I am wondering about putting this tire on my '05 CRV-SE? It is too "truck-ie" for this vehicle? I live in Pittsburgh and we burn thru tires (up and down hills all day long). The truck-like characteristics of the LTX-MS seems to hold up better. Currently are 14 month old CR-V has 10,000 miles on it, but the burn rate will be much quicker now that my teen daughter is driving (so will my hair-graying rate). The factory Bridgestone Dueler tires are crap...about 1/2 to 3/4 worn to replacement.
So what do you folks think about the tire I propose?
In other words, getting lovey-dovey with the dealer is a high priced insurance policy on a low risk item.
Neat car - when my son lets me drive it..."
I think the book says 27, but you can put anything you want up to the max cold pressure. I kept 33 - 35 in my 2003, for better fuel economy. And your son is young enough to take the harder ride... :P
Would be a bit of a bummer to have it reboot while you are driving at 3am... :surprise:
Anyone out there that has had this type of problem fixed.
Gremlins. OMG, they killed a sensor. :sick:
That's odd. It is louder then some other cars, but nowhere close to beeing THAT loud.
I guess you are just too sensitive.
When I take off the glove compartment I see some large units. Could it be the heating system or air-conditioning system.
Can someone please tell me what this humming noise could be and how to fix it.">
when you hear this sound, have you opened the hood to see if it is the radiator fans? if they continue to run to the point of running down the battery, could be a thermostat issue or a fan relay issue. you can probably rule in/out the fan relay by looking at the relay/fuse box in the engine compartment and swapping an identical relay for the fan with something else (in my '94 accord, it was a power window relay). so then, if it is the radiator fan, but swapping the relay doesn't fix it, it could be the thermostat.
lets say it isn't the radiator fan. is it the blower motor for the cabin fan?
lets say it isn't that. where is your antenna located? is it one that when you turn the radio on, it goes up?
open up the engine compartment, and pull the cover on the relay housing and go from there. If it's located on that side of the vehicle, mayne it is a relay that is chattering.
Upshift? Watch tachometer.
Honda Automatic will downshift when you slow down, it is related to grade logic circuitry. Watch your RPM's when it does that. They should jump 500 RPM.
By reading the OWNER's MANUAL!
Yes, CR-V has the steering wheel lock, which is activated when the key is removed. There is a pin that locks the column so that a thief (in theory) can't steer if they have by passed the immobilizer and started car. It doesn;t always activate because it is set to work only a a few angles of the steering wheel.
Time to break out the MANUAL out of its wrappers.
That's the Honda vs. Toyota thing. Toyota isolates the driver from the car or the road with overboosted steering assists, and excessive sound insulation. Honda, on the other hand, makes cars that are sportier and "tell" the driver what is going on. Some like it some don't.
Think of Toyota as Mercedes, and Honda as BMW.
Check the air filter box, see if it is closed.
The only time I heard my CR-V make noise similar to not having a muffler is when driving in 2+ feet of snow this past February.
Honda CR-V Tires & Wheels
Anyone else experience this? Should I be worried?
Thanks in advance!
I realize that you have probably dealt with your problem by now but I would be interested in knowing the results or if you are still in the midst or working on the issue.
I found that if I clicked the "unlock" button on the remote I was then able to get the key in and start with no problem.
Kind of quirky but was glad I could get it to go. I must say though I did PANIC when it happened as my SE only has 300 miles on it!
I have a 2004 CRV with almost 7,000 miles (short commute to work!). The other day my check engine light came on and when I checked here and the owners manual it said if I had just refueled to tighten gas cap and drive it for several days and it should go off.
I had just refueled, so I have done that and have now driven about 100 miles and the light is still on. My brother another CRV owner thinks it takes more miles to make the light go off. I don't want to damage the car, does anyone know about how long it takes if it was a gas cap problem before it will go off?
Thank you so much!
Good Luck
M
Hello I just wanted to tell everyone that HONDA really backs up their product.
I just had the trans replaced a power door-lock (slider driver) and replaced the ignition interlock on a van that is OVER 7 years old and has almost 80,000 miles on the odo. No hassle, no BS just yes sir we will repair this under Honda's warranty service. I never bought an extended warranty either. I will drive nothing but Hondas from now on and I will most likely buy them at Norm Reeves in Cerritos SoCal!!!!
Sidenote, - I had a lincoln continental, blew the trans at 72K, the motor at 75K and the suspension at 80Kmls. Ford told me to go fly a kite every time! Guess what? -- I dissuaded at least three peoples from buying a ford product, but have swayed at least six peoples to buy Hondas. I have three Hondas: a '91 Accord, a '99 Odyssey, and an '05 CR-V...
And I really want to add an Element to the list... :-)
I'm going to move your CR-V AC question to the topic covering those particular issues. Here's the link:
Honda CR-V AC Problems
MrShiftright
I was wondering if others have encountered a similar problem or have any suggestions? Would appreciate any ideas.
T.N.
Hmmmm - I think I would get another opinion.
Thnx
33,000 miles
The other day, it started making hte same noise you are describing here, when I make a hard left or right.
I dropped my car off at the dealership this morning for an oil change, and asked them to take a look at it.
They called me back, said the power streering fluid was full, and that they would have to take another look at it, becuase I may need to have the rear dofferential fluid changed, and it would cost me $95.00, and its not covered under warranty because it's a mainteanace issue.
I am still waiting to hear from them.... any advice...
I have never had to do this with any other CRV's I have owned, and to be quite honest I am annoyed that I have to pay almost $100.00 for that, and tha car is so young.
I searched a few posts for you - see 4529 and around it, also 4013.
But best, Varmint, one of our honorable members, has a great thread you should start with:
http://townhall-talk.edmunds.com/WebX/.ef229e9/17!make=Honda&model=CR-V&ed_makei- ndex=.ef229e9
I called the dealrer I originally bought the car from, and they told me it was covered as warranty work, becasue honda doesn't tell you to change your fluids untill you get to 40K miles.
I called back the dealer close to my office, where I dropped off the car this morning, told them what the other dealer said, and he changed his tory.
He said he talked to the technician and his technician said they would take care of it under warranty.
Saved me $100.00 .... Woo hoo....
I am thinking twice now about giving this dealer any more of my business. It's conveniant because it's right around the corner from my office, but that's really just it.
What have we learned today - Always question authority
Incredable that a simple phone call saved me $100.00
Mandie :sick:
