Quick Links
Quick Links
Are you under 40 and think that you might not be able to afford a brand new vehicle when you purchase your next car? If so, a reporter would like to talk to you. Please reach out to [email protected] by 12/16 for more details.
List your lemon trucks here: 1980-2002
Owned the following LEMONS:
1980 GMC Heavy Half w/350-4V 3:08 long bed, torque lockout auto tranny, it was painted metallic blue, should have been yellow. Horrendous defects, too many to list
1991 GMC S10 Blazer TAhoe 4x4 4-door 4.3L Defective ABS system, brakes, worn out valve guides at 79,000 mi resulting in blue smoke at start-up, 20,000 mi brake pads, and numerous electrical problems
2000 S10 Xtreme, 2.2L manual tranny reg cab black mini (for commute purposes) :
Horrific stalling at 20K, dealer unable to fix after 4 tries. Possible defect, Engine management computer.
RE: Ford pickups: of the three owned, '83 F150, '94 F150, '95 Ranger XLT =0 DEFECTS, flawless operation...
1985 Ford F250, 460 C6...Flawless
1989 Ford F-350 460 5speed EFI...Flawless
1996 Ford F-150 5.8 4x4. beat the crap out of it!!
wheel bearing seals under warranty(might be because of the high speed mud crossings) and steering box after stuffing right front tire into ditch at 50mph @ 3am!! Also covered under warranty!!!
'00 Super Duty...flawless
'01 Super Duty.....may need to get cab/bed mounts tightened. Hear some popping over bumps occasionally.
Oby, don't bother, there's not enough server space for your lemon.LOL!!!
- A/C blower replaced
- throttle body replaced
- steering rack replaced
- the infamous 5.3L piston slap - knocks like mad when started cold (new pistons on the way, says GM)
- front springs noise (dealer can't find)
- door hinge covers loose (two tries - no luck)
- driver seat back moves when starting from a stop(dealer can't find problem)
- clunking underneath (dealer can't find)
- pinging at highway speed (reprogramming computer helped)
- coastdown vibration at 700rpm (dealer hung weights on the exhaust system...helped some)
- harsh transmission shifts when cold (dealer said all OK - ha!)
- bumping in steering at slow speed (dealer will attempt fix this week)
Wish I had kept my '95 F150 Supercab...no major problems for 100K miles.
Peter
"harsh transmission shifts when cold (dealer said all OK - ha!)"
That is normal read your manual (i believe it states this fact in there).
Ryan
Have they replaced the instrument cluster? Only thing that fixed my dads (92 S-10). His stopped working and only worked after 1/4 tank
96 silverado...after two months discovered overspray on frame rail, some body damage had been repaired..replaced fuel pump,stopped at dealership to complain about hard starting and the truck refused to start..anti-freeze leak at rear of engine, replaced intake gasket..anti-freeze leak at front of engine, replaced intake gasket..replaced alternator..had severe engine knock when totaled in auto accident.
since i have had such good luck with my chevies i now own a 2000 silverado(my wifes comment:why another chevy?....good thing i never told her about my experience with my 78 olds cutlass).
1.Both doors replaced due to cracked sheet metal (cracked again!)
2.Roof rails redone...cracking again!
3. Pitman arm replaced, due to creaking and excess play
4. O/D button no-workee
5. Pass. side window barely goes down(dealer can't fix)
6.Coolant leak from timing chain cover.
Trading truck this week, NEVER BUY A FORD!!!!
We have had the bushings replaced on the sway bar links because of constant squeaking. They were replaced about 2400 miles ago and there getting replaced again. There was a rattle underneath and we found out that the converter needs to be replaced. We've had the same problem as googs3...tranny slips or hesitates, truck stalls and then its ok after truck is restarted. Dealer says this will happen when the engine isn't warm...believe me, it happens warm or cold. Has anyone else had these problems and what did you do?
Dealer got to hate the sight of me. I sold the pig at a loss but got rid of it. (No more Fords!)
In short, it is my opinion that GM does not build their trucks strong enough to do the job they are supposed to do. I guess the days of a "real man's truck" - all metal, built like a tank, couldn't kill it if you wanted to, go absolutely anywhere, ride like a log wagon, scares women and small children kind of truck - are gone now that the manufacturers are catering to soccer moms and limp wristed real man wannabees.
crank sensor,elec body control module now found bad .5609 miles ,stalls again same symptoms dealer has truck for 2 weeks, finds bad power train control module,2nd crank sensor,cam sensor all bad. when i picked it up i warned about lemon law possiblity here.. they said all fixed now... mechanic drove the shi* out of it and its all peachy now.....5 days later guess what? STALLS
I call detriot to register a complaint and register it as the boat anchor that it should have been from the start... LOL GM Begs me to give them 1 last chance to fix truck before i do the lemon thing, they replace ign switch,throttle body,gas pedal and accel pedal assembly, 3rd crank sensor...oh did i tell you that i had to repair the hood with my pennies... 3 months of wonderful driving then it hits the fan.....steering shaft rattles loose at steering box,coolant leak on head,transmission shifts and slamms, shifting onto overdrive sounds like you are driving over a cattle crossing.... i call detriot to tell them the games are over, lemon law time.. they say they promised to buy back only if stall problem repeats not other issues, so sorry for me.. they replace transmission control module, steering shaft, reseal plug on head and tell me all is well!! 3 MILES LATER transmission control module trips 5 trouble codes and shift like shi*******... I Went to Dealer GM where i bought the truck and told him make GM BUY BACK THIS TRUCK OR THE PICKET SIGNS AND LEMONS GET PAINTED ON TRUCK AND I PARK IT ON THE STREET IN FRONT OF HIS DEALERSHIP FOR AS LONG AS IT TAKES
After 1 VCM,BATTERY,3 TCMS,2 PCMS,COIL PACK ,3 CRANK SENSORS,ELEC BODY CONTROL MODULE,CAM SENSOR,IGN SWITCH,GAS PEDAL AND ACC SENSOR ASSEMBLY,THROTTLE BODY,STEERING SHAFT, HEAD COOLANT LEAK ...GM is
Repurchasing my truck . I hope the buy back goes as fast as they took my 14000 down payment....i will keep all posted....
I detail this for you and others who think they have a complete lemon when the problem is a dealer whose techs cannot find the root cause of a failure. I do know that lemons exist. You cannot mass produce anything without getting a dog every once and a while. Even something as simple as lightbulbs sometimes burn out the first time you apply power. Just try to find a dealer with a good service reputation no matter what brand you buy. Good luck,
Jim
BUT, I did not give up on GM and ordered the first year run of the 88 Ext Cab w/4.3, that turned out to last me 12 years before I sold it w/126000 miles and ordered the 2000 Silverado I have now. As JLFlemmons writes there are some bad runs in a production line and it must have taken a major electrical hit at one point to cause those electrical problems.
Good Luck on your next truck no matter what brand it be!
Ray T.
Regards and happy holidays to all truck loving people, etc
Lee Iaccoa, I want my money back on the 1982 K-car Dodge Aires cream colored wagon i bought for my wife back in 1982!!! Shucks, the warranty expired, FORGET IT LEE!! Oh i loved your book.
Old Carnut, With all those problems you noted you should have brought it to another dealer or contacted GM since the warranty still applied and all the TSB's that were issued for the majority of these problems.
It sounds like you relied on only one dealer and didn't follow through when turned away, I feel for ya but in this day & age you have to be proactive with dealers to get what's yours. I was always taught to stick to my guns when I'm right about something & be willing to compromise when necessary, it's been good advice to date.
Ray T.
