Tacoma vs. Camry
Does anyone know if the Tacoma and the Camry use the same engine?
Totally different power plants. One for speed, one for hauling.
The 3.4 was a new design specifically for the Tacoma when it was introduced in 1995 although it has been introduced into other vehicles such as the Tundra (for base models), the new Highlander, and the 4 Runner.
Cheers,
John
The engine code on that 3.4-liter V6 is a 5VZ-FE. That's odd, because a relative of mine had a 1989 Camry V6, and it was called the 2VZ-FE. And I believe the 92-94 Camry V6 was 3VZ-FE before switching to the current 1MZ-FE V6 in 95.
Maybe the Taco's V6 is a stronger "truck" (stronger block, etc.) version of the old Camry V6. Hmmm.......
-RAVvie4me
I know Chevy has taken their 4.8 V8, and used a shorter piston rod and different crank to get the 5.3 V8 with the same head and block.
It would't surprise me if little tweaks like this were done all through out the auto industry.
Thanks for the clarification on the Highlander. I knew that but thought I deleted that out. Gotta cut down on smokin my banana peels.
John
