rotors and pads from rocks or branches.
We had a similar problem with a "clicking" noise when turning and it was coming from the front wheels. I pulled these pieces of sheet metal away from the brake rotors, and the problem went away. Now every six months or so, after the sound returns, I bend the sheet metal away from the rotors and we're good for another six months or so.
I hope this helps.
I apologize for the problems you are experiencing with your vehicle. Were you planning on taking the vehicle back to the dealership? Please keep me posted.
Thank you,
Caron, GM Customer Service
note and the other an double note. They seem to be about a minute
apart and I can't see anything in the owner's manual which refers to
sound alarms. There are no warning lights on the dash. Are these a
sign of something serious? Or can I ignore them for a while until I
can afford to have them investigated.
Thanks for any help
Ann Forrester
I have noticed that the coolant needs replaced and a radiator flush is desperately needed as it's all gunky in the overflow container. The temp gauge runs a bit past the middle line, but does cool itself down pretty quickly. The gas gauge is a pain in the rear, once the tank is on half, it never gives off an accurate fuel amount, it's either full when it isn't or empty until I make a tight turn. Luckily I haven't ran out of gas yet
Passenger side window makes a crackling sound when it's rolled up or rolled down, thought to be dirt...but I'm not wagering on that theory. I didn't read reviews on the vehicle before I bought it. I had to get a large vehicle with 3rd row seats as we have 4 children at home and 2 in a different state who come to visit. I love my truck soooo much despite all the bad reviews and the fact that I might not be the lucky RDV owner that I thought I was lol. But any idea on what the problems may be?
Also, this just started today. When I first bought the truck none of the cig lighter plugs worked, changed the fuse and they were fine. Today(3 months later) the fuse has been blowing again. I replaced it this morning, and within an hour the fuse was blown. We thought maybe it was the car charger as it's just a cheap universal one, took it out, fuse still blew. Thought it was the radar detector, unplugged it, fuse blew again. We haven't added any new things to it, just did an oil change, and changed out a fog light. My rear end is also uneven. We had a rear suspension spring fixed on pass side, the drivers side is still good so we left it alone. We also noticed the black rubber tubing around the self adjusting air suspension metal rod things behind rear tires are all eatin up, and the metal behind the rubber is rusted out. Do we need to replace air suspension? We have the built in air compressor which works fine, but scares the $^(&&*^* out of me when it runs lol
Help anyone? I'm at my wits end. I'm okay with fixing it and i'm okay with always fixing something as I love my truck so much, but where do I start? My husband is pretty mechanically inclined, but I need to learn the in's and out's too. Thanks in advance. ~Tami~
I took my truck into a mechanic today, (I wont use a GM dealer because they OVER price everything). for the rear end noises, which after reading several threads, sounded like a rear diff problem. Most of the posters said the noises went away after refilling the rear diff, so I took the truck in to have the diff filled, and the mechanic is trying to tell me I need a whole new rear end. I'm not sure what to think of it actually. It could be the rear diff does just need fluid, but the dealer I bought the truck from did no repairs to anything at all. He did fix a rear spring that I noticed was broken into 2 pieces, but once he changed that spring my rear end became very un-even/lop-sided. The truck has a very obvious lean to the left(drivers side). I only notice the noise when making tight left hand turns, and mind you my air shocks are completely shot, in fact they may be the original shocks that the truck had put on during assembly.
Could it be possible that the truck is moaning when making the left hand turns due to a substantial amount of weight bearing on the left hand side due to the lean? I'm wondering if fixing my shocks, driver side spring and filling the rear diff would help the noise. I'm thinking now that it may be a rear wheel bearing making noise due to the huge load put on it when turning into the lean? I hope that makes sense. I'm just wondering if this is a possibility or if I am really looking at a new rear end. I also have a slight wobble in the passenger rear tire, also wheel bearing? Or could it be just a simple balance issue? The moaning noise does happen when turning right, but it's not as noticeable. In fact I haven't noticed it but my husband says it's there.
Anyways, that's whats going on so far...I think. I will be taking it in to a few more mechanics to have diagnostics ran to figure out if I really need a whole new rear end or not. As far as my mirrors, window, heated seats and memory seat goes...I have bigger fish to fry with this truck before those are dealt with, but I will keep everyone informed as I go!!!! BTW- I STILL love my truck
Moan or groan typicly at slow speeds from the rear could very well be either low on fluid (meaning there is a leak somewhere) or fluid just needs changing (via the 'proper' procedure).
**However, Standard Rear differential fluid does not remove the sound when you have a buick. You must buy the actual Buick Rear differential fluid from the buick dealer.
Then you drive your car in doing several figure 8's in both directions and that fixed my problem. Much cheaper than $1200. My husband did this in about 20 minutes himself on this second round. I was advised on the internet that you want to change this fluid about every 20K miles with Buicks. I am glad my car no longer sounds like a moaning old person.
I will also be adding changing the rear diff oil as a regular maintenance thing. I would much rather spend the $60 for the fluid change than the whole rear end. IF I do need a whole new rear end, I have a friend of the family who is a mechanic and he is going to build the rear end for me, instead of having my mechanic order a *GULP* used one. I can't see paying $900.00 for a 94k used rear end, that would take a crap 30k miles down the road, to just have it done all over again. I just read that your husband took care of the rear diff oil change. Buying the oil is crazy expensive!!! I have a mechanic here willing to do the whole thing plus ordering the oil for the $60.00 And yes I will be watching to make sure it's the correct versatrac oil.
It's much more cost effective to just build the rear end than to buy one.
Too hard to be sure from your description if it's suspension related or drivetrain. Describing the type of noise you hear "when turning left" might help us. But it's still hard to diagnose over the internet. Reputable shops generally give free estimates, especially the independent ones. I would get a second opinion and go from there. If he really has to replace bearings in the differential, $400 doesn't seem out of line.
With all the electrical equipment on these vechiles today, u need to monitor the charge.
We do not drive much lately and on a trip i noticed the Buick was not running that well, i figured it might be the gasoline, but I use " LUcus injector fuel system cleaner).
Well when i got home i cked the battery and found it to only have about 200 amps on the load test - I charged the battery and now it has a 600 amp after load test and it runs alot better. I now keep a $5 trickle charger on it nitely so the charge is strong.
Donot ever buy a cheap battery - Get one with 3 yr full replacement free, 7yr pro rated after that, the different may be $30, but its worth it in the long run.
Maybe I misunderstood your advice to everyone, but something isn't adding up.
Your car started just fine, and you left on a trip. During the trip, you felt the engine wasn't running up to par, is this correct?
Although it's possible your battery is getting old and not holding its charge, and that may be happening based on your low load test measurement, you have or had another problem going on as well.
Once a vehicle is started, it doesn't technically need its battery to run at all. The alternator creates the electricity needed for the engine to run and all of the electronics as well. If the engine, once started, is not running well, AND the reason its not running well is due to insufficient electrical power (which your load test alone doesn't prove) then your alternator isn't creating the voltage and/or current it should be.
Putting your battery on a trickle / float / slow charge each night shouldn't be necessary, even in the harshest of climates and even if its sits for weeks. If it really runs better on days after you've charged it compared to days after you didn't charge it, either the alternator is not up to spec, or the battery has a problem, perhaps even a small internal short between cells.
What voltage are you getting with the engine off? Should be around 12V. What voltage are you gettting with the engine running? Should be close to 14V.
Lucas fuel system cleaner is good stuff, provided you don't overuse it, but if you did have a bad tank of gas it can't fix that. It does almost nothing to help get any water out of the gas which is the most typical "bad gas" issue. It contains detergents that will clear intake valves, clogged injectors, etc.
In the future if you feel you got a bad tank of gas, the best additive would be one bottle of something like Sta-Bil moisture absorber/gas stabilizer. Dosage per label.
As I said, maybe I misunderstood something, let us know so we can better assist you. And keep enjoying the Buick -- I come from a long line of Buicks so to speak 61 Special, 74 Century, 81 Regal, 83 Regal, 89 Regal, 98 Century, 07 Rendezvous.... and too many other GM's to bother listing.
Hoping for a 2013 Regal GS next, what a beautiful car.
