I think it's an offshoot of when the new CarSpace was rolled out and the Elantra area had a flood of new threads.
Good catch!
It has 72,000 miles, and I had the timing belt replaced at 63,000 miles, and the other drive belts also.
badly on the shroud's steel flange or bracket that mounts to the top of the air cleaner cover by trying to short-cut the removal. Obviously, mechanics are always trying to save time to book as much work as possible. An extra minute of his time would have eliminated this problem altogether.
The dealer was good enough to order a new air cleaner cover Part number 28112D270, but interestingly, the replacement (same part number) is not the same as the original! If you look inside the original air cleaner cover there is an "air horn" of sorts projecting inside the cover connected to the opening or hole of the cover which leads to the intake manifold. The replacement does not have this air horn extension inside the cover.
Anyone have any thoughts on this? In looking at the Hyundai parts website, it does not show this extension as available separately. It doesn't appear the air horn extension comes off easily either to place it on the replacement air cleaner cover.
There must be a reason for this air horn extension inside the air cleaner cover. BTW . . . the tech never found a problem that could have triggered the Engine Check light fault code.
Be persistent with the dealer; this is a new car issue that is clearly under warranty. In my case it took probably 5 or 6 tries before they finally got everything right. They were real good about it and followed the troubleshooting charts, but I think the issue was that, yes, the O2 sensor was bad, but there was also something else wrong. It was only after they replaced the stuff in the evap system *and* the O2 sensor that the problem was fixed.
Make sure this gets fixed; if you have a Check Engine Light when you take the car in for inspection, it will fail. (most states require the car to be CEL-free for later models.)
It has its own part number: 2813826320. It's called "Hose, air intake".
It's a little confusing, though, in the Hyundai parts listing. Looking at the picture in the parts catalog,
You should be able to find the label 28111 in the picture. Looking it up in the listing, this is the 281112D270 you mentioned. A little left of that is the label 28138. In the listing, the 28138 part on non-CVVT cars (2001-2003 model years) is a 281382D001, called a "HOSE-AIR INTAKE".
On CVVT cars (2004 to 2006 model years), according to the inset diagram at the top, the part that looks like that is labeled 28139C, "HOSE-AIR INTAKE [B] (CVVT ENGINE)". The full part number is 281392D250. Also in the CVVT inset, there is a different part labeled 28138- this is your "horn", also known as "HOSE-AIR INTAKE (CVVT ENGINE)". The full part number is 2813826320. It is a separate part from the top of the air cleaner. If your dealer failed to take the horn out of the old air cleaner and put it into the new one, he now owes you a horn as well. Dealer list price on that part, by the way, is $20.10.
If you need the horn, print out this post and take it to the dealer; it should help straighten things out. I hope!
Is this covered under Hyundai's 5 yr./60,000 bumper to bumper warranty?
Thanks! :confuse:
Shortly after I got it back from the garage, the engine light came on, so I took it back down, and they supposedidly put it back on the computer and nothing was wrong, so they just had to re-program the new engine...Not to mention that now, it is very loud...
Then after a week or so, when I left it run all the way down til the low fuel light came on... the engine light came flashing on, and then stayed on. I was also going around a sharp turn, so I thought that had something to do with it. Well after I pumped gas into it, the light went off. Ever since then though, almost every time I would put gas into the car, it wouldn't let me pump it, it sounded as if it wasn't even going into the pump. So when I took it for inspection, I told the garage what happened and said they would check it out. Well when I went to pick it up, they said it wasn't the vent hose like they had hoped because they could have fixed that without having to drop the tank.
So then I took it back to the garage that I had gone to, to have them replace my engine... Well they fixed the problem, they apparently cleaned out some hose or something, but didn't charge me because it was their mistake. But after a few days of driving it, the engine light came back on. My dad knows a lot of stuff about cars, so I asked him to look at it. He reset the car, by taking off the positive side of the battery, and cleaning it off... Then he took it out for a test run. He ran it to 50mph, and nothing came on. So I took it back home, and when I came to a red light, and I had to sit there for awhile, the engine light came on again, and stayed on. It seems like the car idles very roughly almost like a disiel powered car, but it's not. One morning I, once again, left it go down to the low fuel light, and I was going on the highway at about 60-65mph, and the low fuel light came on, and then all of a sudden it felt like something had dropped in my car, and lost some power, so then I decided to slow down, and my engine light came flashing on, and now it once again has stayed on. I'm trying to figure out if this is a major problem or not... I'm hoping not, but with my luck with cars, it will be...
timing belt replaced on my 2001 elantra.i would like to
know before shopping around.
thanks/
thanks/
I have done stuff like changing headlight bulbs, air filter. This is my first attempt at a DIY job on the spark plugs for an Elantra. Any tricky stuff I should keep an eye out for while changing the plugs?
Thanks for your help.
Robyn
Basically, what you need is an engine air cleaner replacement (something you could do yourself!), a radiator flush & fill, a transmission flush & fill, oil change, and probably a tire rotation and balance. Also, have the inspections recommended in the owners manual done (which at my dealer is included with an oil change). The cost to me for these was only $200, as opposed to the $360 package recommended by the dealer.
My best advice is have them give you a list of the 30,000 mile service package, and cross off everything in the owners manual that is not a recommended item. It should save you about $100 or more.
And as doohickie said, there are some services that are very easy to do yourself, such as air filter and cabin filter replacement.
Plus, if you ever want to get a new head unit later on or want to convert back to the stock stereo, it's a lot easier to do if you buy the adapter harness.
If you want to do it yourself, it's really not that hard. I've written up a CarSpace Guide On how to do it yourself. I have an 05 Elantra which is identical to the 04; if you have any other questions, just let me know.
I'm new to this forum, have a Hyundai Elantra 01, 4dr sedan.
I'll be grateful if anyone could help me with this, the windshield washer doesnt work anymore, I had a look at it, its not the water being empty, or the pipes being clogged, so I think its the windshield-washer motor, cause I dont hear the motor sound anymore, any idea where the motor is located or how do I access it? short on money so i'll have to fix it myself.
Thanx
ya the motor is at the bottom, and the worst part is, i cant pull it or slide off from the top,found a high pavement and pulled it out from below. the worst part is that the replacement i found has a different power socket so now to friggin go down and try to a re wire it.
thanx for the help
Ran down to the local Autozone and picked one up. Got home and when I went to install, found that there was no bypass valve in the filter. Checked it out further today and found out that the AC Delco was identical to the STP crap that they sell. Right down to the color of the filter, just the label was different.
I had read that AC Delco was having a problem with counterfeit filters flooding the market, but this was the first time I had seen one up close. Just for grins I went to another parts house that carries various brands. Of the six brands I checked, only the STP and AC Delco did not have the bypass valve.
I will be going by the dealer today to pick up a supply of Hyundai OEM filters. :mad:
