Oil Filters, whose is best, and Why?
From Mopar study....
Mobil 1
M1-301
Like the Champ filter, this filter is made by Champion Labs. However, it uses a unique end plate and a thicker can that make it the strongest filter available for wide distribution retail sale. It also uses a synthetic media, which inproves filtration and flow. I'm happy to say that this filter is NOT a fake. It is definitely a unique design.
It uses a synthetic fiber element that can filter out very small particles and is very strong. It is rated just under the Purolator Pure One as far as filtering capability, but is still very much above conventional paper filters. It also has a very strong construction to withstand high pressure spikes during start-up. However, as with all Mobil 1 products, expect to pay 2 - 3 times as much for this filter.
I have received many reports of these filters failing at high pressures. It seems that the seam where the backplate crimps to the case can split.
Exploded view:
Average Retail Price $10
Cartridge Length 4.250 inches
Cartridge Outside Diameter 3.250 inches
Cartridge Inside Diameter 1.625 inches
Cartridge Pleats 52
Cartridge End Cap Type Stamped-steel, with bypass valve
Anti-Drainback Valve Type Nitrile rubber diaphragm
Bypass Valve Type Spring-loaded steel, nitrile seal
Element Type Synthetic media, glued seam
Element Length 85 inches
Element Width 4.125 inches
Element Surface Area 351 square inches
Shell Thickness 0.022 inches
Backplate Thickness 0.138 inches
Gasket Type Nitrile rubber
Again, the web page quoted is at:
http://members.nbci.com/minimopar/oilfilterstudy.html
"Car And Driver
SF-1A
This filter is a Champion filter.
Average Retail Price $3
Cartridge Length 4.000 inches
Cartridge Pleats 54
Element Type Paper media, glued seam
Element Length 87 inches
Element Width 3.875 inches
Element Surface Area 337 square inches
Shell Thickness 0.012 inches
Backplate Thickness 0.102 inches
Gasket Type Nitrile rubber"
2. Purolator= troubling assembly problems because of the "string" causing crushing.
3. Champion Labs= generally good filters, although I have some question whether using a "premium" high density filtering medium can put undue pressure on the assembly itself.
4. Wix= seems like a good filter.
Come to think of it, I have read that the Mobil 1 filter is Hastings. Is it a Hastings filtering medium in a Champion Labs case?
I think the main lesson in the MoPar study is simply to never EVER use a Fram/Quaker State/Pennzoil oil filter. Everything else is probably OK. Some OEM brands like the MoPar filters may be Fram or just about anything else.
My Hyundai Elantra is due for an oil change soon. I'll probably take it to Wal-Mart after putting a big "no Fram" sign on dash and air cleaner and ask for the $11.99 special. Hopefully they'll use Super-Tech (Quaker State) oil and the Super-Tech filter. Optionally I'll get the $30 synthetic fill and tell 'em to use Mobil 1, but I can get 2.5 dino changes for one syn!
http://www.ntpog.org/reviews/filters/filters.shtml
Comments:
This filter looks identical to the Toyo Roki-made JDM filter at first glance- externally the same construction, the only indicator is the "FILTECH" stamped on the outside (a large US manufacturer of filters under various brand names). Internally it's *almost* identical to the JDM filter- steel end caps, steel bypass valve. What makes it stand out as different is the radically different filter media. The material on the Japanese filter looked like the STP or Bosch units. The US media looks much, much worse than the Fram. The media is noticeably "fuzzy" with small fibers protruding out from every angle. While the filter itself is constructed very well (like the Japanese one), the furry nature of the media makes me question how long it lasts and what it will release into the oil system. It also has the least surface area of all the Honda filters (though only a few inches less than the Canadian one).
I don't believe there are specs on the anti-drainback valve.
Yes, I'd agree that the Penske and Castrol filters are both made by WIX and so are the same as the NAPA line. But, do they all use the same valving? What about the same filter media? There seems to be some slight discrepancies in the way these are made (evidence of sealant drips, etc ...) even though the gaskets have the same colored marks on them in exactly the same places, etc ...
