6.0 liter knock
I was just curious who has the infamous "normal" 6.0 liter engine knock? My 6 liter knocks like crazy for up to 15 minutes after start up. It will also knock after the truck has been sitting for a half an hour, so it is not really a cold engine knock. I have about 6,700 miles on this engine and this is the second engine in my 2000 Silverado. GM replaced the original engine at 15,900 miles for the same reasons (knocking and tapping). I would like to show GM that there is alot of other people that have the same concern that I do. I don't feel that I should have to turn up the radio to block out the noises when you have paid over $32,000 for a new truck.
If the problem is oil not staying up where it should be, this might help. If it is slop in the fitting of parts, it might require a serious heater to get the engine up to operating temp before starting it. ;-)
I have a 2000 Silverado 1500 with the 5.3L engine, and it has the same symptoms as you discribed in your message. The dealer is telling me that they (CM) will have a new piston which will correct the problem, but that it won't be out until December. Is that what you are hearing also?
Sounded like a lifter to me in my 01 6.0.
My bud has one of those stethoscope (spl)
things. It worked great..............Geo
-- Don
Oh and regarding your engineering as bobsquatch stated.... That special hell awaits you! LOL
Ray T.
Yes, I got the same story. The shop foreman listened to the knock himself and diagnosed the problem as piston slap. He said that GM is planning to replace the pistons along with new rings, connecting rods, and connecting rod bearings. I am not too excited about having a dealer rebuild the engine, so I plan to complain to customer service (they have issued a file number on my case). I would much prefer to get a factory engine, but GM's warranty gives them the right to rebuild it. Anyway, I will seek an extended warranty if they rebuild it.
By the way, my son-in-law has a '99 Sierra with the 5.3L that knocks worse than mine. It has 80K miles without any problems...and he drives it rough.
Let us know how your case goes.
So why not leave yours alone?
"if it aint broke dont fix it"
When your buds used to flame Fords for the piston slap in the '99 5.4's I didn't see the same stand.
BTW, Ford replaced motors, not just pistons if I remember correctly.
You should tell Oby to just accept any vibrations because it's really not affecting the longevity of the truck.....just really a nuisance, that's all. Why get the clunking intermediate shaft fixed??? It's just a noise. LOL!!!
If i knew it didnt affect the trucks performance, reliability, or anything else yes i would.
It seems many trucks like the example above with 80K have it with no ill effects just a cold start knock which goes away. If it knocks all the time (isnt that the case with the F150s? im not to familiar) thats a problem then but if it goes away within a few seconds i wouldnt worry about it.
MOD you have to agree with me a little on this too. Alot of people complain about vibs who have never driven a pickup. They arent used to how a truck drives.
Why get the steering shaft replaced? Well because it was loose? Possible safety hazard? I know after mine was changed the steering was very improved.
Ryan
After soaking the pistons, decarb, checking purge and cannister system and balance test. The conclusion by the dealears service dept. is that the engine noise is the same and increases slightly with RPM. The service Mngr., after discussing my problem with his district service rep., has told me that some 6.0 engines have pistons that are out of tolerance. New pistons will not be available until sometime in 2002. Current production of the 6.0 use the same pistons, so changing the engine now may result in better, the same or worse results. Since performence is O.K. and I don't do more than 6K a year, I'm going to wait and see what happens, but as a lifetime Chevy man I'm not very happy right now.
My buddy drove his GMC with clunking steering shaft for 10,000 miles, there's no safety issue or it would have been federally recalled. IT WAS JUST ANNOYING and unacceptable for a vehicle, truck or not. Much like an engine knock regardless of brand.
So Oby is just being too picky about the vibes on his truck???
While you may not want to accept it, the fact that something is knocking when cold means those clearances are looser than where they should be(Ford was running forged pistons which naturally must be run with more clearance than a cast piston. There was just too much clearance)This may not affect performance at first, it will most definitely affect longevity. The motors are still wearing, they just have that much less clearance to wear out till you lose oil pressure or have a more permanent LOUDER knock.