2 heater cores (17K and 66K)
1 steering gear box @ 18K
Seized #3 connecting rod bearing @ 21K
Idler arm, tie-rod ends @ 23K
Driver's window regulator @ 24K
New transmission @ 28K
Windshield wiper motor @ 30K
starter @ 31K
Lower ball joints and right fronr lower A-arm @ 33K
Master cylinder @ 40K
Speedometer replaced @ 42K
Left rear outer axle bearing @ 50K
Alternator @ 55K
Idler arm, pitman arm, Upper ball joints @ 60K
Began fouling #4 & #7 spark plugs. Oil consumption at 60K was 1 quart every 450 miles.
Timing chain, valve guide seals & recondition cylinder heads, 5 new vavles, all new lifters and camshaft @ 65K
Transmission @ 71K
Total out-of-pocket expenses for 76,000 miles = $4313.00.
Above figure includes other repairs (brakes, exhaust, etc.) and does not include warranty repairs.
- Fan clutch failed
- Brake master cylinder failed
- Blown intake gasket
- Cat-back exhaust replaced (hole in muffler)
- Cracked cylinder head
- Paint in roof gutters and on hood cracked and peeled off
Intake gasket and cylinder head fixed under warranty, with $100 deductible.
Coolant leak at 1K
Poor door alignment @1K
Accelerator pedal falls apart @2K
Squeek noise from rear @2K (not resolved)
Air conditioning fails @ 5K
Mildew odor @ 6K (not resolved)
Air condioning fails. Replaced low pressure switch @ 7.5K
Brake vibration. Replaced left front rotor @ 10K
Replaced idler arm @ 12K
First complaint about peeling paint. This issue never resolved correctly. Vehicle repainted four times by GM.
Rough idle, idles too fast. Replaced carburetor base gasket @ 14K
Oil leak. Replaced rear seal @ 15K
Drive line clunk. Replaced U-joints @ 16K
Oil leak. Replaced front timing case gaskets @ 17K
Brake vibration. Replaced left caliper and rotor @ 19K
No start. Replaced engine compartment wiring harness @ 21K
Starter fails. Replaced @ 23K
Noise and vibration. Replaced torque converter @ 27K
Steering column breaks. Replace complete assembly @ 28K
Starter fails (continues to crank engine) @ 33K
Starter fails. Replaced starter ring gear and starter @ 35K
Replace idler arm @ 36K
Replaced heater core @ 39K
Replaced driver's power window regulator @ 40K
Rear axle side gears explode. Replace complete rear axle assembly @ 44K
Air condition fails. Replace pump and condenser @ 45K
Starter fails, melts cable from battery @ 48K
Replace battery @ 49K
Replace windshield wiper motor, arms and pivots @ 50K
Replace speedometer @ 50K
Replace alternator @ 50K
Replace drivers door hinges @ 50K
Starter fails at 52K (Vehicle begins eating batteries at one per 6 months)
Engine seizes. Replace oil pump @ 58K
Replace idler arm @ 60K
Lights are uneven density. Install ground wire retrofit @ 60K
Starter fails @ 62K
Idles too high. Replace carburetor base gasket, intake manifold gaskets @ 63K
Steering column breaks. Replaced with used assembly @ 63K
Replace drivers door power window regulator @ 63K
Replace fuel tank @ 64K
Replace heater core and fan motor @ 65K
Replace alternator with 100 amp unit @ 65K
Oil leak, replace rear main seal, oil pan gaskets @ 66K
Oil leak. Replace oil pan (rusted) @ 67K
Replace torque converter @ 67K
Upper & lower ball joints, A-arm bushings, inner and outer tie-rods, both front springs, wheel bearings @ 68K
Total out-of-pocket expenses $7165.00. Includes tires, batteries, exhaust, etc. Does not include warranty repairs.
I park the truck in the drive with 1/4 tank of gas and come out in the morning reading "below" empty.
After checking all of Edmund comments I have found, like so many others, that GM admits to the problem. Now what? When the tank gets to 1/4 get gas? It still has between 2-4 gallons remaining depending upon driving conditions. Not the best way to know.