I think some of the newer Motorcraft filters are made by Purolator and are Pur-One. This is hearsay, however, and I haven't cut them apart myself to verify this.
--- Bror Jace
One of the earlier versions of the Engine Oil Filter Study slams Champion for having thin media and rusted end caps. Supposedly the author backed off Champion after legal threats. As far as I could tell the Champion filters cut open looked just fine. Couldn't tell much of any difference between Bosch, Deutsch (no longer carried), STP and suprisingly Mobil 1, although I'm certain that the filtering media in the Mobil 1 is probably different-- I just couldn't tell it.
AC had fewer but deeper pleats and the Purolator filters had the tell tale string, but no crimping of the filter media.
The Fram filter looked just horrible. Cardboard ends, almost no filtering media. Just like they say about ground zero, the pictures don't do it justice. I can't imagine anyone looking at a sample of that crap and buying it, but I'm sure they sell a lot of 'em. If any clerks are in the area next time I'm in there I'll ask 'em.
"premium plus" filters.
Obviously, I am NOT going to alienate any current or prospective customers with any comments that I might make. I will speak only in general terms.
I know a lot more about the media than I do about the assembled filters, but I have to know something about filters to be able to make good media.
Almost all automotive spin-on full flow filters have paper media! For some reason the manufacturers will dream up some other term for the media, but, believe me, it's almost always resin-impregnated paper.
Now, some grades of paper have synthetic components in addition to the cellulose (wood fibers). The two most common synthetic fibers used are glass micro-fibers and polyester (ok, there's a fancier term for what I am calling polyester, but i never can remember what it is: polyvinyl something or other).
The micro glass is a very expensive component in the "furnish" (recipe), but it does some dynomite things for filtration! The poly is there for endurance (flex fatigue and burst strength are greatly enhanced by the poly).
All major manufacturers make filters for other major manufacturers. It would not be practical for a filter maker to make all of the small volume filters (think of all the tooling they would need), so they make them for each other.
Our product is filter paper in rolls slit to the width of the pleated paper pack. Our customers unwind these rolls and feed them into a pleater.
The stream of pleated paper usually goes into an oven to semi-cure the resin in the paper. As the stream of pleated, cured paper comes out of the oven, they have either an automized work station or people that cut the pleated paper into pleat packs at the ink marks sprayed on at the pleater every so many folds.
The two ends of the pleat packs are sealed by various means (usually some kind of glue, but sometimes metal clips). This forms a cylinder of pleated paper that then has a center tube inserted into it.
The paper and center tube are placed into the bottom end cap, which has a trough around the edge and a layer of plastisol to form a seal. The top end cap is also put on, and it also has platisol for a seal. The viscosity of the plastisol has to be high enough that it doesn't run down when the top end cap is placed on the paper.
Usually from here the cartridge goes into an oven, where the plastisol is cured and the paper receives additional curing (often, the oven after the pleater just serves to stiffen the paper enough to set the pleats but not fully cure the paper).
The cured cartridge is placed in the can with a relief valve (usually) and then the base plate containing the anti-drain back valve is double- seamed to the can. The base plate is where the threads are and has the little holes for the dirty oil to enter the filter.
Ok, enough for now.
I will post a little later about what I know of that makes a good filter (without getting into brands!).
tom
Note that the chemical name for polyester fiber is polyethylene terepthalate. It has higher tenacity and elongation-at-break than cellulostic fiber. These characteristics do recommend polyester in terms of filter media strength and toughness - but Tsjay will have to provide the filtration effectiveness data.
Someday I would love it if someone in the know wuld give their opinion, I have also spoken to filter manufacturers and they also refuse to state who they think makes a good filter, the whole world is afraid of being sued, fired or just fearful of giving an opinion. Cheez!!!!!