Sorry Ryan, any knock in a motor is unacceptable. Ford, Chevy or even (gulp!!) Toyota.
I didnt buy my truck with a start up noise. At about 10-11K it started. Doesnt do it everyday. Lasts about 5 seconds max.
Quad, I'm hurt!!! You ALWAYS agree with me! LOL!!!
-- Don
Anyway, my solution for that was to modify the thermostat to open 10-12 degrees sooner. Worked in cooler weather, allowing me to run regular unleaded. In hot weather, t-stat is open all the way anyway, so no benefit. Ran premium for 2-3 hottest summer months. Anyway...no problem with DURAMAX diesel!!!
I always agree with you when you are right!!!
My last motor I built I ran TRW forged pistons that actually called for a pretty tight .003 clearance for forged units. I've seen some forged pistons run .005. Cast are usually in the .002 range. Let's say, hypothetically, that oil usage and cylinder seal is compromised at .009 piston/cylinder clearance. If the GM motors are already at .006-.007 causing a little cold knock, wouldn't that leave less time till it reached that .009 number???
By my reckoning, there is only scattered commentary on this topic, less than 30 posts total at this point. Problem is real enough if you have it though.
Diesels have loose tolerances, and seem to run a pretty long time by the way. One thing I'm keen to, is how long it takes the crankshaft to stop turning when you shut it off, new...versus how long after a few thousand miles. I think other things are at play also, like how you maintain it, frequency of the oil changes, did you stick to the break-in schedule, lots of high rpm early loosens them up etc.
Do you have the specs on diesels??? I always thought because of the enormous compression they'd be very tight.
I would however take a new engine (if it came down to that) or an extended warranty.
BTW, glad you enjoy your truck and I hope that you don't have any of the probs that the GM's seem to be having........so far.
Regards
Tim B
Of course, that's Powersmoke diesel...Duramax bound to be muchhhhhhhh tighter
As for what's happening with these 6.0L engines, can't say. My '99 was 5.3L fine. Definitely felt tight, like it could go 200,000+ easily. What could have happened since then?
My '91 LX 5.0 Pony car had a bullet proof engine that was much more user friendly to the go-fast guys than the OHC that replaced it. Still, that engine was wheezing at 4800, and past done at 5200 rpm. These Chevy truck motors are turning 5600. Food for thought.
That's interesting on the diesel info. I find it hard to believe you could make 17+.1 compression with loose tolerances.
I too am a 5.0 fanatic!!! That and the SBC have no comparison as far as aftermarket support.
What's sad to me is the fact that Mustangs clobber camarobirds in the showrooms. The 4.6 SOHC is up to 260 HP but is still no match for the mighty LS1. The Cobra R 5.4 is N/A and runs 385 horses. No need to upgrade the 'stang with that motor 'cause there is no competition(as far the bean counters go)
Am shopping for a Lightning tomorrow to replace the Cobra. Will offer $500 over invoice and want wholesale book for the Cobra.(17,000) If no deal I'll wait for the new paint(Ford authorized it and I'm scheduled for the 13th) and go Lexus/Accura shopping. The ball's in their court!!!!
Remember, it's not the static compression ratio. Compressing air 17:1 or 8:1 doesn't compare to the combustion pressure that develops when you burn a fuel mixture. In the case of the diesel, compression ratio is not so important except you need it to produce the temperature for ignition when the fuel is injected. Consider, it's 17:1 AND turbo'd.
Loose tolerances are still a leap of faith on LS1's. I think the short piston skirt has been mentioned.
One other correction...when I read about the piston slap in 5.4L Tritons in Truck Trend, the fix offered was not a new engine, just new pistons...fix was not offered...you had to be affected, and you had to ask.
By the way i like my truck us it off road on the beach every weekend, probably will rust out before the 6.0 goes! If i could only solve the high speed vibrating/whistle sound.
Went back to premium, works fine.
Really happy with the truck at 7,000 miles.