Obviously, we work closely with the filter manufacturers as we develop media, but they don't always share all the info with us about performance.
We have our own "flat sheet" multipass test stand to evaluate the performance of our different paper grades. What is meant by flat sheet is that the paper is a disk of unpleated paper that has been cured and placed in the test stand.
This is tells us what the paper is capable of doing, and it takes out all the variables of filter construction. It serves as a basis for comparison and is a great test for developing media.
Gotta eat my breakfast and get to work, but I'll get back online tonight and answer all the questions that I can (or should).
c ya
tom
That's the same question I asked over in the "oil" discussion. I really don't know the answer, but I am very curious about it.
I will take advantage of the next opportunity to ask one of my contacts at one of our customers about it.
I know that they have a "cold flow" test that they run, but I don't hear about it very often. I think the filter people have a lot of tests that they just don't tell us about, unless they think the media needs to be enhanced for better results.
tom
Yes, the same filter maker can make filters that meet different specs. They can increase or decrease the pleat count, thus changing the total number of square inches of media in the filter. They can also use different grades of paper for some elements, with the higher performing grades being used in the premium filters. So, even though two filters might be used for the same application and made by the same company, they could be quite different in their performance.
If they are making a filter with their own brand, then they set the specs for the filter performance, but if they are making a private brand filter, then they have to meet the specs agreed upon with their customer.
Most of the big name filter makers have OEM (original equipment) accounts, and these filters have to meet the specs that the auto makers set.
As far as your desire that I "express my opinion," I AIN'T GONNA DO IT! I think you can understand why I will not get into brands. I mess around on the internet for FUN, but I feed my family (and, unfortunately, half my inlaws) by designing filter paper. So, pissing off our customers is not a good thing for my career.
tom
It is more important for me to know how to use it to get what we need in the paper than to know the technical name for it, although I admit that I really ought to know it. I am NOT a chemist by any stretch of the imagination!
tom
PLEAT COUNT:
There needs to be enough square inches of paper in the element to handle the load. There should NOT be too many pleats, though, because that can lead to "pinch-off" where the paper is too tightly packed and the oil has a hard time getting through.
PLEAT SPACING:
Uniform pleat spacing around the center tube is important. This spreads the load around to all of the pleats, and this makes the best use of all the paper in the element. The oil will take the path of least resistance, so a gap in the pleats will take more of the flow, and groups of tightly packed pleats will not take much of the flow.
PROPER CURE OF THE PAPER:
We impregnate the paper with resin for stiffness, so that the pleats will maintain their shape and spacing in the element. If the resin is not properly cured, then the pleats will not hold their shape and spacing.
PLEATING WITHOUT CRUSHING:
We go to lots of trouble to make a nice, bulky, low density sheet of paper for good dirt-holding capacity. Caliper is very important, but if the pleater is not adjusted properly, then the paper will be densified as it goes through it, and this will cause loss of capacity.
There are lots of other things too, but these are the ones that relate to the paper itself.
tom
tom
You have to be scientifically right on track with your info. Keep it up. Don't be discouraged by no current response. The site may have had a problem this evening (?).
The center tube is of a certain diameter in a particular filter. There are only so many pleats that you can get around the circumference of the center tube for a given paper thickness. Take into account that at the pleat tips there is a double thickness of paper.
There is an ideal pleat count, therefore, that is determined by this combnation, i.e., center tube circumference and paper thickness.
Without getting into brands, I will say that the premiun filters that have high efficiency will normally have tighter (more restrictive) paper, and to get the proper throughput, they use more pleats than would the average filter. In other words, a tighter sheet of paper will pass less volume of oil per square inch of surface area than a more open sheet, so there needs to be more square inches of paper in the filter to obtain the proper total flow at a given pressure.
These premium filters are designed to handle the extra pleats, so they do not "pinch off" even with the extra pleats.
tom
Who was the roundest knight at the round table?
(Sir Cumference)
tom
Usually, the filter design has already been established by the time we are asked to develop a grade of paper for that filter. This gives us constraints that we must work within in the design of the paper. Seems backwards, huh?
I'll get more into this tonight, but gotta get ready for work now.
tom
Myself, I use Pure One on one car and Amsoil on the other 4. One the one I use Pure One it is because after two Amosil filters for this model they both leaked at the Gasket. Bot brands for me provide excellent oil analysis results.
There is room for debate as far as what oil and what filter are the best. There is even more room for debate about what really wears an engine out.
I think you'll find that automotive engineers will argue among themselves about what factors are the most important in engine wear. Is it the dirt particles, and, if so, what size particles do the most damage? Is it the harmful chemicals that build up in the oil? Is it sludge that harms the engine the most?
I would bet you big money that if you took ten engines and used oil from the very same batch for every oil change in each engine, used the same type of filter on each of them, drove the vehicles in a convoy over the same roads every day, and did everything you could possibly do along these lines to assure that each engine had seen exactly the same conditions of use, you would see one of them give up the ghost at 150K miles, one at 175K miles, one at 250K miles, etc.
There are just some inherent differences in engines, even the same type of engines produced one after another in the same factory. It's called variation, and every process has variation.
Think of all the parts in an engine! There is variation in each of these parts. The engines that last the longest maybe got the parts that had the least variation, and the ones that died sooner might have the parts had more variation.
Look at how many more RPMs a balanced and blueprinted engine can handle than a standard engine. That's how important the variation in the parts can be.
Obviously, the oil and the filter and how often they are changed are major factors, and it would be foolish to ignore these things.
But above a certain point (and I sure can't tell you where that is), a better filter or a better oil won't do any good, because something else becomes the limiting factor.
tom
I will try to do a little homework at work (can you do homework at work?) so that I am not trying to quote numbers from memory.
The pressure drop with clean paper is a more appropriate test for an assembled element, since the construction of the filter is a major factor there. We are held to a maximum "clean element restriction," but there is only so much we can do with the paper, and the way the filter is designed and constructed becomes the major factor.
I will look up some of our flat sheet multi-pass results for the standard run-of-the-mill oil sheets and for our premium grades. I could quote you some pretty accurate numbers right now, but I would rather give you actual data.
Our multi-pass test starts with a clean disc of cured paper (about 6" diameter, I believe). The oil is comtaminated with test dust and in-line particle counters measure the concentration of dirt by particle size groups upstream and downstream of the paper. This is how the efficiencies of the various particle size categories are determined. The test is continued until a certain pressure drop is reached as the paper becomes plugged with dirt. By keeping track of how much dirt is added before the terminal pressure drop is reached, we can calculate the capacity of the paper in miiligrams per square inch.
Our multi-pass test results are reported as efficiencies at various micron sizes and capacity in milligrams per square inch.
tom
5µ 7µ 10µ 20µ 25µ 30µ GMS/In²
53 62 89 95 99.9 .083
65 73 83 98 99.7 99.9 .063
You can see that we didn't even test for the five micron efficiency on the standard filter's paper. The premium paper is higher in efficiency at five microns than the standard paper at ten microns.
You can see that the premium filter's paper is lower in capacity, but this is in grams per square inch, so they just put more pleats into the premium filter for more square inches and end up with filter capacity as good as the standard filter.
Sorry the table doesn't turn out too well, but you can figure it out, I think.
tom
There are different size "reams" in the paper industry, but we define our ream as 3000 square feet in the filter paper business.
One of the major differences in the two sheets that I compared is the amount of micro glass. The standard sheet that I used has just a smidgeon of glass and the premium has much more.
tom
Of course these sheets are very tight and could not be used for oil applications.
Fuel is much lower in viscosity than oil, obviously, and therefore flows more easily through the paper, and flow volume requirements are much lower. It doesn't take much fuel flow compared to the flow required for lube.
tom
